Originally Posted by
joe@vwvortex
With the ability to get 800hp using the Ypipe and a MAF - what is the incentive to create a MAFless tune without a Ypipe? I'm asking this seriously.
Well, AMD is making almost 700whp on the 770r car with log manifolds... Does that mean log manifolds are awesome and need no replacement? No. And what do you think the hp increase would be with individuals? Seriously, if you can make 800hp with a ypipe you could probably make 850 w/o it. That Ypipe is going to get so massively heat soaked after just 1 pull on an 800hp setup. How about you do this. Go do a pull on that 800hp setup, then do another one back to back. Then replace the Ypipe with twins that route to the front airdam and do 2 more back to back pulls and tell me where you're at.
Here's your incentive. The more power you can make without adding boost the longer your setup will last because less boost = less heat. More heat = less longetivity.
Normally I wouldn't even say anything I would just do it myself but I'm going vr6.
