Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 140
  1. #81
    Veteran Member Four Rings steve0827's Avatar
    Mar 07 2011
    981 GT4, 997.2 C2S
    Southport,CT
    I had it changed after 8k. Regardless, I went from topped up to minimum level in 3800 miles. Someone tell me there's something wrong. I have heard that our cars take 10 quarts??
    2012 Audi S4 (Gone)- Part-out Thread
    2016 Cayman GT4
    2010 911 Carrera S Convertible
  2. #82
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    I don't know what the specific "minimum" line on the dipstick means, but I bet it's a quart low or more. Does it consistently consume that much oil between changes? What kind of driving do you do? What oil is in there?
  3. #83
    Sep 13 2008
    Western Chicago Burbs
    Well when my oil light comes on, I pour in 1L of oil and it gets it to about the middle of the hash marks. I don't get what you are saying your intervals are. You first said that the oil light came on after 10,000 miles from it's last change. Then you say you got it changed after 8000 miles. So which is it?
    No matter what anybody tells you, you ABSOLUTELY MUST change your oil more often then that. In other motors, 10k interval is fine, but not on this car. Bad OCI's is one of the leading causes of scored cylinders. Change it every 4000 miles
    What oil are you using?
  4. #84
    Mar 07 2011
    981 GT4, 997.2 C2S
    Southport,CT
    The light came on both times. I occasionally drive spiritedly but even then I rarely go over 5k Rpm. This was the first time it's happened. My first oil Light was 7k after I bought it at 26k.....the dealer did an oil change right before I bought it.
    2016 Cayman GT4
  5. #85
    Mar 07 2011
    981 GT4, 997.2 C2S
    Southport,CT
    What I'm saying is that ive owned the car for 10k miles.
    I think I'm just gonna go with the b8 s4 I've been looking at.
    2016 Cayman GT4
  6. #86
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Quote Originally Posted by steve0827 View Post
    If thats the case then conversation done.
    If not then change your oil every 4-5000 miles. use a good oil search for oil recommendations there are lots of posts in the tech sections on this. Also check your PCV system that can cause oil consumption issues as well.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
  7. #87
    Veteran Member Three Rings travw3's Avatar
    Feb 26 2011
    F150, 2012 ZX6R
    Mesa, AZ
    My min oil light came on so i put in more oil until it was good, and about 400 miles later the light came on again and it had almost no oil according to dipstick, put 2qts in. Going to go get it checked out soon, any suggestions on what it could be?
  8. #88
    Feb 26 2011
    F150, 2012 ZX6R
    Mesa, AZ
    My car is in the shop, had a strange banging noise from the engine they took off the valve covers and manifold but didnt find anything so they called the master mechanics and they asked for my vin to see what date it was built because they said they have been seeing a lot of problems in certain build dates but they wouldnt say what it could be, they just said they would call if my car was a match for the build date problem.. Any ideas of what it could be?
  9. #89
    Veteran Member Three Rings Apat's Avatar
    Jul 04 2011
    B7 S4 , 97 A8, 99 A4 Avant
    Minneapolis, MN
    Quote Originally Posted by V8S4Ryan View Post
    2004 s4
    early build date. 117k miles
    the day before i heard a ticking noise checked oil a quart low. added oil and went on had a slight tick still. the next day tick got real bad. called a few people that are trust worthy mechanincs and confirmed it to be a lifter tick. will update with the outcome for sure. motor burned about a quart every 3k miles.
    Listen to these vids of my car. I thought it was a lifter. The problem was confirmed to be a broken timing chain guide. Thank god for extended warranties.
    http://www.youtube.com/watch?v=ivCf0iAt9ow
    http://www.youtube.com/watch?v=n9v9_jLjHqI
    Link to my thread with relevant information:
    http://www.audizine.com/forum/showth...FTER-warmed-up
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM Intake Manifold and Spacers // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // PSS9 Coilovers // 034 Rear Sway // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights // 19" Neuspeed RS10 summers // 18" VMR V710 winters
  10. #90
    Established Member Two Rings V8S4Ryan's Avatar
    Jul 22 2011
    04 nissam murano,11 dk clevland bike
    Havelock Nc
    your second video sounds alot like mine. but mine is coming from the passenger side rear of the motor and nowhere else. but i had planned on doing the timing chain, water pump,lifters, jhm stage 4 clutch, headers, and maybe a tune!
