Results 1 to 40 of 45
    Established Member Two Rings AudiS2's Avatar
    May 19 2009
    2000 Imola S4 and 1995 Audi 90q with VR6 turbo swap
    Audi 90 VR6t Project
    Well here it goes...Car started to get dismantled on this past Monday...The car is at AMS Autowerks in Linden, NJ and they are making great progress on the car...They are trying their hardest to get it all done to bring down to Waterfest this year...I will try to post as much pics as I can of the progress, so here it goes.
    First off, picture of my car
    Dismantled motor, Block
    Pic of motor with manifolds before accesories
    Painted block and Adapter plate
    Flywheel
    Attached wastegate vband directly to manifold
    Beginning of shaved engine bay
    May 19 2009
    Here are some quick specs...It is a 12v VR6 motor...Only did a head gasket and ARP head studs otherwise motor is stock...Running a Precision 6262 turbo, snow performance water/meth stage 3, southbend stage 5 clutch, intercooler, and much more.
    I will take pics of all the parts and post them up later. Hope everyone enjoys the build!
    Established Member Two Rings mhorsfield89's Avatar
    Dec 02 2008
    Durham, NC
    damn lol that is big turbo - what are your plans with the car? your 90 looks very clean too - good luck with it
    Oct 14 2006
    west coast
    looking good, What are you planning on doing for engine management? I have 2 friends that are running similar set ups (one in a 4k, one in a cq).
    Sep 12 2008
    South Central PA
    this is the shit
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    i saw this car back in decemeber at the shop, real clean bro!
    May 19 2009
    Thanks for the comments...
    mhorsfield89 - As far as plans for the car, I just plan to show the car and race it every so often...But I am not doing the 6 speed trans swap yet and I do not know how good my trans holds power, so I will not be launching the car hard for a while
    ruffiano - For engine management I am going to use the 034 IIc standalone. How are your friends cars doing so far?
    I have a couple of questions maybe you guys can help me out with. Does anyone know how well my trans holds more power? 95 audi 90q sport. And I know now that there is a VR6 swap in a 4000 and a 90 coupe, but do you know if anyone has done this swap in a B4 yet? Or for that matter any 90 4door?
    I should be posting some new pics later tonight
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    One of my dream combinations! Can't wait to see results on this.
    You'll likely find the transmission won't together for too long if you plan to make big power. You'll want a 5 or 6 speed 01E likely. This requires additional parts, but is going to be the most reliable way to put the power down without issue.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Aug 07 2008
    Nashville
    Might want to check out MG for other VR6 projects, it should be full of them
    Jan 18 2010
    Jupiter/Gainesville, FL
    Yeah, there are a few VR6T's in coupes, 90's, etc.
    I LOVE yours though.
    The tranny is going to be an issue for sure. They don't hold up so well. 016's from the 200 20v is a good substitute up to about 500awhp and then the next best thing is a wide first 01E. Those are your options.
    200 20v - custom coils, big brakes, 67mm turbo :)
    '94 530i MT
    Established Member Two Rings quattroderrick's Avatar
    Apr 14 2009
    2005 GLI
    Lake Stevens, WA
    Awesome project. We are thinking about doing this swap into my brothers 5k. Trying to decide between VR6T, 2.7TT or VR5T. So I'm anxious to see how this turns out for you. Good Luck
    1993 UrS4 | Pearl White | Stebro | Samcos | 2B Coilovers 400/500 | 2B Camber Plates | CF Trim | Euro S6 Taillights | S6 Sport Wheel | Apikol 2.0T coils | IA Stage 3 | SS lines | Delrin Subframe Bushings | Apikol Snub | 034 SD Trans Mounts | DDM 55w 6000k HID | StopTech BBK | Rear BBK | Euro Lenses | Clear Corners | Black Interior swap |
    On the bed: S6 Rear sway, Euro S4 taillights
    Wishlist- Full GT35/40R with VEMS build.
    May 19 2009
    Thanks for the comments...Here are some more pics
    Turbo
    Oil Cooler
    Intercooler
    Primered Engine Bay
    Jul 10 2010
    harrison
    nick your car is looking great!!
    Registered User Two Rings
    Dec 28 2008
    05 Cayenne Turbo, 84 UR Quattro,2002 Allroad 6mt,1998 993tt,99 CBR 900rr
    Linden, NJ
    Quote Originally Posted by brazilianfil88 View Post
    and because of this car i have not slept for a week,working on it right now on this beautiful sunday, and will be not sleeping this coming week to get it done in time for waterfest :)
    Oct 14 2006
    west coast
    Quote Originally Posted by loxxrider View Post
    the tricky part for this car to go 01E is final drive. the b4s were 3:89 instead of 4:11 like the 01Es, that means you have to figure out different rear diff... that gets tricky.
    May 19 2009
    Heres an update....taken just a couple of hours ago, right before the motor was pulled out again, so that the engine bay can be painted.
    Oct 14 2006
    west coast
    looks like there is sooo much room!
