Page 1 of 40 12311 ... LastLast
Results 1 to 40 of 1569
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    05 A4 USP Avant, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Arrow The Build - A GT2871R build documentary
    Well today was the day all the magic started. And since I was unable to post this in the projects/builds section......you guys are stuck with me putting this here.
    I have been stock-piling pieces over the winter in anticipation for this day. After MUCH deliberation between keeping it simple and going with a cookie-cutter setup GTRS with Revo, I decided that if I'm going to spend this much money and effort.....why build a setup that will always keep me wondering "what if." Not to mention the fact that there isn't a single aftermarket high-flow OEM replacement that doesn't crack. I've ready about too many horror stories of installs and cracking etc. I didn't want to go that route.
    So I guess now is the time where I lay out all of my info. Unless otherwise noted, parts will be from OEM AMB engine
    Software: Eurodyne Maestro7 custom tuned by me
    Injectors: Siemens 630cc Now using Injector Dynamics ID725
    Fuel Pump: "005" from 034 Motorsport
    MAF setup: Audi S4 4.2L MAF
    Turbo: Garret T25 GT2871R w/.64AR. Internal wastegate, Ø2"outlet, and Ø3" inlet
    FMIC: Racetec
    DV: Forge 007
    Oil lines: Braided stainless -4AN feed, -10AN return
    Coolant lines: Braided stainless -6AN
    Manifold: PSi Concepts T25 manifold
    Testpipe/Downpipe: PSi Concepts Ø3"-Ø2.5" prototype testpipe (will be replaced with a production run unit), Milltek Ø2.5" Downpipe
    Exhaust: Milltek catback
    Intake: Ø3" aluminum inlet
    Engine internals:
    Integrated Engineering connecting rods with 19mm wrist pins
    New rod bearings
    New crank bearings
    ARP head bolts
    ARP main studs
    ARP crankshaft bolt
    Engine/trans:
    034 Motorsports Street Density engine mount
    034 Motorsports Street Density transmission mount
    Clutchmaster FX300 w/240mm Billet steel flywheel
    Nov 29 2005
    Edmonton, AB
    And now for the goods.....
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Awesome. Subscribed for a great setup that I would love to have.
    USP CLUB MEMBER #71 BetaAlphaTau Member #16
    tumblr
    Saint Cloud, Fl
    subscribed for more dope photos
    Nov 29 2005
    Edmonton, AB
    Welcome aboard, kids!
    Senior Member Four Rings nein-reis's Avatar
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Nice! Looks like you have the energy to do a build AND take photos worth something? Awesome, thats more than I can say... mine were so snap-shotty after I was done working.
    -Tyler-
    IntegratedEngineering - Bulletproof your engine.
    /GT3076R/Eurodyne M7/6MTQ
    AEB/IE Cams/Supertech train/2.0 stroker
    Active Member Two Rings Rejmow's Avatar
    Apr 24 2010
    Audi S4 -94, Audi S6 -97, Merc c220 -02
    Sweden
    Setup looks cool Subbing because you have a dope camera !
    ___________________
    (___)==OOOO==(___)
    _\_(==========)_/_
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Sexy pics!
    Chris, you *may* want to consider going to a S4 MAF. From what I've found in the past, I managed to max out the VR6 MAF (which maxes out at 229g/s) on a race tune with just a GT28RS. Though you can scale the g/s readings on the tune, the MAF signal is way too close to 5vdc (your MAF reads 0-5vdc) at 4.2vdc. Though this will still work, having the MAF voltage at that high will cause it to burn out much sooner.
    Just a thought. :)
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    I wish you the best with getting the MAF to work. Chris (bananas) is trying but with limited success. Probably in a couple of months CTapp will have the MAF scaling figured out [I hope] within Maestro.
    Which S4 MAF Jeff? Different housing or housing and sensor?
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    Finally you spilled the beans Chris! Take a picture of your old pistons when you've taken things apart.
    Senior Member Four Rings kneel's Avatar
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    wow sick avant and a sick turbo build!
    Neil_
    2003 Atlas Gray Avant w/ REVO STG.3
    PSi Concepts 20g Turbo..... Baby Recaro Seats!
    PODI
    Dubs on Defrost 5 - April 7th, 2012 - Westport, CT
    Stage 2 Banner Advertiser Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Linden, NJ
    Only you could take a dirty job (turbo replacement) and make it look beautiful. Nice work!
