Results 1 to 25 of 25
    Senior Member Three Rings S4tranquility's Avatar
    Dec 29 2005
    2001 S4 6 speed
    NE Ohio
    Beltline Trim Removal and Installation Shortcut Method
    DIY B5 S4 / A4 Piano Black (or CF, etc) Trim Installation Shortcut Method Write-up (I modified golfrsi's instructions - link may be broken)
    Tools Required:
    * Phillips head screwdriver
    * Ratchet
    * 10mm socket
    * 8mm socket
    * Flat head screwdriver
    * Thin, long flathead
    * Ratchet extension(s)
    * Thin pry tool (butter knife works or 45 degree pick ideally)
    * Needle nose pliers
    * Pry tool (wide pry surface to remove the last clip in the long dash piece - screw driver is too narrow). See pic below.
    Step 1: Front Doors... There are 3 phillips head screws that need to be removed from the outside (marked with red arrows). Once the handle screw is out, the plastic trim piece it holds can be moved down - no need to remove it entirely - just enough to expose the screw(s).
    Step 2: After you have moved the plastic trim down (note: the pic shows it removed, but you don't have to completely remove it), you will see 2 brass screws (1 in the rear doors). Undo these. The door card is now free to remove. Pull up and out. Do not remove all the way out as the handle cable and wires are still connected.
    Step 3: Once you have the door card away from the door you can lean it in place by resting the lower plastic guides into the holes. With it leaning in place, it's time to remove the trim clips. Pull the foam back and find the 5 clips (4 in the rear doors). Make sure all are removed before you try and pull the trim out. Forgetting one can result in cracking the wood. The easiest way to remove the clips (for the wood trim, aluminum is different - refer to step 10 to see those) is to insert a small flat head into the open end, pull it down or over, and remove it. Once all the clips are out, you might need to manually push the trim out as the vinyl on the door cards will hold it fairly snug. From that point, re-install is the exact opposite. One key point is to remember to feed the lock pin (next to the alarm LED on the top left (on the drivers door) back through the door card when you are sliding it down into position.
    Step 4: The rear doors are almost identical to the fronts except there are 4 trim clips and only 1 brass screw behind the plastic trim piece in the door handle. It's even easier to get at this screw without entirely removing the plastic door handle trim piece.
    Step 5: Drivers side lower dash removal... Remove the fuse panel door - this is just clipped in place and your thin pry tool or flat head will get it off very easily being careful not to crack it. Remove the 2 bolts located on the bottom (no pics of these). There are 2 more bolts located on the underside of the lower dash, one on either side of the steering column. These are hidden under rectangular plastic covers that just pull straight off - using a flathead screw driver you can stick it in the lower end of these and slide it till you feel a notch - this is the easiest place to pry from and you will be less likely to scratch anything. There may be a 5th bolt down on the lower right (near the driver's right foot). Once all out, the lower dash just pulls and falls away.
    Step 6: Passenger side lower dash removal.....
    Start off by pulling the end cap off the end of your dash board. This is just clipped in place and your thin pry tool or flat head will get it off very easily being careful not to crack it. This will expose 2 screws that need to removed. They are marked by red arrows in the pic.
    Step 7: Open the glovebox door. Remove contents. There are 2 tabs (marked in red) on either side that stop the door from opening a full 180°. pinch these together so the door swings down like shown here.
    Step 8: There are 2 screws located to the left of the lower dash. These connect the lower dash to the center console. See the picture. It is taken as if you put you head in the glovebox and looked towards the drivers side of the car. Be careful not to let the left one drop into the abyss. Once these are free, the entire lower box will drop down enough to get at the trim clips.
    Step 9: Hazard trim piece... This needs to be pulled straight out. There are 6 clips holding it. Here is my shortcut - Being very careful with a wide flathead screwdriver or butter knife (maybe better), insert into the top edge and carefully pull outwards working along the top till it is all evenly out a little bit. Then work in by the cupholder and buttons to pop out there, too. That should do it. See the pictures to understand the clips.
    Step 10: Small dash piece... Contort yourself so you can see the clip you are attacking. You might be able to see it through a hole near the fuse panel. Using your butter knife or picker, work the 2 clips off the post. Once you get it a little way off, you can use needle nose pliers to get it the rest of the way. It can take some patience depending on how good your tools are. Keep these clips because you will need for the new pieces. once both are free push the posts through the vinyl and remove the trim piece. The pictures show an intact clip and one removed.
