Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Thumbs up 710N DV Install (Reverse) - Pics and Tips
    Back in early Jan I installed a 710N Diverter Value and never got around to posting pics + notes. Wanted to do so now.
    Upon starting, I realized this was the first mod I ever did a few years back on my B5. Not only was it a complete disaster but I was hopelessly confused. It was ridiculous... took me forever too. Bought the part from a dealer at probably 2.5x it's online price, used no ramps or stands, somehow sliced my left hand open which bled everywhere and afterwards pretty much wanted to stalk and kill the inventor of the one time hose clamps.
    Pretty funny to think about it now, especially considering my current higher levels of knowledge and confidence in working on my A4. Okay, maybe not too much higher. We'll not get carried away here.
    So, I opted to put together a little something for those who might now be where I was back in the day (meaning this will likely be trivial and boring for some of you experts).
    I read countless threads and posts concerning running a diaphragm style DV in reverse. Have known about it for some time but never got around to looking into it till now.
    In a nutshell, the theory is that running a diaphragm style DV in reverse creates even pressure coming into each side of the DV's internal diaphragm. The results in a more efficient operation as the DV becomes more balanced. Simple enough.
    EDIT: Excellent additional info on reversed DVs from diagnosticator, post 387-398.
    But which way does it go, like, when, not reversed? Hmmm, I needed visuals. Go go PhotoChop.
    The standard install method is for the top / vac-line opening of the DV to face horizontal towards the pass side of the vehicle. In reverse, the DV is facing upwards as shown here:
    I marked my 710N with painter's tape in hopes of it showing up when installed to make this easier.
    Part #: 06A 145 710 N
    After getting the car on ramps and the skid plate removed, start working on this clamp first with a long screwdriver. (The screwdriver is basically pointing straight towards the DV... it's the apex where the two clamped hoses meet.)
    From here, fire up your Dremel and cut that bastard off. It goes w/out saying that using a soft cutting tool is a good idea in case you nick something. Try not to. And don't try to cut through the whole clamp, just the connection point where it's actually crimped. It's really easy with a Dremel. (Yes, go buy one. They're cheap. And awesome.) More serious note, protective eyewear is a must. Unless of course you like hot metal in your cornea or something, you sadist.
    Look just to the left of the Dremel's cutting tool... see how the hose clamp is dislodged a bit? That's all you need, then just Dremel a bit and work it free.
    The one time clamp on the top of the DV is not fun. Using a combo of appropriately sized needle nose pliers and that long narrow screwdriver made quick work of it though. Sorta. (ProTip: Yes, I sometimes wear batting gloves when I work on the car. They're fricking awesome.)
    At this point I realized this mod needed more quesadilla in it. Do take note of the formidable technique utilizing cheese, turkey and red bell pepper. Win.
    From here, you can start attacking the upper, horizontal hose clamp connecting the DV. Screwdriver / needle nose pliers and Dremel.
    I opted for large screw down hose clamps and cut them to match the one timers. Use of these makes installation of a DV really easy as you can use a ratchet head to screw them down nice and tight (in addition to a flat head screwdriver if need be.)
    After prepping the screw down clamps, get them on their respective hoses first so you're not fumbling around with them, the DV, piping etc. Facing the bolt-ends of the hose clamps in this manner gave me the most room when I was to tighten them. Helps a lot... especially if you have long-ass arms like me.
    Next, first attach the vac line to your new DV. Obviously this needs to be done on a bit of an angle when torquing down the hose clamp (might need that screwdriver here). I got it close, maneuvered it into place by pushing down on it w/the screwdriver and some pliers and then tightened it. Actually simpler than it looks. IMO, this is far more effective than a zip tie.
    From here, the DV needs to be wedged into the hoses and the clamps torqued into place. Pretty sure I did the horizontal one first as it was a bit more tricky for some reason. Bad pic but here you can see the ratchet driver (like a screwdriver w/a ratchet head end) on the screw down hose clamp. (This pic and the position of the DV are all screwy and was just to show the driver on the clamp.)
    So then, here's a before and after taken from directly underneath the DV. Notice in the right side pic, the blue tape on the DV demarcating a reversed setup. Obviously, if you're not looking to run your DV in this manner, opt for the setup on the left.
