The short story. 2008. Stage 3. VAST. Prince. Mike. Michigan. Neil. Milwaukee. Awesome. Misfires. WTF! CEL? WTF? New program. Cool. Misfires!! Help! Again. Neil. Cool! Loving. Life. Summer. Base file. 12.2@116mph. Pump gas. VAST! 2009. Winter. Hit. Pot hole. Shit. Totaled! Sell parts. Prince. "Dude...Race Car!" Me. "Hey honey, do you care if I build a race car AGAIN? It won't cost THAT much?!" Wife. Says. Yes. America! FUCK. YEAH! 034. Javad. Issam. Dan. VR6! Conversion? What!?! Damn. I. Need. That. Shit. In. My. Life. Must. Pull. Engine. And. Trans. Leng! Keng! Two brothers. Milwaukee. Hell. YEAH. Transmission. Rebuild. Local. Ben. Import Automart! Fabrication? Local? Jon. Best friend. Yes! Waiting. On. Parts. Took. Forever. 2010. Here. It. Is.
Build Sheet Info:
ENGINE
AAA 12V VR6 OBD2
JE FORGED PISTONS 9:1 COMPRESSION 82MM - POLISHED TO REDUCE SURFACE AREA AND CARBON BUILD UP
EUROSPEC FORGED H-BEAM RODS WITH ARP 3/8" ROD BOLTS
ENGINE BLOCK OVERBORED BY 1MM (2.9L)
BALANCED ASSEMBLY
POLISHED CRANKSHAFT JOURNALS
JOURNALS LINE HONED
CLEVITE OVERSIZED MAIN BEARINGS
KING OVERSIZED ROD BEARINGS
ARP MAIN STUDS
ARP HEAD STUDS
MLS HEAD GASKET
02 INDUCTION STAGE 3 PORTED AND POLISHED CYLINDER HEAD WITH PORT MATCHED INTAKE RUNNERS AND PORTED AND POLISHED EXHAUST RUNNERS
1/2" PHENOLIC SPACER WITH DOWEL PINS - PERFECTLY ALIGNED TO INTAKE AND FACE OF CYLINDER HEAD - TOTALLY SMOOTH!
BORG WARNER S400SX3 (S475) TWIN SCROLL T4 TURBO 101MM EXDUCER W/ 02 BILLET ALUMINUM MAP WIDTH ENHANCER
TWIN TIAL 38MM BILLET WASTEGATES WITH 02 BUILT SS 1.5" LONG TUBE ATMOSPHERIC DUMPS
TIAL 50MM BILLET BLOW OFF VALVE WITH STAINLESS FLANGE
02 INDUCTION CUSTOM AIR TO WATER INTERCOOLER WITH HAND FABRICATED END TANKS
CORE SIZE 11X7X6.5 (500.5 CUBIC INCHES)
02 INDUCTION BUILT HOWE FULL SIZE HEAT EXCHANGER WITH CUSTOM END TANKS
SPEARCO WATER PUMP
02 INDUCTION 3” OUTLET ALUMINUM INTERCOOLER PLENUM WITH COOLANT TANK
80MM NISSAN Q45 THROTTLE BODY (MODIFIED)
02 INDUCTION EQUAL LENGTH ALUMINUM LARGE PLENUM INTAKE MANIFOLD
02 INDUCTION CUSTOM EQUAL LENGTH 304 STAINLESS TWIN SCROLL TURBO MANIFOLD
02 INDUCTION STAINLESS STEEL TURBO BRACE
02 INDUCTION 4” 304 STAINLESS EXHAUST WITH DYNOMAX STAINLESS ULTRA FLO 4" MUFFLER
02 INDUCTION 4" 304 STAINLESS DOWNPIPE WITH V-BAND FLANGES
034 EFI STAGE IIC STAND ALONE ENGINE MANAGEMENT 4 BAR ECU WITH UPGRADED FIRMWARE VERSION
034 EFI PLUG AND PLAY VR6 HARNESS
034 EFI RELAY BOARD (4 RELAYS INC.)
6 BOSCH 3 BAR 210LB (2225CC) GENESIS II INJECTORS HIGH IMPEDANCE
034 EFI BILLET FUEL RAIL -10AN INLET/OUTLET
FUELAB 41402 PRODIGY 1300HP FUEL PUMP
FUELAB BILLET ADJUSTABLE FUEL PRESSURE REGULATOR -10 INLET/-6 RETURN
6 034 EFI DIS IGNITION COILS WITH CUSTOM ALUMINUM MOUNTS ON VALVE COVER
034 EFI VR6 SPARK PLUG WIRES - MODIFIED BY 02 INDUCTION
02 INDUCTION CUSTOM ALUMINUM ENGINE MOUNTS
02 INDUCTION CUSTOM ALUMINUM COOLANT HOUSING WITH REMOTE THERMOSTAT
HOWE ALUMINUM RADIATOR MODIFIED BY 02 INDUCTION
OEM MODIFIED ALUMINUM VALVE COVER
TECHTONICS 268 DEGREE CAMSHAFTS
TECHTONICS TITANIUM RETAINERS
TECHTONICS HEAVY DUTY DUAL VALVE SPRINGS
SUPERTECH 42MM (OVERSIZED 3MM) INTAKE VALVES
SUPERTECH 36MM (OVERSIZED 1.8MM) EXHAUST VALVES
OEM LIGHT WEIGHT LIFTERS
PHAETON OIL PAN MODIFIED FOR OIL RETURN PROVISION
TRANSMISSION/DRIVETRAIN
REBUILT 01E TRANSMISSION WITH UPDATED SYNCHROS AND 1-2 SLIDER
034 EFI/ EUROSPEC BILLET MOTORSPORT CLUTCH
034 VR6 TO 01E BILLET LIGHT WEIGHT FLYWHEEL
034 EFI BILLET STARTER
AUDI OEM VR6 TO 01E TRANSMISSION ADAPTER WITH ADDITIONAL MOUNTS ADDED
JHM METAL SHIFTER LINKAGE UPGRADE
JHM SHIFTER STABILIZER BUSHINGS
JHM SHORT THROW SHIFTER
034 EFI STREET DENSITY TRANMISSION MOUNTS
AWE DRIVE TRAIN STABILIZER
APIKOL REAR DIFFERENTIAL MOUNT
APIKOL REAR DIFFERENTIAL CARRIER MOUNTS
Here are some progress pix...........
