HEy guys looking for a bit of help from those that have completed the conversion or have the adapters to do it.
I was contacted by a member who purchased a car and someone had installed HID and LED tails. Now instead of using a conversion harness for either of them they hacked the hell out of the original car harness. The member was under the impression the conversions where done properly and just needed coding.
For the front they cut off the original connector and just spliced a bunch of wires together until they had partial lights functioning. I was able to work with the guy to get his rear light wiring corrected and lights coded so all those faults are gone but the front is just a mess. I got enough coding done so the car is functional but far from done.
Bentley is missing the entire pin out of the light on the right side and the there are a couple of wires that are vague for the HID. I was hoping someone could post the conversion from their adapters so I can try and give the member a proper wiring diagram to fix this mess. Although it will never be as nice as a conversion harness at least he can get rid of the errors and have proper functioning lights.
Help would be appreciated. To whom ever did this to the car you should be ashamed of yourself. Guys don't hack your cars to save $100.
