Results 1 to 40 of 49
    Veteran Member Two Rings tgt's Avatar
    Feb 18 2004
    Wisconsin
    My Avant S6 LED Install - with Pics
    After much deliberation (between FLY's LEDS and installing/modding the S6 LED's), I decided to give the S6's a go. Something about them being in the bumper just looked great to my eyes (don't get me wrong, I love FLY's and he does a terrific job).
    I decided to follow nnnicks lead and install the S6 LED's on the Avant. I won't go into great detail with the exception of what I did differently than nnnick.
    nnnicks DIY post: http://www.audizine.com/forum/showth...&highlight=led
    Thanks to nnnick, enigma, and 10mpg for their pics/info from the past.
    Differences from nnnick's install:
    -I installed the LED's flush with the inside of the bumper (rather than notching the inside of the bumper) ala enigma/10mpg. This made for some interesting fit of the outside of the LED around the intercoolers, however, it JUST fits. :)
    -I wired the LED's to the ignition (tapped into fuse #7 and ran the wire into the cabin fuse box)
    -I really liked enigma/10mpg's grilles (the way their shops customized the OEM grilles), so I decided to go that route. Cutting the grilles down, filling the fog light hole, 'creating' the grille bar across the middle, and then sanding, bondo, sanding, bondo, etc. etc. was a HUGE pita. I'm happy with the results (they aren't 'perfectly smooth' yet, but I'm glad I decided to go that route). For now I didn't create the top grille bar like enigma/10mpg did, as I actually liked how the bottom of the LED shows as it does on the S6. If I change my mind I'll create it later.
    **I know some have mentioned concerns about the LED's blocking some additional air flow to the IC's. If after some driving I think there is any hampering of air flow, I plan to cut out the exterior (that is always blocked, even on the OEM grilles) solid areas which should provide more air flow than stock.
    Onto some pics. Unfortunately just after installing the fog grilles it started to rain (so I only snapped a few pics). I will take proper pictures later. Any questions from those considering this...I'm happy to assist/answer.
    Thanks,
    tgt
    Final Pics:
    Pics of LED's prior to grilles being complete:
    Pics of the grille fab:
    Steps:
    -Trim fog light grille to fit
    -Cut out fog area of grille
    -Use tape of your choice and crate 'backing' (something for the Fibre hair body filler to hang onto. I got the filler from Napa). I used TWO coats of this filler to create the bar area.
    -Sand (A LOT, this was EASILY the most time consuming thing)
    -Body Bondo to Smooth (Note: the body bondo is different than the fibre hair body filler)
    -Sand
    -Body Bondo
    -Sand
    (you get the idea, you need to do this until it's smooth and the imperfections are gone)
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: My Avant S6 LED Install - with Pics
    great job! look amazing!
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    well done. looks good.
    DUH! an Audi
    los angeles, CA
    nice :)
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Nice work!
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Items for Sale
    looks awesome! very clean indeed. i like the grills too, I might have to try this out wiht my old grills lying around and compare them side to side...seems straightforward enough based on how you did it, I like the use of duct-tape :)
    Do you have a close up of the wiring into the fuse box? Might have to give that a try.
    Current: 2012 Audi TT-RS | HREs, MSS Kits, oCarbon, and most of the 034 Catalog
    Former: 2006 Audi S4 (Heavily Modded) | 2006 Audi A4 (Also Heavily Modded)
    Visit my blog: NicksCarBlog.com
    Veteran Member Three Rings Msu2312's Avatar
    Jan 17 2009
    scooter?
    damn super bright, awsome
    ...2008 A4 2.0T S-Line...
    Neuspeed flash upgrade/Forged diverter/spacer/AEM intake/VMR Test Pipe/19'' black ultraleggeras/Magnaflow Unresonated Exhaust
    ...All wrapped in Double limo...
    Registered User Three Rings 05.5SilverS4's Avatar
    Jun 14 2009
    2005.5 S4 , 2000 Yamaha R6
    Fishers, IN
    looks awesome. this makes me on the fence as well in some aspects on whether to do this or FLY's
    Feb 18 2004
    Wisconsin
    Thanks all.
    nnnick - I will snap a pic of that tomorrow. I used a mini fuse tap and tapped into the fuse box (driver's side, side of the dash).
    -tgt
    Jan 17 2009
    scooter?
    imagine both lol
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2012 A6 3.0T, 1990 944 S2
    Items for Sale
    they look awesome but bump for some closeups on the car. you will want a fmic when it gets hot out again.
    And it starts all over again
    Senior Member Two Rings TehDolphin3.2's Avatar
    Aug 20 2009
    Long Island, NY
    Looks really good...well done!
