Page 1 of 5 123 ... LastLast
Results 1 to 40 of 166
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    (viziers's) - FWD to AWD Conversion Project
    Just as the tile states ive finally started my conversion yesterday will have some pics hopefully later this evening.....
    So far ive got the rear of the car on jack stands got the exhaust off tires off, E-brake lines off, shocks disconnected sensors unhooked now i just have to try and get the brake assembly off that the hard part because the brakes have NEVER been of the car ever.... They arent exactly located in a prime spot to get at them to apply any significant force to brake them free so i sprayed them with wd40 (all i have untill i get to store for some PB Blaster) in hopes tolosen them a bit..If that doesnt work the ill just take the lines off the calipers and try to take them off when i drop the rear that way the shocks wont be in the way..
    Dont say use an impact gun because i already tried that with a 1100lbs torque 1/2" gun and it didnt even budge it!!!!!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Re: It finally has begun FWD to AWD
    Wow, and they didn't budge? Good luck on the conversion!
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    What do you mean, your brakes? The caliper? The disc?
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Lets see some pics!
    -Kris
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by IceMole View Post
    Lets see some pics!
    Please
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    personall, i would sell te car then buy an AWD, this is insane
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    probably would have saved money and time by selling the fwd and buying an awd... no? good luck!
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    this is the most ridicluous undertaking I have seen in a while. you have balls my friend...good luck!
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Nice project! Been following the thread in the B6 section.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    I respect your decision to go this route, but I think you're a fool for doing it.
    The ONLY time I think FWD to AWD conversions are a cool thing, is when an AWD of the same car is not offered. Which is obviously not the case this time.
    Regardless... Good luck and I hope things turn out the way you want them to.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Veteran Member Three Rings ZEM930's Avatar
    May 12 2008
    2006 Audi A4 Quattro
    Orlando
    Easier to sell and buy a quattro??? Props for going the extra mile though!
    (06 Audi A4) Quattro/2.0T Quartz Grey/Black-------Lots of plans
    ---------- VMR V710s, D2 Coilovers, APR 93, RS4 Swaybars, 034 HFC---------
    Remember, you cant turn a pig into a racehorse but you can build a mighty fast pig!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I'm assuming you've been reading this?
    http://audizine.com/forum/showthread.php?t=259582
    Good Luck! You'll be stoked once power goes to all four wheels.
    -Doug
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    Isn't there some extra computer modules you'll need as well to update the traction control and torque split programming? This seems like a MASSIVE undertaking...
    Lover of all things motorsport, powersport, sport.
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    props for attempting this
    BUT, this is going to kill resale value. Can you imagine trying to sell this as a quattro, and then carfax and VIN number showing its a FWD. Then having to explain to the potential buyer that you retrofitted quattro... that person is most likely going to run for the hills before you can even finish explaining.
    ASE All Same Everything | Est. 2011 MA to FL
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    you're a brave man, Viziers.
    best of luck!
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Veteran Member Three Rings Shnab's Avatar
    May 05 2009
    Your wife and kids
    Brooklyn
    I just hope the car will be reliable after doing all this work to it
    Gotta love em, gotta hate em.
    "Lady Gaga aint got no key changes" -Charlie Hunter
    Jan 27 2007
    NC
    Hey all ill have an update soon as well as let you know some of thie issues and differences ive found so far and the little mishap i had.. With pics of course.....
    vizi
    Jan 27 2007
    NC
    Quote Originally Posted by Bllzll View Post
    Resale........ hell the car already has 111,000 miles on it by the time i go to sell her she will probably have close to 300,000 mlies on her.. Yea im not selling this car ever...... Ill own this car until the wheels fall of it.. Then itll be time for the duct tape and bubble gum...
    And as far as sell this and buy a QT well i got a hell of a deal on some of the pieces so it made it worth it for me.. Plus i know exactly how this car has been run and what its been through because im the 1st owner of it...
    vizi
    Jan 27 2007
    NC
    Quote Originally Posted by scoobycarolan View Post
    The bolts that wouldn't come off were the ones that hold the bracket to the wheel spindle i let them sit over night with the WD40 and then when i got the rear out of the car it was much easier to get at them because the shock or anything else wasn't in the way.....
    vizi
    Jan 27 2007
    NC
    Quote Originally Posted by greene08 View Post
    Nope no modules QT is mechanical from what i understand... And actually this whole conversion is really easy to do.
    vizi
    Senior Member Three Rings ed1380's Avatar
    Mar 16 2009
    ATL
    1/2" impact gun pushing 1100ft/lb? you sure its not 3/4 or 1"?
    good luck with the conversion.
