Results 1 to 32 of 32
    Senior Member Four Rings fly300kts's Avatar
    Oct 16 2008
    South Florida
    DIY: CC (Clear Corner) Mod
    Hi Guys,
    Because a lot of questions have been asked on the subject numerous times, I took time today, to take some shots while I was doing a LED strip integration. Of course, this is not the only way to proceed, but it is my way, and it’s a safe way (you don’t end up with broken tabs or other issue). This DIY is performed on a Xenon housing (more complex than Halogen) but the same steps can be performed for both type of headlights.
    This DIY has 2 chapters due to the number of pictures (too many - Right not granted by Admin)
    Time = 1hr per headlight
    Difficulty = 4
    The Tools
    WARNING: The internal chrome components are really fragile and I highly recommend wearing cotton gloves once you start to manipulate them.
    Heat Gun
    Some of you prefer to stick the headlight in the stove. To have personally gutted out numerous Xenon headlights and seen the amount of tinny plastic components, I don’t want to take the risk.
    Flat screwdriver
    T25 Torks screwdriver (grinded to the diameter minimum, you will understand later why)
    Using the flat screwdriver, snap off the clips: 5 of them
    Pull off the rubber protector
    Install the headlight on a soft rag (prevent scratching the lens) and you are going to heat up the seal between the housing and the lens. No need to heat the entire perimeter, the glue used is messy enough when soft and you don’t want it to stick to the chrome. Heat the area for 10 mn.
    Materialized in red the area to be heated.
    Now, grab two rags, hold the headlight vertically and separate the lens from the housing. The lens shape on the turn signal side provides a good grip. If it’s too hard to pull, you can heat up a bit more the area.
    Use a razor blade to cut the cold sealant.
    Voila, headlight is open
    Now you need to remove the internal housing. There are 3 screws holding it in place. Location materialized in red
    Close up of screw #1
    Close up of screw #2
    Close up of screw #3
    Now, the housing should slide off
    On some headlights, it’s a bit more difficult because the housing stays clipped in the turn signal area. Gently pry under the plastic tab to release it.
    Here is a close up of the tab that may stay clipped
    Once the housing is removed, there is an additional screw to be removed right under the turn signal.
    At this stage, I have seen people banging the orange corner with the screwdriver: 99% of the time, you will end up breaking the turn signal tabs !!!
    Now, the tricky screw: He is hiding behind the chrome housing. This is where I use my trimmed screwdriver and work it thru between the headlight housing and the chrome piece. Even if you scratch a bit the edge of the chrome housing, do not worry about it, you won’t longer see it once the headlight is reassembled.
    You can really see the sucker hiding on this one
    Now, you are going to separate the two plastic parts of the turn signal.
    Take a close look at the little plastic shaft preventing the separation
    Using a razor blade, you are going to trim just a bit of the edge of the center pin, trying to make a chamfer.
    Once trimmed, it should look like this
    And now, if trimmed enough, you will be able to slide and separate the 2 pieces.
    And Voila
    Now, to remove the orange cap, just push on it, towards the inside.
    Oct 16 2008
    South Florida
    CC Mod: The DIY - Part 2
    Because most of you will use the opportunity to black out your headlight since they are open, I going to push a bit more the DIY and show you how to remove the chrome pieces off the internal housing.
    Start by the biggest housing. From the inside, just gently pry with a flat screwdriver, the 4 surrounding clips and the chrome piece will release.
    Same process for the small chrome piece, pry on the small 4 tabs. You will have to apply more pressure on these because they are kept locked by a piece of plastic
    To remove the last piece, using small pliers, bent a bit towards the center, the 2 bottom tabs and you will be able to slide the last piece out.