  11. #91
    Feb 26 2011
    F150, 2012 ZX6R
    Mesa, AZ
    2004 s4
    my car had the same noise but a quart every 3k is not bad, I have a thread on what happened to mine.
    http://www.audizine.com/forum/showth...177-New-Engine
  12. #92
    Sep 09 2011
    After two months and two mechanics, they pulled my motor and found the timing chain tensioners were busted. They're estimating $8K+ in total parts and labor for the repair. I have an aftermarket warranty, but we're still waiting on approval.
  13. #93
    Jul 04 2011
    Minneapolis, MN
    Quote Originally Posted by Isostar13 View Post
    Just went through this. My Zurich 3rd party covered the replacement of the entire timing set. You shouldn't have an issue. Whats the year and mileage of your car?
  14. #94
    Feb 26 2011
    F150, 2012 ZX6R
    Mesa, AZ
    Update on my car they said the bearings in the short block were coming apart and that was causing the point still haven't gotten the new engine. Think I might sell my car once everything is done.
  15. #95
    Mar 26 2007
    Colorado
    That is always really hard to sell once everything is fixed...... because it makes you want to enjoy it for another 30,000 miles or so
    CURRENT:
    2021 Atlas
  16. #96
    Apr 24 2009
    Frisco, TX
    If I was getting a free replacement motor, I would drive the shit out of that car for another few years. It's like starting over with a new car.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
  17. #97
    Sep 09 2011
    Quote Originally Posted by Apat View Post
    It's a 2005 with 120k miles on the motor. The techs are estimating $8k+ in parts and labor. My 3rd party warranty is supposed to cover this, but of course they're dragging their feet with giving an answer to the tech. I'm hopeful to hear a "yes" this week.
  18. #98
    Jul 04 2011
    Minneapolis, MN
    Sounds about right. I'll be getting my car back tomorrow (figures crossed). Its been almost 3 weeks. The warranty thing slows down the whole process but you'll be fine.
  19. #99
    Feb 26 2011
    F150, 2012 ZX6R
    Mesa, AZ
    Quote Originally Posted by dparm View Post
    you think there will be a big power difference?
  20. #100
    Sep 09 2011
    Got the car back today. About $10k total damage, but the warranty company covered roughly 80% of that. Not bad.
    The engine runs beautifully though, and its faster than its ever been since I've owned it.
  21. #101
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    Quote Originally Posted by B00sted20VUSP View Post
    It basically boils down to this....The engine is great for a period of time, then it just falls apart. Dont know if its because of faulty parts, or poor assembly or poor break-in. From my experience with this engine i will personally NEVER own this peice of shit 4.2 misfiring/oil burning/leaking junk. People shell out money for a car that should not blow up at 40-50k miles, lost countless nights of sleep fucking logging misfires, checking my dipstick, Monitoring Fucking insanely high 12% long term fuel trims on one side of the motor ONLY. The car is amazing when its running well, which is ONLY during a full moon and when the suns nuclear activity is at its peak when all the planets are aligned. Finally did a borescope test to the cylinder walls.....Started laughing and traded this junk in!! LS7 or GO HOME!!!
    I'm sorry to hear of your troubles. But I, for one, love this car for more than its engine. Nothing an LSX comes in matches the S4 - not only is it quick and comfortable, it flies under the radar like nobody's business. If you wanted a speed demon, you bought the wrong car to start with. If you want a sophisticated and understated sports car, this is one of the best in my opinion.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
  22. #102
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Agree 100%
    Quote Originally Posted by SquiddyB6S4 View Post
  23. #103
    Senior Member Three Rings zookie's Avatar
    Jul 30 2011
    NKY
    Apat, you were going to get the car back on 11/9/11, did that happen? How's it running?
  24. #104
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    Yea i was just fed up with it, but totally agree with you, I love AUDI AND WILL CONTINUE TO DRIVE AN AUDI. The LS7 is my Garage queen. Im getting ready to Seal the deal on my next AUDI this weekend. Theres just a feeling you get with these machines that is unmatched by any other car company. With that being said I guess my car was just messed up. I know several people personally with b6/b7 s4's and have 80-120k with NO issues with the engine; I was not so fortunate. None the less I WILL Continue to be loyal to a company that isnt afraid to test the waters with cutting edge technology.
  25. #105
    Mar 26 2007
    Colorado
    I think at around 85,000 Miles I will just pull my motor and do the chain guides as preventitive maintnence. Maybe even throw longtube headers on at the time. But I would rather pay the cost to make it preventitive than pay $8k down the road if it goes.