    Initial impressions were very positive. With the new reverse DV installed, I immediately noticed the car holding boost more effectively around and past 5K.
    I'll certainly admit no A-B test took place (new DV in, standard install + reverse install, compare) but the pre-install behavior was exactly the same as my previous B6. After the install, things felt better. So it's safe to say there is some truth in the revered diaphragm-style DV setup.
    Also, with the new DV in place the engine response was more crisp, so to speak. This could have more to do with the DV being new rather than the direction of install. However, the current one only had ~54k on it and didn't appear to be lacking in holding strength. Again, exact same behavior as by previous B6. But, there's no science to back this. Just my speculative opinion.
    It's been close to 1,000 miles since I installed this DV and I've not experienced anything negative. No fluttering, CELs, weird noise or modulation in power. Kinda bummed I didn't try this sooner as it appears to be a nice little gain (or reclaim, if you will). I would certainly recommend it, if for nothing else to try it out.
    Veteran Member Three Rings Prospect25's Avatar
    Jan 09 2010
    LoHi, CO
    Solid writeup. Especially the part about the quesadilla. Haha
    Veteran Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    B9 RS5, B9 SQ5, B5 S4
    New Jersey
    Nice write up, i forgot that those 1-time use clamps existed on my car.. I sware i have zero left, i took them all out when I replaced my check valves. I have been under my car so many times and there is some must 'custom' plumbing my car looks nothing like you picures haha. Sometimes I forget when i tell people "Just turn your DV around" that its not actually so simple
    Cheap and fast wont be reliable.
    Reliable and cheap wont be fast.
    Reliable and fast wont be cheap.
    Veteran Member Three Rings NW A4's Avatar
    Nov 17 2009
    WA
    So when you reverse your DV, it will hold more boost, is that what I am getting at? So why wouldn't they be created this way?
    Sorry just trying to learn.
    B62.7t
    Dec 01 2007
    San Jose CA
    It's safe to say my quesadilla modding skills outweigh my Audi modding skills. Still workin on that. Thx Prospect.
    Quote Originally Posted by Prospect25 View Post
    Dec 01 2007
    San Jose CA
    Yeah, good point Puff! Just reversing it can be a seriously arduous process, hence why I started snapping pics for this "little" project. It's totally one of those, right tools + technique = easy mod... and certainly the opposite if not.
    Glad you brought up check valve replacement as well. It's certainly something I'd like to do + document (as it's very related to a DV replacement) but CA emissions requirements would be violated so I'm skipping it. However, just like on my B5, I want to replace all my vac lines w/upgraded hose and document that as well. I wonder if colored line more effectively holds boost? lol If anything it'll show up in the pics better.
    Quote Originally Posted by Pufftrees View Post
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    Im liking the quesadillas
    Dec 01 2007
    San Jose CA
    Not bad questions at all. I wondered the same. First, some specifics.
    An increase in DV performance via reversal is only specific to this engine, in this model using a diaphragm style DV. This just happens to be one of those Audi quirks.
    The 710N is designed to hold more boost than the standard DV that is installed in the A4 A.8T from the factory.
    Side note, there does not appear that a piston style will benefit from this change as it has a different design, more on that in a moment. Additionally, I can not speak to this.
    EDIT: Looks like there is. Per Mike Hood, "The reverse direction is how you install the piston type valves. The pressure under the valve helps open it quicker when the pressure on top of the valve that helps keep it close reduces and becomes vacuum."
    History
    Like I mentioned above, I was familiar with this idea but wanted background as to why. Through extensive searching, I came across a few old, scattered posts that made mention to OEM DV's honking in early Audi 1.8T engines (~2000)... specifically the TT. This resulted in a TSB notice (not sure if this covered all 1.8Ts or just the TT.) which prompted a fix. Again, unsure if that TSB just required a 'reversal' or a swap. Can't find the TSB anymore.
    I do recall some B5 A4 owners installing theirs in reverse. So then, big picture, a theory is that the swap was applied across the board to all Audi 1.8T engines. After digging up some old AW posts referring to techs seeing both orientations from the factory, I figured there was likely merit to it. Who knows.
    Regardless, a diaphragm style DV can work in either orientation. Again, maybe a visual will help here.
