Page 1 of 3 123 LastLast
Results 1 to 40 of 120
    Oct 16 2008
    South Florida - Ft Lauderdale
    Thumbs up OEM Votex Skirts: the DIY
    Hi,
    Because some of you have purchased the OEM Side Skirts, you will find attached a DIY
    Tools = Generic
    Difficulty = 3
    Time = 1.5 hrs per side
    Manpower = 2 souls for final install
    First, remove the door blades from the front and rear door. There are 2 screws holding them in place, front and aft of each door.
    AFT
    Front
    Using a flat screwdriver and starting by one end, lift and pull towards the outside of the car, the doorstep rubber trim
    Remove the 2 screws on the front wheel well
    Remove the 2 screws on the rear wheel well. Remove also the trim under the chassis; you will need to modify it later. Remove it completely!
    Now remove the wagon of screws on top and bottom of the existing skirt.
    Don’t forget this one hiding behind the front door
    Bottom
    Skirt removed
    Clean really well the areas covered by the old skirt, I used MEK.
    My kit was manufactured in 2006 and I was not happy by the stickiness of the tape already installed. I decided to remove it, and after a little trip to home Depot, I bought a brand new roll of 3M tape, double sided and really sticky.
    Old tape
    Once the old one is removed, clean the area with MEK. CAREFUL NOT TO TOUCH THE FRESH PAINT!!!!
    Install the new tape and respect the cut off areas.
    On the rear corners, my set had masking tape on them. Peel it off, clean with MEK and install a piece of tape on each cut off areas of the skirts
    Cut off areas
    Now with the tape installed
    Equip and install the 3 brackets
    Equip the new rear bracket provided with the 3 rapid nuts and install on the car.
    Installed
    This is when you need to call your Friend: Peel off the protective side of the tape on the entire skirt. Starting from the back, present the skirt and install the upper screw on the rear bracket while your Friend is holding the front part of the skirt away from the chassis
    Top screw installed
    Go to the front and clip the skirt to the chassis. With a clean rag, press firmly on the entire length of the doorstep and the result should look like this
    With a razor blade, cut the rear trim as follow because it will not longer fit inside the new skirt
    Cut off
    Installed
    For the front wheel well, you will note that now, the skirt goes on top of the plastic well while it was under before. This is why you need to use now the long screws provided.
    Reuse also the same screws to secure the 3 brackets under the chassis to the car.
    One side done, one to go.
    Pictures of the car will come later...after a good bath
    Let me know if any question
    Phil
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Very nice! Cant wait to see finished install. You are a Jedi in the World of Audizine. LOLOL :-) Would be cool if ya had comparison pics of before and after of a side view of the car. I still cant tell from all the pics I have seen all over the web just how much lower thse things go than the original side skirts. If they look good I might buy a pair and keep them till I want to put them on later. My local Audi dealer still has a set. :-)
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Once more really helpful Phil. Thanks again for the input.
    Are you running S4 Door blades, or S-line ones...?
    I am thinking of going with S4 ones so just asking, thanks.
    Audi A4 in an RS4 body
    Mike
    Oct 16 2008
    Here is an old picture of my car.
    The skirts are about 1/2 inch lower than original, but still above any components under chassis
    Phil
    Oct 16 2008
    Quote Originally Posted by Doctor View Post
    Always a pleasure my Friend
    These are S-Line blades
    phil
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    wow thanks again phil. you are fast!!! :-)
    Senior Member Three Rings 4ty-phive's Avatar
    Jun 12 2009
    Stay tuned...
    Chesapeake, VA
    I have a question. Did you paint yourself, or did you pay someone? Either way, what did you pay (if you don't mind)? Great post.
    Veteran Member Four Rings gpxluke's Avatar
    Feb 14 2006
    Vancouver
    nice mod~~~
    where did u buy your side skirt? and how much did u pay for it
    Oct 16 2008
    Quote Originally Posted by 4ty-phive View Post
    I do prep and paint myself. I just borrow the paint both where I work. Base + clear cost me for a pint: $140. But I have a lot left for the rear DTM bumper once I get it
    Phil
    Oct 16 2008
    Quote Originally Posted by gpxluke View Post
    nice mod~~~
    Got them from the Dealer and paid $79.20
    phil
    Feb 14 2006
    Vancouver
    .....holy crap that's fucking cheap~~~~
    I am gonna drop by my dealer and check out the price...why it's so cheap -_-?
    Oct 16 2008
    Yes, it's really cheap and this price include the 2 skirts primed, all the hardware, the 6 side brackets and the 2 rear ones.
    Not sure why they dumped the price but for your information, I have been really lucky that my Dealer had a set in stock so if I were you, I would hurry up because this Discount, is well known in the Cummunity
    Phil
    Feb 14 2006
    Vancouver
    haha sure i'll definitely go check them out tomorrow
    Dec 07 2006
    San Francisco, CA
    Great write up. Thank you! I can't wait to install my set. I have a lot more confidence after reading this write up!