    Now the housing is chrome free and you can spray the black
    Time to put everything back together. First the central chrome piece
    Then for the external one, start by the 2 top tabs and then drive in the 2 bottoms one using the flat screwdriver
    When you reinstall the central one, make sure that these tabs
    Lock into these
    Reinstall the rear turn signal reflector with the top screw
    Then snap back in place the top housing and secure both with the bottom screw
    Reinstall now the internal main housing and secure with the 3 screws
    Reinstall the lens
    Grab a beer
    You are done
    I am around if any question
    Phil
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: CC Mod: The DIY - Part 2
    Excellent.
    Having done it in the past using a different DIY, I wish I had this one instead.
    I think it would be good, having some photoz showing, or explaining how the glass goes back in, as to whether it needs extra silicone or not. I hadnt put any, I used the OEM glue, some do.
    Once again, excellent man.
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and B6 1.8Q USP
    Byers Audi - OH
    You are the man! Know if I just had the guts to do it myself.
    Current: B7 OEM + and B6 USP OEM +
    Previous: B5 and B6, All OEM +
    Oct 16 2008
    South Florida
    Quote Originally Posted by jriddle11 View Post
    If still too scare, send them to me
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY - Part 1
    Phil
    Site Moderator Four Rings AvanTTix's Avatar
    B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    To the Admins,
    I was not able to post this DIY in one single post due to the amount of pictures.
    I would be great if you could merge the PART 1 & Part 2 of this DIY.
    Thank you
    Phil
    As you found out there is a limitation in the number of pics one can insert in one post, however there is no limitation as to the number of posts one can post in one thread... So when you've got too pics, just split them over multiple posts, i.e. reply to your thread...
    Great DIY BTW!
    Stéph - Moderator
    MY2003 B6 A4 1.8T Avant
    : DenimBlue||Ebony||5-Speed MT||Quattro||Premium Package||Sport Package
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium Package||Audio Package
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    ^^ Thank you
    Mar 14 2007
    09 A4 2.0 6MT AWE Exhaust&FMIC
    New York, NY
    Re: CC Mod: The DIY
    Great writeup! I did the clear corners on my old B7 using the screwdriver & brute force method, and this looks like a much more elegant solution... not to mention safer.
    Veteran Member Three Rings dubless's Avatar
    Apr 15 2005
    Carlsbad, CA
    Re: CC Mod: The DIY
    Great write-up . One of the best diy's I've seen on here in a while! If I can't find a fairly inexpensive set up of euro-lights in the next few mos I may end up doin this mod.
    DTM....FTW!!!!
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    ^^ Sorry, I had a set and I just sold it. I'll let you know if I get another one
    Phil
    Mar 26 2007
    Byers Audi - OH
    I want to because I want the LED's too, but our new baby uses diapers up like they are free.
    I just noticed I typed KNOW instead of NOW, boy I need to stop coming to this site when I am tired.
    Senior Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    BT B6 A4, 06 Suzuki Hayabusa
    Raleigh, North Carolina
    Re: CC Mod: The DIY
    What is your paypal OP, so that i may send all my money to you??!! You are thorough! And hairy lol...thx for a killer write up
    -Brandon-
    Mods: APR STG III+ / Labree Split DP / Full APR Exhaust w/ 4" tips / E.R. Comp FMIC / Authentic Oettinger F/R Bumpers / FK Badgeless grille / 19" iForged Daytonas / B6 S4 Calipers / KW-V2 Coilovers
    -12.9 @ 104mph-
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    ^^ I am anal on everything I do
    I'm hairy because I am old
    Mar 31 2009
    Re: CC Mod: The DIY
    lol, are/were you a pilot?
    -Brandon-
    -12.9 @ 104mph-
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    ^^ yes, thanks God, I am still a Pilot.... Did not lost my Medical......yet
    In case you are interested: www.tbm850.com
    Mar 31 2009
    Re: CC Mod: The DIY
    Good to hear! Job security in this economy is the most reassuring thing anyone can ask for at the moment. I am extremely happy that the only way i could lose my job is if i screwed myself over [:D(which i dont plan on doing)
    -Brandon-
    -12.9 @ 104mph-
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    ^^ 10/4
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    Quote Originally Posted by JasonR View Post
    Glad you mention that, it reinforce my therory
    Senior Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    Re: CC Mod: The DIY
    thanks great write up. i will def do next time my bumper is off
    Jan 13 2009
    2008 2.0T A4, 2006 3.2L A3
    Pittsburgh
    Re: CC Mod: The DIY
    awesome write up! Wish I had this when I was doing mine....then I wouldn't have used a screwdriver and partially scratch my housing. Plus now I know how to remove the trim so I can go back in a paint everything black. Thanks again.
