Page 1 of 9 123 ... LastLast
Results 1 to 40 of 339
    Established Member Two Rings Matteeee's Avatar
    Sep 29 2009
    Malmoe, Sweden
    B5 lowering caps on my B7 to even out the stance
    Audi A4 B5 lowering caps. Audi part number: 8D0-412-103-B
    Before
    Before
    Getting started (note the grilles in the background!)
    Difference from B5 to B7 (B5 to the left)
    Almost done
    Done!
    Pic of the result
    /Matteeee
    A4 2.0TSq Avant -07 Dolphin grey S-line
    http://www.garaget.org/?car=169717
    Veteran Member Three Rings audib7maniac's Avatar
    Oct 23 2009
    New York, NY
    need moar low
    Junior Member One Ring gawa's Avatar
    Dec 20 2006
    Toronto, Ontario
    looks good!
    Jul 15 2010
    Minneapolis, MN
    Where is the best place to purchase these? I can't seem to find them online.
    Mar 26 2007
    Colorado
    its better than before....but going down another 3/4" both front and rear would look perfect
    CURRENT:
    2021 Atlas
    Active Member Two Rings supertob's Avatar
    Sep 24 2008
    Audi A4 2.0t Quattro - 2005
    Stockholm / Sweden
    Snyggt!
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Where to buy the B5 caps? I've been looking for these for long time
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Oct 29 2009
    Sold - 06 b7 2.0T a4 avant quattro
    Kitchener, On. Canada
    Quote Originally Posted by shiro1745 View Post
    dealership...they aren't very pricey...I also have a set on my avant...my measurements were about 25.85" in the front and 25.9" in the rear
    Sold - 06 B7 A4 2.0T Q6MT avant - BB
    Mods:Uni stg2 HPFP 91oct, KMD HPFP, ER SMIC's w/034 hoses, 034 TIP, 034 HFC, Custom quad-tip, a4 sport suspension, RS4 rear sway, RNS-E, RS4 carbon trim pedals & shifter, S4 Recaros, AWE vent mount boost gauge, Black RS4 look grill, Votex front splitters & side skirts, Ti window trim, S4 mirrors, LLtek LED headlights, DDM HID Fogs, Black 19" O.Z. Ultraleggera
    Jul 26 2009
    DMV Area
    thanks
    Jul 26 2009
    DMV Area
    Anything that goes lower than B5 caps ???
    Veteran Member Three Rings CystmX's Avatar
    Feb 04 2010
    Andrews AFB, MD
    Coilovers.
    Sep 29 2009
    Malmoe, Sweden
    Quote Originally Posted by CystmX View Post
    Coilovers.
    ..or lowering springs... or bags :)
    But these aren´t for going low - these are for evening out the stance between front and rear...
    /Matteeee
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    so this is stock s-line suspension with B5 caps?
    Sep 29 2009
    Malmoe, Sweden
    Quote Originally Posted by NODO-GT View Post
    Exactly!
    /Matteeee
    Nov 03 2008
    Durban - South Africa
    wow, exactly what i need. see if the local dealers have this
    Apr 18 2008
    Jacksonville, FL
    will this work on the stock 4x4 suspension?
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Senior Member Three Rings rick1.8t's Avatar
    Jun 15 2007
    2007 Audi A4 S-Line, 2003 Audi A4 GTRS
    Hillsboro, OR
    DIY?
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    Quote Originally Posted by rick1.8t View Post
    DIY?
    x2
    2008 Audi A4 S-Line/Ti 2.0T Quattro
    2003 Audi A4 1.8T Quattro (crushed by tree)
    Jun 23 2008
    Boston, MA
    Not sure what OP paid but ECS has them for $55 each.
    http://www.ecstuning.com/Search_VW/8d0412103b/ES252652/
    Jun 23 2008
    Boston, MA
    Are your RS4 reps 18 or 19"?
    Edit, nvm. I see the r19 on the sidewall!