    Matt Kapuscinski
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 201.777.0005
    Email: matt@europaparts.com
    Twitter: Specials & Discounts
    Help us track our Audizine sales: Enter "MATVEJ" at checkout
    Senior Member Four Rings itsmatt33's Avatar
    Jul 14 2009
    Pasadena
    this is the tits
    Revo stage 2.TT225 injectors.Forge splitter.VMR test pipe with heat shield.ER Comp FMIC.AWE exhaust w/ down pipe.HP2 brakes. Stern Snub Mount.Clutchmasters FX400 240mm Steel FW.AWE boost gauge.S4 Seats.Euro Light Switch.LED Interior.Brushed Trim.5% tint 54% windshield tint.Black grills with sliver paint match rings.single ecodes(6k).Hoen fogs.Rdash plate LED.USP Front bumper.S4 rear bumper with black valence.DTM skirts.Oettinger RS.RS4 sway Bar.Stasis SS coils.19" VMR V710
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by Matt@EuropaParts View Post
    I know right? I was like "Wow that's pretty... Wait, what? I hate spilling coolant!"
    Senior Member Four Rings AudiA4Turbo22's Avatar
    Dec 06 2007
    '03 Audi A4 1.8TQ Tip, '08 Mbz ML550, '10 Mbz S550
    AWESOME! when will it be done?
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    This is all wrong.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Nov 29 2005
    Edmonton, AB
    So excited to finally have this project started! I've been wanting to do this for 5 years!
    Steve I plan on taking photos of EVERYTHING :) That's how I roll..... So tonight I'm hoping to snap a few photos of some more goodies as well as possibly the manifold. I get off work at 5 tonight and hopefully should have a hoist by 6. The engine will be out tonight and hopefully I'll be able to start working on the rods and rings.
    I would like to have the motor back together and ready to be fitted back in the car on Saturday......but who knows. I spend over 30 mins yesterday fucking with the lower coolant hose and heater core tubes. lol.
    Dec 03 2005
    connecticut
    A little silicon grease on the o-rings within the coolant line connectors and they will go back on easy and come off next time even easier. Use on all o-rings.
    Unbolt the a/c compressor from the engine and you can rotate the compressor and condensor to the passenger side, out of the way, with it all connected. No need to loose coolant.
    Unbolt the power steering pump (bolts are though those three holes in the pulley) and place that on the driver side frame rail. No need to loose power steering fluid.
    -Doug
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Chris, glad to see the official unveiling :) We'll be in touch, I'm sure.
    I've got it mostly figured out now. There might be issues with clipping beyond some value, but I haven't run across it yet with my turbo/sensor/housing. Super easy now, enter your MAF size, choose a starting point, and it gives you the scaling and offset values for Maestro: http://spreadsheets.google.com/ccc?k...ORGdnNXc&hl=en
    Also, I agree with Jeff, go bigger than TT225 housing if you can. Check the "normalized data g/sec" tab in the spreadsheet linked above for voltage->g/s mappings.
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Nov 29 2005
    Edmonton, AB
    The AC condenser is already unbolted and sitting on the passengers side.
    The power steering pump, however, is still on the engine and the lines are drained. I needed to drain it anyway to get the cooler out from the rad support.
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by bananas View Post
    We'll be in touch for sure. Haha. I'm going to need a few pointers from the people that have been messing with Maestro for a bit. All I've been able to do is open it up and look around so far. I haven't actually learned anything yet.
    As for the MAF housing.... the VR6 MAF is going to have to do for now. I need my car back ASAP because I have shoots coming up. I'll figure out the MAF situation once I get things up and running with the parts I have. PS.... being able to swap MAF housings whenever I want is EXACTLY one of the reasons why I didn't go with Unitronic or Revo. I can make the changes myself. No BS with dealers or shipping ECU's.
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    03-A4||08-X5||01-///M3
    Good luck with the build! Looks great so far
    2003 A4 QM EFR 6758 on meth
    Dec 03 2005
    connecticut
    Quote Originally Posted by MmmBoost View Post
    But its still connected to the a/c compressor. You are removing the motor right? Then remove the a/c compressor and move it all to the side.
    -Doug
    Nov 29 2005
    Edmonton, AB
    Yes it's all still connected. You can see it off to the side in the 3rd last photo. I didn't want to have to have the AC recharged at the stealership.
    Senior Member Three Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Thanks chris. I often day dream of having the fastest B6 in Edmonton. That is unlikely to happen now. You destroyer of dreams!
    Kyle
    2004 a4 1.8tq 6MT > I got a turbo, and a bunch of other shit.