    CURRENT:
    2021 Atlas
  26. #106
    Jul 04 2011
    Minneapolis, MN
    Quote Originally Posted by zookie View Post
    Ended up taking 3 weeks. Busy shop + 3rd party warranty.............It runs so smooth now. Sounds brand new when starting. No DTC codes since getting it back(checked yesterday). I couldn't be happier with the car. Love it. Love it. Love it
    @ Vdub headers........heaaaaaaaaaders...... HAHA. I would've if I could've but I dont think my warranty company would've liked that idea.
  27. #107
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    anyone have a video with sound of a normal sounding engine? it's hard to tell which noise is supposed to be there and which isnt
  28. #108
    Oct 30 2010
    Buffalo, NY
    Do you think there were any changes to 2007 and 2008 S4 engines that would possibly account for the lack of scored cylinders and catastrophic failures or do you just think these models will soon start showing the same problems?
  29. #109
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by 2manyaudis View Post
    Mileage is much lower on most 2007s and 2008s, that's why. There were no known changes made.
  30. #110
    Oct 30 2010
    Buffalo, NY
    So other than frequent oil changes, what preventive measures should be taken and when?
    Thanks.
    Tom
  31. #111
    Jul 22 2011
    Havelock Nc
    Ok mechanic confirmed that the timing chain guides cracked and I had bad valve cover gaskets. Tada! Should get the car back on friday waiting for my ecu to arrive.
    Mods: JHM IM//JHM LWCP//JHM 93 OCT. TUNNING//JHM STG4 CLUTCH &LWFW//JHM TRIO PACKAGE//APIKOL SNUB MOUNT BUSHING//034 SNUB MOUNT BRACKET//TREXTRUK CATLESS DP//AWE CATBACK NON RES//BILSTEIN PSS9 COILOVERS//19X9 ROTIFORM BLQ//FLOSSY REDHEAD GRIP TAPE SHIFT KNOB//275/35/18 CONTI SLICKS//
  32. #112
    Jul 24 2008
    chicago
    Thanks.
    Tom
    There is lots you can do. make sure to let the car warm up in the morning before you hotrod the car. Do your maintece on time
  33. #113
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    Quote Originally Posted by vdubjetta02 View Post
    What would the approximate cost be to get the chain guides replaced under preventative maintenance?
  34. #114
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Justincredible View Post
    More specifically, letting the OIL warm up before applying a lot of engine load. The oil needs another 5-10 minutes of driving after the coolant (temperature) gauge stabilizes in the middle.
    Using an oil with a high viscosity index and higher ester content will assist in quickly pumping it and assuring you maintain a good film on all parts.
  35. #115
    Jul 04 2011
    Minneapolis, MN
    Quote Originally Posted by Black3.2 View Post
    Depends on the shop. I was quoted $4500-$5000 from a high end euro performance shop. Around $8k from a dealer. You probably can get it done a bit cheaper but I wouldn't trust that job to a 1st timer.
  36. #116
    Jun 02 2009
    Atlanta
    would there be other things to get done at the same time, such as clutch, flywheel, motor mounts, etc... and anything else that you can add to the list? Much appreciated.
  37. #117
    Established Member Two Rings audi _4 _life's Avatar
    Apr 17 2010
    V70R/Z71 Tahoe/S4
    newport vermont
    Just bought my S4 2 weeks ago 1 owner car. 3 motors First motor lasted until 98,000 miles was using oil bad. about a quart every fill up. Then the second motor lasted 2000 miles and was burning oil even worse. I have 114k on it and does not use oil at all. Glad Audi foot the bill 16k for each motor job.
  38. #118
    May 06 2009
    2004 Audi S4 Sedan (automatic)
    Virginia
    Quote Originally Posted by audi _4 _life View Post
    Do you mean that the prior owner replaced the motor twice? You certainly didn't have to replace the motor twice in the last two weeks :)
  39. #119
    Apr 24 2010
    Teh!cks-us
    Quote Originally Posted by Black Leaf View Post
    For sure he didn't cover 16,000 miles in two weeks. Perhaps they did not replace a faulty PCV valve the first time around. I can't see a new engine having that trouble unless the owner beat the snot out of it. Possible, though, that he/she/they did tear it up, for some reason hoping to get it warranteed before their 100k warranty ran out?
    -Jason
    LifeWithSquid
  40. #120
    Apr 17 2010
    V70R/Z71 Tahoe/S4
    newport vermont
    I Bought the car with the motor replaced. The guy that i bought it off of gave me every record on the car. I even have the miles every time he put oil in it. First motor went because of a broken tensioner and that caused the cylinder walls to score. The second one i never looked to see on the repair order to see what was causing it to use so much oil. I will do that and report back.