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    What does your suspension feel like on the road now? Is there any difference?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Sep 29 2009
    Malmoe, Sweden
    I followed this DIY: http://forums.fourtitude.com/showthread.php?2637475
    Some of the mm-dimensions are not correct, but if you have 16-19mm plus 13mm key you will be fine :) If it is 3/8" or 1/2" socket does not really matter.
    The suspension feels as before, I have not yet made a 4 wheel alignment which I plan to do, even if it might not be needed.. The main thing would be looks, not performance. Still worth it though =)
    /Matteeee
    Sep 29 2009
    Malmoe, Sweden
    Quote Originally Posted by minameismud View Post
    Yes, but you will only decrease the front height by ~15mm (~0,6 inch)..
    Quote Originally Posted by JayStang View Post
    They are VMR V708 Onyx Black 8,5x19" ET38 with 245/35-19"
    /Matteeee
    Jul 26 2009
    DMV Area
    will these work with a BILSTEIN shock? I just lowered my car on H&R / Bilstein and the front screams to go a bit lower. This I think would be perfect. Anybody using my setup with B5 caps?
    Mar 12 2008
    New York
    Yes, the caps will fit bilstiens and stock sport shocks. I know another poster a while back ran into a problem bc he was trying to mount them on Koni's. I believe the issue, if I remember correctly is that the Koni shock body is to wide.
    Veteran Member Three Rings Mr. Merk's Avatar
    Sep 20 2007
    1988 911 Carrera 3.2
    NW Arkansas
    our car has this and it tucks tire in the front, too low
    you want to sell us your stock caps?
    13 S4 3.0T | Her daily driver
    88 911 Carrera 3.2 | My fun car
    87 S-10 383ci drag truck | Her fun car
    05 Sierra 5.3L SLT Crew | My daily driver
    14 Jeep Wrangler Rubicon | Her other fun car
    Jul 26 2009
    DMV Area
    Quote Originally Posted by Mr. Merk View Post
    I guess this was for me. Do you have a picture of the front to see how much lower than mine is? Bilstein came with caps. I still have all the stock suspension, I'm not sure if to sell it or not. I would only sell it as a hole package. I don't want to sell the caps separate.
    Sep 20 2007
    NW Arkansas
    i dont have any pics yet, waiting to do a shoot with our b5
    Sep 20 2007
    NW Arkansas
    and actually i was speaking to the OP, but anyone who has the stock caps would be fine
    Veteran Member Four Rings Koby's Avatar
    Aug 05 2008
    Easton, PA
    That's a very useful half inch
    Sep 29 2009
    Malmoe, Sweden
    Sorry, I dont have them anymore - threw them away... And still, Im in Sweden, making freight cost too much i guess.
    But some more on here have the B5 caps, and maybe they have some B7 caps laying around..
    /Matteeee
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Quote Originally Posted by jmars View Post
    All konis? I have the FSD's and I'm looking for another 1/2" of low. Nm - discovered that they don't fit FSD's.
    Last edited by billyhoyle; 10-25-2010 at 09:04 AM. Reason: They don't fit Koni's...damn
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Sep 20 2007
    NW Arkansas
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    I have stock caps...want to trade your B5 caps for mine??
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Sep 20 2007
    NW Arkansas
    only if you could send them to me first, she drvies it daily
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    I am going to be doing this in two weeks. If someone still wants the stock ones pm me. Great thread. Appreciate the pics and measurements.
    Jan 22 2007
    Fontana, CA
    How much are you guys paying for the lowering caps?
    -Anil
    Sep 02 2009
    Layton/Utah
    Quote Originally Posted by Sly Raskal View Post
    I will let you know tommorrow how much they are gonna cost me. I have a good hookup at the dealer.
    Jul 26 2009
    DMV Area
    Thanks for the picture. I will probably do this when I'll have time. Any rubbing at all with the B5 caps?