    Apr 09 2009
    montreal
    bookmarked for future reference :p
    Veteran Member Three Rings RJMars's Avatar
    Oct 18 2008
    Minnesota and NJ and MI
    Cleaaaannnn installll
    Light Silver Metallic 2005.5 A4 2.0T, Quattro, MT
    ST Coilovers | "18 BBS RX wheels w/ Michelin Pilot Sport PS2's | LED Interior, citylights and license plate lights | Cupra Lip
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Real Nice! Now to match them with Phils leds :)
    Isn't it easier to just use the S6 fog grills? Cost next to nothing and not as much work as the B7 ones.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Feb 18 2004
    Wisconsin
    Quote Originally Posted by redlabel81 View Post
    Unfortunately not, BELIEVE me I looked into it. The S6 grills are a different curvature, so even though they are less work (to trim/cut down/etc.) the fit is not like the stock grill.
    I would have MUCH preferred to go that route.
    -tgt
    Nov 24 2007
    Tromsoe, Norway
    I see. Thanks :)
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Looks awesome, I'm considering this for my DTM bumper before I do a respray. Was the wiring easy since they include a kit for it?
    Feb 18 2004
    Wisconsin
    Sharkfin - Wiring is easy. I did not use a separate harness, just ran the power/ground to the LEDs and connected them.
    nnnick - Sorry, ran out of time tonight for the wiring pic. Will try again tomorrow night. :)
    Someone requested closer pics, here's a couple. I put a piece of 'door edge trim' (had some laying around) on the top lip of the grille and actually likely the way it looked so left it on. Passenger side grille wasn't completely fastened in the last pic.
    -tgt
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    where did you buy them from?
    awesome
    Nov 05 2007
    Oregon
    Looks great! Did these on my custom DTM bumper for our Avant a bit over a year ago, and they've always looked great. Nice to see another hot avant steppin' out... For the record, I've never experienced any obvious effects from the minor blockage of air that these present for the SMICs, and simply don't worry about it.
    Aug 25 2009
    Where Pimps Hang.
    the Leds look great. Not to be too off topic but how does that epoxy floor covering you have on your garage floor hold up? I'm looking at doing my garage before winter.
    Feb 18 2004
    Wisconsin
    lodidodi - Very well, have been really impressed. If you do it I would recommend the clear top coat (which is the route I went). Really keeps the shine and makes it durable through the elements.
    nnnick:
    Fuse box pic:
    -tgt
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Items for Sale
    thanks for the pic. Did you add a fuse to the wiring in the picture above?
    Feb 18 2004
    Wisconsin
    Yessir, added an inline fuse 'just in case'.
    Feb 18 2004
    Wisconsin
    Quote Originally Posted by Sharkfin View Post
    http://www.umnitza.com/umnitza-aries...ht-p-5652.html
    -tgt
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Items for Sale
    looks awesome, tgt.. definitely the cleanest install done with the s6 LEDs yet!
    by the way, i'm still running your rs6's.. but i just got 2 tires replaced due to hitting a pot hole and having them bubble, haha.
    SQ5 - SEPANG BLUE | BLACK OPTICS | KW SC | AWE | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Feb 18 2004
    Wisconsin
    Quote Originally Posted by staticuxo View Post
    Thanks staticuxo!
    Glad you're still enjoying the RS6's. Dang NY roads!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I was hoping you would say them, I'm considering this because their price is 150 less than the next best competitor. Hmmmmm.....
    Jun 29 2009
    london
    Have you patched it up so the S6 LED lights Stay on during the day with out the side lights being turned on ?
    Veteran Member Four Rings Hockenheim's Avatar
    Jul 09 2007
    Phoenix
    Items for Sale
    Outstanding work, I've been wanting to do this but too chicken to start cutting up my car
    Feb 18 2004
    Wisconsin
    Quote Originally Posted by digzz View Post
    Not exactly sure what you mean. I wired them up to come on with the ignition (per the 1st post), so no other lights have to be on. Can you clarify the question?
    Thanks,
    tgt
    Jun 29 2009
    london
    Quote Originally Posted by tgt View Post
    Thanks,
    tgt
    Thanks you just answered my question.... How did you know how to wire it up? Also did the led's come witrh the wire ?
    Nov 24 2007
    Tromsoe, Norway
    Really like it, but at the same time I miss the round fogs....:)
    Feb 18 2004
    Wisconsin
    It's not difficult. Just a power wire and a ground wire (also an optional wire if you want them to blink with the turn signals like OEM, but I did not want that).
    -tgt
    Established Member Two Rings S4SHOES's Avatar
    Jan 21 2011
    Calgary
    super clean install!
    just ordered my oem s6 led's hopefully installing next weekend with help from all 4 threads. will post pics after
    thanks for all of this info (would have been lost without it)
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Quote Originally Posted by S4SHOES View Post
    Thread is from a year and a half ago, FYI.
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Am I the only who thinks S6 LEDs are more OEM looking on our B7s than any LEDs in headlights? It just flows with the car so well.
    B7 A4 GT28
    Feb 05 2011
    Alpharetta
    I've been looking for the lower grilles to do this modification. If anyone could tell me the part number or which lower fog grill it is(b7 sline, a6,s6). I'm going to do the mod, I just need to know which fog grills were used.
    -"I really liked enigma/10mpg's grilles (the way their shops customized the OEM grilles)."
    I'm looking for these grills he's talk about.
    Thanks in advance for the answer.