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    I'll be doing mine soon too... That will complete my full DTM Kit!
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    dude 80 dollars only? wow thats awesome!! Phil you should swing by tomorrow night
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    Great DIY! Thank you Phil!
    BUT hmmmm. This was my concern with these. I think anything other than the non-sline door blades look a little funky. Which kind of makes sense as the votex kit was molded for a non-sline car. Phil do you still have your stock blades? If so maybe slap a side on to compare?
    May 20 2004
    More cars
    Never Land Ranch
    nice DIY, but i don't see a huge difference....
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Dec 16 2008
    Cleveland OH
    Quote Originally Posted by SEXICAN View Post
    Ohh but it is :)
    Oct 16 2008
    Quote Originally Posted by Geoffafa@Wolfcars View Post
    Hey Boss, won't be able to. I am flying tomorrow night. I will call you next time I come, to make sure you are there (you know what I mean)
    Phil
    Oct 16 2008
    Quote Originally Posted by Tusin View Post
    I won't be able to compare because I don't longer have my OEM blades. sorry
    Phil
    Oct 16 2008
    There is Sexican, believe me. To give you an idea, on the rear door, the edge of the door blade is flush with the skirt
    Phil
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    S line door blades are hiding the skirts. With stock blades, the effect is very RS4-like, especially in person.
    If you look at a side shot of an S line or S4, the lower definition of the body (and front valence lip) is at the bottom of the doors. With DTM, Votex, and RS4, the line is shifted to below the doors, making the car appear lower and more aggressive.
    Mixing the two (door blades plus skirts) just looks confused, IMHO. But hey, whatever makes people happy, I guess.
    Nice DIY- way better than the included instructions...
    "Obsessed" is a word that the lazy use to describe the committed.
    Aug 31 2007
    Miami
    Phil
    No problem Phil, just give me a call. We are either at Moe's or at the shop, either way you're always welcome :) Have a safe trip!
    IG | @fukn_fafa
    Established Member Two Rings FASTONE's Avatar
    Feb 13 2006
    04 I35, 05.5 A4
    KMC/Erfenbach
    Nicely done Phil.
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    Phil thanks for this write up! My order is supposed to come in today/tomorrow and I am getting them painted as part of an accident where someone hit me on my drivers door! I am wondering though if I should put them on now or wait for my DTM front/rear. Any ideas?
    -Trent
    Oct 16 2008
    Your welcome.
    I will put the skirts on now.
    I found a rear DTM bumper as well. Should be here in 4 days
    Phil
    May 20 2004
    More cars
    Never Land Ranch
    Your welcome.
    Phil
    Sorry i couldn't get it for you sooner
    I'm sure it looks good in person, but i dunno....
    How much are they?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Jan 05 2006
    Oakland, CA
    http://www.audizine.com/forum/showth...ray+dtm+skirts
    About halfway down the page, there's a lot of pics of a quartz gray car featuring Votex skirts. Probably gives a better idea of the effect.
    May 20 2004
    More cars
    Never Land Ranch
    So almost looks like the VOtex and side that come on the DTM. Are they the same?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Oct 16 2008
    Yes they are
    Phil
    Active Member Two Rings barro's Avatar
    Mar 28 2009
    A6 4F 3.0TDiQ Avant
    Finland, Helsinki
    Looks amazing!! Again;)
    Do you have any OEM numbers for that skirt kit?
    Looks very clean with S4 door blades as well.
    Jan 05 2006
    Oakland, CA
    Yes they are
    Phil
    Actually, no. Different part numbers, and it appears that Votex stick out slightly farther.
    Mar 16 2009
    Anchorage, AK
    Yup exactly the same.... Hmmm I have a decision to make. I have S4 door blades, and still have the stock OEM blades. My Votex skirts are not in yet. But I think either not use the votex skirts, and keep with the S4 blades. Or sell the S4 blades and put the OEM ones on with the votex skirts.
    Oct 16 2008
    Or you compromise and get Sline blades with skirts. I think the S4 blades will be too aggressive and will way out the skirts
    Phil
    May 20 2004
    More cars
    Never Land Ranch
    I have the CF S4 door blades and would consider doing this, but i would need a picture of these and S4 door blades on...
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Oct 16 2008
    Quote Originally Posted by barro View Post
    Looks amazing!! Again;) Do you have any OEM numbers for that skirt kit?
    Voila: 8EC-071-685-9AX
    Phil
    Mar 28 2009
    A6 4F 3.0TDiQ Avant
    Finland, Helsinki
    And these Votex fits with S-line or S4 door blades?
    Even more interesting;)
    Oct 16 2008
    Yes they do
    Phil
    Oct 02 2006
    Wadsworth,OH
    These are designed for A4 Sedans and A4 Avants as well as S4 Sedans and S4 Avants. We are running a sale on a couple of Votex items:
    http://www.audizine.com/forum/showth...Spoiler-85-OFF