    Grabbed my old DV and sawed it open. (the green arrows point to a rubber jacket which contains the spring and allows for movement)
    As you can see, reversal will still allow for the DV to operate in the same way, just applying boost pressure on the other side so to speak.
    The difference I noticed was nothing shocking but certainly enough to take notice. Considering there was question some years ago as to what the orientation should or could have been from the factory, this swap does merit consideration.
    Hope that helps... trying to not over complicate this too much.
    Quote Originally Posted by NW A4 View Post
    Veteran Member Three Rings AvantJunkie's Avatar
    Jul 17 2009
    Too much shit.
    Longview, WA
    Great write-up! I did this just a couple of weeks ago, and like you stated, I felt that the boost came on smoother and seemed to hold better. Cheap, if not free, mod that is completely reversible if need be.
    **Brett**
    2002 A4 Avant 1.8TQM Brilliant Black/Platinum with some stuff.
    My car and I have a lot in common--we're both kind of old and slow, but still manage to look pretty fucking cool.
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Excellent writeup, as always.
    And in case anyone wants to replicate this, we have the 710N's in stock (http://www.europaparts.com/diverter-...10n-bosch.html)
    Dec 01 2007
    San Jose CA
    <shakes head>
    Can't believe I forgot to post that. Thanks for pickin up my slack Matt.
    Quote Originally Posted by Matt@EuropaParts View Post
    Veteran Member Three Rings Mani's Avatar
    Dec 21 2009
    2008 BMW 335i - Dinan Stage 3
    Irving, TX
    Very nice write-up. Thank you!
    Established Member Two Rings heffer's Avatar
    Apr 22 2010
    Idaho
    Nice write up, I don't know how I missed this thread before.
    May 17 2009
    The Netherlands
    Great write up. For a non technical person for me also to do. I have looked in engine room (a4 B6 1.8T) and I can't see the diverter valve from above. Is this correct?
    So, I have to change it from under the car?
    Aug 18 2009
    02 Audi A4
    Quote Originally Posted by Tobs View Post
    You should be able to see it from above, but like you said installation has to be done from under the car.
    "I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story so don't let someone else write the book."
    Instagram: lisek99
    Dec 01 2007
    San Jose CA
    Glad it was helpful, and that's exactly why I put this together. I used to be very non-technical so stuff like this always helped me out in the beginning. Still have a lot to learn, but that's the fun part.
    First, start by putting your car up on some ramps (jack stands make me nervous) and then remove the lower belly pan / skid plate.
    Next, print this out and start looking around at your engine. In the beginning, this worked really well for me. Helps a lot to have a labeled diagram to understand what you're looking at.
    Quote Originally Posted by lisek99 View Post
    Exactly.
    May 17 2009
    The Netherlands
    Ok. I replaced the stock diverter valve with the 710N today. It looked a little bit different from your pics and tubes. So I hoped I installed it the right way. I connected the lower tube that was connected to the intercooler pipe on the side of the diverter valve. I connected the higher tube to the side of the diverter where the other side it the small opening (for the small tube). Is this ok, or was it already in reverse installed?
    The stock diverter valve has the number 058 145 710. Was this also a good diverter valve already, because it ended with 710 without the N?
    When I tested it, the car looked like it ran better (direct power when I switched gears). But I still have the problem that when I pull till 5500rpm and than switch to a higher gear (and press the clutch) the gas is going up a little longer. I was hoping this would fix it. Any ideas what I can do to solve this issue.
    By the way I have a audi a4 B6 avant 163hp (stock) and I chipped the car to 204hp. It is running on liquid gas.
    Established Member Two Rings villan's Avatar
    Jun 10 2009
    2007 4Runner
    excellent write up!
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    .... But I still have the problem that when I pull till 5500rpm and than switch to a higher gear (and press the clutch) the gas is going up a little longer. I was hoping this would fix it. Any ideas what I can do to solve this issue.
    Bypass your N249 valve for almost INSTANT throttle to DV action. This valve acts as a dampener for the throttle-dv activation and lets the ECU filter when the DV kicks in instead of when u release the gas pedal. Car feels more reactive to on-off throttle transitions and seems to do what u want RIGHT AWAY.