    Step 11: Long dash piece... Now that you know how to remove the clips, you will need to be patient to remove 5 of the 6 here. As you can see in the picture below, the second one from the left is the one that isn't directly accessed using this method. Once you remove the 5 you can reach, it's on to getting the last one off. Using the large pry tool, work it in from underneath right where the clip is shown to be. Pry away carefully. You will likely turn on your hazards and depress other buttons or the cupholder during this process. That's okay just keep working it free (an alternative method is to insert a couple zip ties on both sides of the last clip and pull those). This method is better than prying away and bending the trim from the sides because you may ruin the piece by doing this. Eventually it will pop off and the clip will go off to never never land. That's okay. Just install the new piece with the other 5 clips. It will be fine. Picture is to illustrate where the clips are. You will not remove the center console, etc for the shortcut method.
    Step 12: Shifter surround... Directions are for a 6 speed since I've never worked on a TIP... Unscrew the shift knob. Reach inside the surround and pull straight up from the front. It will unclip from front to back and than slide forward out from under the ashtray. Install will be the reverse, but you will need to unscrew the shifter boot and bend the aluminum tabs to remove the shifter boot and trim - you'll see I hope.
    Step 13: Ashtray... Open the ashtray. The trim piece just pops off. I have seen these tabs broken, though, so just take care. I grabbed mine by the top corners and it just popped off without too much effort. Snap on new piece.
    If you haven't already, bolt the dash, glovebox, and everything back together. Grab a beer and admire your new interior.
    Here is how mine came out :)
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    2008 Bmw 135i
    Westchester, NY
    Re: Beltline Trim Removal and Installation Shortcut Method
    now this looks like a more manageable job. i cant wait to do this.
    AKA: Bigair
    Sold: 00 Audi S4
    New: 08 Bmw 135i White
    S4 //VAST
    Senior Member Three Rings tgiblin's Avatar
    Mar 27 2008
    2001 S4, 1957 Bel Air, 1972 CT70
    Don't Steal My Car
    this was actually one of the easiest things ive done so far on this car. it took no more than an hour.
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    MPLS/ATL
    One of the best writeups I've seen in a while.
    Great work - it came out awesome.
    Here's some more incentive for everyone else to do it...Just painted silver. Pre Alcantara.
    Dec 29 2005
    2001 S4 6 speed
    NE Ohio
    Quote Originally Posted by HotSauce View Post
    Very nice. I thought about trying a set similar to that, except doing the 3 center console pieces in plastidip.
    Sep 27 2006
    2008 Bmw 135i
    Westchester, NY
    any write up 's on how to paint your trim like that?
    AKA: Bigair
    Sold: 00 Audi S4
    S4 //VAST
    Jul 26 2004
    MPLS/ATL
    Quote Originally Posted by Bigair View Post
    http://www.audizine.com/forum/showthread.php?t=50805
    And yea, I thought about plastidipping. I'm really glad I did the shift surround in silver, but I think the ashtray and hazard would be better black. Just too lazy to change it up, and it's grown on me.
    Sep 21 2008
    Toronto, Canada
    i actually did this recently...
    For the 2 trim pieces on the dash.. i just used a prybar similiar to the one pictured to pry the trim off..
    I managed to take them off without any damage to the trim or car... Then on the reinstall i rolled tape on the metal studs and they went back in nice and snug.. Probaly not the best way to do.. but I didn't feel like taking the radio, glove box, etc out.
    You cannot pry the doors off though.. the clip system is different than the fronts... so I had to take the panels off..
    Active Member Two Rings Dirty(30)v's Avatar
    Nov 10 2009
    03 A4 3.0L
    North NJ
    Red ultra suede Trim
    clear corner/stealth bulb/ yellow fogs
    DONZ 19''/vmaxx coils/15mm spacer*/ rs4 swaybar/ custom intake
    votex rear*/ usp front*/ DTH side skirts/ trunk lip/ badgeless grill
    I have a bunch of stereo stuff for sale wanna get ride of it asap
    http://forums.vwvortex.com/showthrea...vd-cd-mp3cd%29
    Registered Member Two Rings scottb2240's Avatar
    May 25 2010
    carmel, in
    some of those pieces by the steering wheel are just bitches to get out ... but def a good writeup!!
    Dec 29 2009
    Santa Clara, CA
    Just wanted to say thanks for the thread i did this method yesterday to swap to the silver interior. Also plasti-dipped the hazard and shifter surround .Really nice look!