    Jun 21 2005
    B6 Avant
    ^lol. Just go with a slightly bigger turbo.
    Senior Member Three Rings teg2audi's Avatar
    Apr 23 2008
    2004 Audi A4 1.8t
    Portland, OR
    Can't wait for new pictures and eventually the finished product!
    Black 04 Audi A4 1.8t
    APR Stage 2+, tt injectors, forge 007, South Bend OFE Stage 3 Clutch, APR Snub, Podi, Test Pipe
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Nov 29 2005
    Edmonton, AB
    Day 2: Complete
    Well I certainly didn't make as much progress as I would have liked......but that's how things go. I work in an engineering department....... I know for a fact that NOTHING ever goes according to plan. haha.
    I got hung up on the engine/transmission bolts for a lot longer than I had anticipated. They were SO tight. Every single one needed a love tap from a dead-blow hammer to crack it loose. I also had to fab up a couple of brackets for my engine stand because the neighbor I borrowed it from only had two. I certainly didn't feel comfortable supporting my entire engine on only 2 bolts.
    So after struggling with the engine bolts the motor popped right out. I'm trying to removed the wiring harness in some sort of an order. The engine seems to have been leaking like crazy from the cam chain tensioner. There is also a pile of caked on oil from when my valve cover gasket was leaking before I changed my timing belt.
    After inspecting the K03.....the bearing are definitely pooched. After removing the clutch......the clutch is also pooched. So at least I have SOME justification for my madness and empty wallet.
    Enjoy the photos from today!
    As promised.....some shots of parts from PSi
    Prototype testpipe. Will be replaced with a pretty production unit.
    The engine stand brackets I had to make.....
    What a gong show of hoses and lines!
    The obligatory K03 vs BT comparison shot.....
    My fried clutch
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    NICE!!!! Best build photos ever. When did you have time to work on the engine framing all these photos up? Very cool stuff Chris, excited to see where you are saturday.
    -Tyler-
    Nov 29 2005
    Edmonton, AB
    Awww......shucks.....
    It's hard to not shoot when something interesting catches my eye.
    I don't think I'll be finished on Saturday like originally planned. At this rate I may have the engine back in by Sunday? Monday?
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by nein-reis View Post
    X2. I wish I had my DSLR during my build.
    Since your turbo is internally gated, do you just use a block off plate on the exhaust manifold to close off the external wastegate port?
    tumblr
    Jun 21 2005
    B6 Avant
    Damn, Chris. You work fast especially when you're taking wedding photos of your turbos etc. Are you going to cap off the wastegate flange on your exhaust manifold? Your testpipe doesn't have a provision for a wastegate dump.
    Senior Member Four Rings Turbavanttro's Avatar
    Jan 24 2008
    Lift, tools, B6 Sportec Avant, Saab 900 Carlsson
    Pennsylvania
    ^curious about that as well.
    Your build is really looking good. I love the manifold choice. I'm going to guess you'll be done in 2 weeks. There must be a plethora of gaskets/hoses, etc. you can do right now while its all there in front of you, not to mention the engine bay detail opportunity you have~
    Ands you can shoot more fantastic photos for us~
    Jan 24 2008
    Pennsylvania
    Are you considering having your manifold/turbo/compressor coated? A car as pretty as yours seems to deserve as much....
    Dec 03 2005
    connecticut
    Quote Originally Posted by SleeperAvant View Post
    His turbo is internally gated, he just doesn't have the actuator installed yet. Therefore, I presume, he'll bolt on a cover for the WG port on the manifold.
    I second.
    I REALLY like these photos for some reason:
    SO cool.
    The caption, angle, lighting, color contrast completes this image.
    The contrast rules.
    -Doug
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    wish i had your picture taking skillz...
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Senior Member Four Rings BEESIX's Avatar
    Nov 06 2007
    B6 A4
    The Windy City
    were almost in the same boat, awsome stuff man!, pics are amazing,
    i was going to go with the psi concepts manifold but i was scared to try something new so i went with atp lol
    2002 White A4 1.8T 5MT Fronttrash with a few goodies
    Premier MotorWerks,
    2494 Oakton St, Evanston, IL
    http://www.facebook.com/profile.php?id=100001076103808
    ^ This is what i do^
    Adil
    Sep 12 2008
    Quote Originally Posted by BEESIX View Post
    i went with atp
    fail.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Nov 06 2007
    B6 A4
    The Windy City
    ahaha itll be fine with a strong turbo support brace
    Premier MotorWerks,
    Adil