    Do a search to find the write-up
    Here is a pic from when I did mine showing the loop connecting the N249 valve back onto itself. Also be careful not to break the valve nipplez as many have... hahaaa
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    May 17 2009
    The Netherlands
    Ok after inspection, my oem diverter valve was already reversed. I bought this car from a company that always did maintenance at the audi dealer. So my diverter valve was reversed from the factory. I know witch the 710N back to reverse and it is running better than with the stock diverter valve.
    I am going to do the N249 bypass now. Let you know the results.
    May 17 2009
    The Netherlands
    Did the N249 bypass, but I can't really notice a huge difference. But I just did a test run of 5 minutes. I also read that the bypass was noticed the most when the engine was cold and this was not the case.
    May 13 2008
    NoCal - EBay
    Also more easily noticed with snub, engine, and tranny mounts and LWFW. Off throttle its like I'm already stepping on the brakes with the N249 delete.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    May 17 2009
    The Netherlands
    Quote Originally Posted by A4SoftWalker View Post
    I live in The Netherlands, so I am dutch and I understand nothing from this sentence. Can you explain what you mean?
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    he is saying that when he removed n249 valve, he sees difference, especially if all the mounts are replaced (snub, engine, transmission) as well as having light weight fly wheel (lwfw)
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Prolly gonna reverse mine tomorrow. shoulda done it when I put it in a couple weeks back but oh well.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Dec 01 2007
    San Jose CA
    Interested to hear how it works for you, especially cause you're Stage2+... do let us know.
    Quote Originally Posted by bigblue View Post
    May 17 2009
    The Netherlands
    Ok, today I drived around 100km and the car runs noticable better than before, especially faster response.
    Dec 01 2007
    San Jose CA
    Excellent to hear Tobs, glad it worked out for you.
    Side note, where exactly do you live?
    May 17 2009
    The Netherlands
    Quote Originally Posted by a4darkness View Post
    Eastern part of the netherlands.
    Dec 01 2007
    San Jose CA
    Ah, gotcha.
    After high school (some years ago) I had the chance to live there for a month with two different families... stayed in Heerhugowaard and Obdam but went all over the country. Fantastic place, incredible people. Been back to Amsterdam 3 times since. Love your country!
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Flipped mine, runs a lil funny in low boost. But it is more responsive. Would be it good to get an mbc and set the boost down to like 18 instead of the 20-22 I'm getting now? would it throw anything off?
    Dec 01 2007
    San Jose CA
    This is getting into an area I'm not entirely familiar with. However, my initial thought is that the APR software might be picky about using a MBC. However, I can not speak to this but am interested to figure out why this might be happening.
    Dec 21 2009
    Irving, TX
    I got mine installed in reverse couple of days ago... driven close to 100miles. I feel little more power in lower gears but it is also noisy (maybe extra boost!). I don't know for sure if the noise is related to the DV because I also installed Apikol snub mount the same day.
    Dec 01 2007
    San Jose CA
    Noisy? Like how Mani? Like... boost sound or rattling / engine noise?
    Do tell. Interesting.
    Quote Originally Posted by mani View Post
    Dec 21 2009
    Irving, TX
    Definitely not rattling or from engine. I hear that noise only with acceleration. It sounds like boost to me. I am gonna have my friend's opinion tomorrow. I might switch it back to normal direction and see if the noise disappears.
    Dec 01 2007
    San Jose CA
    Ah, well in that case I'd agree. Wonder if that's it? Keep us posted.
    Mar 22 2007
    2005 Audi A4 1.8TQM Ultrasport
    San Jose, CA
    Nice write up. Really helps the rest of us out.
    Jul 17 2009
    Too much shit.
    Longview, WA
    It is most likely the DV. Audi originally ran it in reverse orientation, but after numerous complaints about a "weird" noise from under the hood, they switched it to the normal, or current, stock orientation.
    **Brett**
    Dec 21 2009
    Irving, TX
    Quote Originally Posted by AvantJunkie View Post
    Sounds like that's my problem as well.
    Established Member Two Rings markskyline's Avatar
    Nov 15 2010
    08 Ninja ZX6R, 15 Harley Iron 1200, 05 Range Rover, 00 Porsche Boxster
    Vancouver BC
    Thanks for the DIY. Did this a few days ago without a hitch. I wouldn't normally have tried to do this on my own. Runs great with my APR Stage 1.