    New Member One Ring
    Nov 23 2008
    Re: CC Mod: The DIY
    Where do you get the clear caps. I heard that you get them off some ecodes. Does it matter which model they are (i.e. B6,B5)? Thanks for any help.
    Nevermind. Just found it. I'm retarded. Great writeup, will definitely use this when doing the mod soon.
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 Audi A4 S-Line
    Tempe, AZ
    Re: CC Mod: The DIY
    +1 rep for you - great write-up!
    Much more harder than just knocking it out with force though, haha.
    2006 Audi S4: Brilliant Red on Platinum Silver, 6MT, RNS-E, Cold Weather & Premium Package
    NicksCarBlog.com | Audi Style Racing | FRRG Southern Ring
    Oct 16 2008
    South Florida
    Re: CC Mod: The DIY
    Quote Originally Posted by nnnick View Post
    Thank you Nick, but more safe and it's the most important for me when I work on Customers Healights
    Phil
    Senior Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    Re: CC Mod: The DIY
    That's a great write up/DIY - I've still got my amber-cornered original headlights laying about, so I think I'll be doing some surgery & blacking out the casing while I'm there...
    plus one for ur reputation
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Senior Member Two Rings rowyourown's Avatar
    Jan 13 2010
    New York
    where can i get the clear caps
    Eibach springs, Bilstein sport shocks, GIAC, 034 HFC, RS4 rear sway, V710s, Hankook Ventus V12 235/40/18
    FTWLTBDWICTW is an awesome thread.
    Oct 16 2008
    South Florida
    Quote Originally Posted by rowyourown View Post
    They are as rare as finding a kidney !!
    phil
    Senior Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    wow, that was very well done. congrats.
    Ibis White 2.0T Quattro, S-Line Ti Pkg. 6MT | Mods: 35% Tint |APR 93 | EVOMS Intake | Stasis Exhaust |Koni Coilovers | RS4 Sway Bar | 12mm Spacers | Hankook Ventus V12 Shoes | Brazilian Driver
    Jan 13 2010
    New York
    haha well I've got two kidneys... trade for some clear caps?
    Senior Member Two Rings pnoyworx's Avatar
    Feb 13 2010
    05 S4(FS) - 08 Titan(sold) - 10 Armada - 08 C300, 06 325xi
    Bothell, Wa
    I'm trying to CC my B6 Headlights. Heat gun more than 10mins, and still won't budge. Any tips? Thinking of throwing them in the oven, do I need to remove all the electronics/motor? Thanks
    Stasis Ohlins SL Suspension : Stern Control Arms : StopTech 355 BBK : Carbonio CAI : JHM Lighten Pulley : JHM Differential : BB Downpipe : Magnaflow CB Exhaust : RS4 Rear Sway : i-Forged Daytona 20x8.5 : Nitto 555 245/30/20 : Hartman HR8 Rep 19x8.5 : Dunlop Sportmaxx 245/35/19 : APR Snub : APR Tune : Piano Black Trim : 15% Tint : 50% Tint Windshield : Escort 9500ix : 6000k HID Fogs : 6000k HID Low Beam :
    Oct 16 2008
    South Florida
    Quote Originally Posted by pnoyworx View Post
    This DIY does not work on the B6 since the headlights are glued and not sealed like the B7
    Phil
    Feb 13 2010
    Bothell, Wa
    Thanks Phil... I figured it out after much effort. :)
    Phil