    Jan 10 2010
    B6 Passat
    Nassau County
    Nice
    Drive low, park lower
    Aug 07 2008
    Dallas, TX
    Massively jealous of this project. Looks so nice and tidy in there. Been talking about this swap with a friend of mine for years since I had my first ride in a Mk2 Jetta Coupe with a VR6t, that VR noise, the power out of a stock block on even just a rising rate fuel pressure regulator and a crummy tune was plenty big, halfway decent power off boost and all he needed was traction which the 90q is going to provide plenty of. Seriously cool setup.
    www.europrice.us
    [email protected]
    May 19 2009
    There is a lot of space, but fitting the 3.5 inch downpipe was nice and tight...but having to work on the motor in the future should be easy...VRs are def great motors and I am real excited to get this thing driving...I have never owned a VRt but I have been in a couple and the are def tons of fun...and like you said you throw quattro in there and its got to be amazing
    Veteran Member Three Rings SCuattro NYC's Avatar
    Feb 04 2010
    '04 A4 Avant 3.0 Dad Ride
    West Orange, NJ
    I was actually at the shop when the original engine was pulled out. Came back 2 days later and saw the guys sanding the bay for painting.. Sweet looking ride and its definitely coming along. Love the Porsche seats as well..
    Current: '04 Atlas Grey A4 Avant - Bone Stock, for now.
    Sold: 04' Arctic White S4 - Slight Mods.
    Aug 07 2008
    Dallas, TX
    Yup, this will be a great package. 3.5" downpipe is a serious stretch even with a 20v turbo which was made to fit into that space. I'm pushing my buddy with a slew of VR6t's to make either a 4000, 90 or A4 VR6t and get some traction over his Jettas,
    www.europrice.us
    [email protected]
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    I saw this car on Tuesday.. AMS do great work..
    Nick- Is the car ready for Tomorrow?
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    May 19 2009
    Unfortunatly, the car won't be there Saturday but Sunday should be good
    Jun 10 2010
    looks good...
    Registered Member One Ring Stash's Avatar
    Aug 18 2009
    Nurburgring
    nice! good luck with the project and lookin ff to see it in action... id use 5cylinder tho
    Veteran Member Three Rings Mcstiff's Avatar
    May 11 2007
    2018 XC90
    Erie CO
    Quote Originally Posted by Stash View Post
    Quote Originally Posted by URQguy View Post
    When is the last time anybody here made 550whp on a bone stock 8v, 16v or 20v motor picked off the junkyard floor for 60 USD? I have yet to find a 20vt for that coin, yet I saw 3 of them with under 100k miles already pulled on the floor hte last time I went to the junkyard. All I would have to do is put them in a back of a truck and drive home. I use the lower aluminum pieces as a base for intake manifold I make, and it is always a good feeling when you just have to bend over, loosen a couple of allen bolts and remove the parts on the ground. :) I have seen VW FWD guys come to track days with a spare 12v in the back of the trailer in case the unthinkable happens. They swap them out in a couple of hours and keep motoring. When I lost a 20vt piston due to a faulty injector, I almost commited suicide. If it was a 12v, I would have not been in deep depression for 2 months, and simply would have swapped in a new motor :)
    I love the I5 as much as the next guy. I got a 550whp version in my URQ, and and a few in other cars. That said, the VR6 is a cheaper way of getting to 550whp. You can do that on stock internals, a head spacer, headstuds, a cheap ATP 200$ cast manifold and a 35r.. People do it all day long in FWD cars. For every 500whp I5, there are a dozen 12v vr6t cars, and 3 24v vr6t cars. They may not have their place in competitive road racing, but they are a sweet motor for a street car. There is a replacement for displacment in turbochargers, but there is not a replacement for displacement plus turbos. They are a heavy engine, and the bias does get pretty extreme in small chassis cars that weigh only 3000 pounds. The CQ is heavy though, and the weight is not as significant. I think a URs6 avant with a healthy 12v making 500whp would be a great daily driver.
    Both engines give me goosebumps at WOT, although I like the i5 at 8500 a bit more. Idle, and below 5000 goes to the vr6t though.
    The vr6 is easy to work on too. There is a ton of space everywhere, the ability to put a Front mount radiato and IC, and cheap aftermarket.
    If it was not for the adapters and fabrication required I would be tempted to grab one and save my 7a for building later; same for a B4 90 or C4 (well maybe a V8 in a C4).
    Aug 01 2010
    Lafayette, CA
    Hey guys. Don't know if anyone is interested, but I have a black 1994 90s for sale. 5 speed, greyish cloth interior, only 127,xxx miles, clean title. It's a bit of a project car considering the last owner didn't take very good care of it and I don't have the income to give it the love it deserves. If you're interested, pm me and I'll tell you more about it and send you pictures. Asking $1500.
    Jan 22 2009
    96 A4 2.8QM 206k strong...
    The Bia East Side
    Any updates?? Car looks hawt btw..
    Chuck Norris does not wear a condom because there is no such thing as protection from Chuck Norris.
    Dec 12 2006
    Charlotte,NC
    Love this car, makes my 90q look like crap lol
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Senior Member Two Rings urs4kid's Avatar
    Nov 21 2009
    mesa, az
    i want to see moreee!
    Nov 21 2009
    mesa, az
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    What hotside are you using for your turbo? I am doing a VR swap in my B5 S4, I am using a 24V that is going to get pushed to 3.0l. I have a 6765 with a .96 t4 housing. I have been thinking about going smaller.
    Nice to see that you are doing this congrats.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Updates?
    Jan 30 2007
    a bunch of tools
    Monument, CO
    What happened with this?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by nefkntym View Post
    Yeah. It looks like an awesome project. My friend is putting an I5 20V into his 90.
    -Doug
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    he updates his motorgeek build thread, guess az just doesn't have a big older audi following
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by NeedingAnAudi View Post
    Mind providing a link?
    -Doug
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    all projects, all way cooler than most stuff on here.
    http://www.motorgeek.com/viewforum.php?f=6
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Mar 16 2009
    Valparaiso, IN
    ^^ Speaks the truth, you can get lost in the amount of cool builds that are on that site.
    Alex
