Has anyone tried to remove the intank pump from the plastic housing without breaking anything????? If you did how did you do it??????
vizi
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
'05 A4 2.0T Quattro MT APR Stage 3
2008 APR Holiday Giveaway Winner!! Thanks APR!!
FRRG Southern Ring
Xbox Live ID: Sqzn2zz
FRRG Southern Ring
2006 Audi2.0T quattro Tiptronic
APR Stage 2+
OEM+
_______________
2013 Passat TDI