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Nice way to bring this back ^ lol ... But you know what, I too, can benefit from this
    ~Sergio~
    Coalition of The OEM+ Audi Owner's Member #9.
    http://www.audizine.com/forum/showth...IY-Master-List
    http://www.allroadfaq.com/reference/engine.shtml
    '01 AR= |034 TBB|034 Y pipe hoses|Custom Tune stg 1|Clarion NX501 ICE|oem roof bars|Yakima Skybox 18|VDO vent Boost Gauge|KnN Drop-in|Yellow Fogs|oem Double spoke wheels(2 sets) summer & winter|20%tint|034 SAI Block off plate kit, Now with less Combi valves
    Active Member Two Rings 11bravo's Avatar
    May 22 2011
    WI and NC
    very cool. i'll be doing this next week for sure
    party rock
    Senior Member Three Rings Corbett's Avatar
    Mar 09 2011
    This DIY was almost perfect! Thanks a lot! My beltline is out for paint as well speak! Will post pics in a few weeks.
    My only suggestion is that for step 9 I ended up just using the radio removal keys and was able to pop the hazard surround off by hand. I wouldnt want to take a prybar or butter knife to that part to get it off
    Oh, and the zip tie suggestion worked perfectly for the front long piece above the hazard/foglights.
    Active Member Two Rings hallvardr's Avatar
    Jul 28 2012
    Norway
    Awesome work. Helped me a lot when I fixed up my interior. I used matte 3d carbon foil on the trim.
    On the final clip over the stereo in the front. I just made one loop on each side out of zip ties and pulled straight out.
    Here are some before and after shots.
    Senior Member Four Rings S4 00 2.7's Avatar
    May 13 2011
    Best instructions out there.
    APR | SSAC dual | tt downpipes | UUC | JHM | ST | 034 rear sway bar + 034 end links
    2003 Z06 blk/blk (Sold)
    Wicked
    WTB: Milltek or Borla catback
    Senior Member Four Rings Gdlaszako's Avatar
    Jan 30 2011
    Probably some Black Widows
    Very nice write-up.
    Griffin: Free style walker...everywhere
    If that series of events ever happens again, and you guys can quote me on this, someone can come to my house and slap me one (1) time in the face. - Gram
    Jan 22 2012
    El Paso/ Fort Bliss
    Awesome write up. Definitely my next project.
    New Member One Ring
    Dec 12 2012
    Norway
    How do I get out the ashtray?!? It's so fn annoying, please can someone help me?
    Registered Member Four Rings
    Dec 11 2006
    QuattroWorld
    Quote Originally Posted by olmarthi View Post
    It snaps out, just give it a good yank.
    For sale:
    4" Exhaust setup. Muffler and piping
    Pass. side timing belt cover (2.8 Brand New)
    AC Lines
    Stock Fuel Rail with FPR
    034 Lower Compression Headgaskets
    Misc. oil and coolant lines
    Misc. brackets
    Misc. AN Fittings and braided lines.
    Rear leather seats (black)
    New Member One Ring
    Dec 12 2012
    Norway
    Quote Originally Posted by Das General View Post
    I've tried that several times... In wich direction should I pull?
    Can someone make a tutorial with pics?
    Senior Member Three Rings Jupiteraudi's Avatar
    Mar 29 2009
    01 S4 Avant 6spd, 08 S4 DTM pkg.
    Jupiter
    The clips are on the bottom, be patient. You also have one of the best DIY instructions at your fingertips. Consider removing the shift surround then removing the ashtray, it might help.
    Stasis Exhaust W/ Milltek DP's
    Stasis Alcon 14" BBK
    Stasis Ohlins SL Suspension
    JHM Tuned
    Hyperflow Cold Air Intake
    19" Hartman 252-M RS4 Reps (machine finish)
    Senior Member Three Rings sqitis's Avatar
    Sep 03 2010
    00 Imola S4 - Tools - BMX Bikes
    Nashville, IN
    Open the ashtray and take the insert out and there will be two little push down clips on the bottom, shine a flashlight in there and you will see them. Gently push them down and the cover will pop right off.
    New Member One Ring
    Dec 12 2012
    Norway
    Got inpatient... Ripped it out, but im going out to see if I can get it back in.. But I got the damn piece off!
    Active Member Two Rings Tec_Nine's Avatar
    Sep 17 2012
    Des Plaines, IL
    do work
