Cut off the factory lens, took out the reflector and mounted the Micro DE in the factory housing. Little bit of trial and error, but worked perfect. Only issue is one of the fogs isn't completely parallel to the ground right now, but that'll be an easy fix. On to the pics:
fogs only - you can see the one is at a bit of an angle. just need to slot the mounting point and rotate a little bit.
euro bi-xenon lows only
fogs and lows only
fogs, lows, and piaa ion yellow h7 high bulbs with the bi-xenon highs.