    Jan 27 2007
    NC
    Quote Originally Posted by Shnab View Post
    It will still have its reliability when im done.. Everything gets torqued to specs it it has one...
    vizi
    Jan 27 2007
    NC
    Yup when it all started... lol
    P.S. Im still working on the pics for some reason its not letting me post them....
    vizi
    DUH! an Audi
    los angeles, CA
    good luck, post a DIY!!! not sure how many people would attempt this!
    props to you sir
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quattro is 100% mechanical. This was just done on a B6, this is the same thing. Everything is just removing FWD parts and replacing them with AWD parts.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 27 2007
    NC
    Quote Originally Posted by dirtybrd View Post
    Exactly......
    vizi
    Senior Member Three Rings killerb7's Avatar
    Apr 27 2009
    05.5 A4 2.0T 6MT
    Orange County, CA
    For sure post a DIY. Ill for sure do this.
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    this seems llike a serious project... how long do you expect it to take you? good luck with everything tho! and lets see those pic when you get them working!!!
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Veteran Member Three Rings WayzataAudi's Avatar
    Feb 18 2009
    911SC Targa
    Colorado
    ...you shoulda just done RWD. i dont even know that its possible but you would be prolly the only one on here running one, and itd be sick. good luck though broseff it sounds insane!
    I <3 Whatever
    Senior Member Two Rings ringofsteel's Avatar
    May 05 2008
    67 BETTLE,95 GOLF JOKER, B7 A4
    BODENSEE, GERMANY
    when complete I will send you a quattro badge. Congrats, and good luck! QUATTRO FTMW!
    APR STAGE II+ APR STOCK/91/93/100/W/M/Test Pipe File,APR Full Cat-back, ZeroThreeZero TP, 034 Motor Mount, AWE DV, BSH Catch can w/PVC bypass, RS4 plastic covers, VAST W/M, D2 V3 Coil's, Cryo Rotor, ECS Steel Brake lines, Hawk Pads, 19" OZ's Ultra's 35et, 10,000k HID, AVIC D3 up front, 15" Flip down in the back with backup cam, Valentine, AWE Vent Gauge, Kenwood 8" Sub in stock local, Memphis Audio amp, 1 Farad power cap, Audi S4 blades, Audi Front Spoiler, Audi Rack system
    Senior Member Two Rings cecaa's Avatar
    Feb 13 2008
    2007 A4 2.oT MT S-line Ti
    Vancouver BC
    I don't have the courage to do this, but I admire your attitude of the doing the project.
    Sure it is easier to sell fwd and buy an awd but I understand it as a passion of modifying cars, same reasoning as selling audi for honda for more power.
    whatever it comes out, let us be posted!!
    best of luck to you!
    Sponsored by VMR
    2007 Imola Yellow A4 2.0T S-Line Ti 6sp.
    235/35/R19 RS4 Replica. Bilstein Shocks. GIAC 93X. Rear Windows Tint. Lamin-X Smoked Tail light/Fog light. Metallic Black Rear Rings. Debadged.
    2004 Imola Yellow TT 1.8T Tip. Gone but not forgotten.
    ________________________________________
    Everyday is a gift, that's why we call it present.
    Apr 18 2008
    Jacksonville, FL
    ...and...turning the engine 90 degrees...
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Four Rings LimiTed's Avatar
    Oct 13 2006
    Bay Area
    wow. can i send u my quattro badge? u have balls for doing this.
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    Thumbs up Re: It finally has begun FWD to AWD
    SUBSCRIBED FOREVER!!!!!!!!!!!!!
    Please keep us updated on the progress!
    U are going where none of us have gone before!
    Have you ever seen the movie...
    The Secret?
    This guy is amazing!
    Six Minutes Can Change Your Life! Find Out How.
    http://store.sixminutestosuccess.com/?aid=590822
    Jan 27 2007
    NC
    Quote Originally Posted by minameismud View Post
    Wrong the motor is longitudal...in the B7's
    vizi
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    you beat me to it. By almost an hour.
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Jan 27 2007
    NC
    Quote Originally Posted by Alkemix View Post
    Lol..... i was wondering what he was talking about at first because my brain was fried out from all the work...lol
    vizi
    Jan 27 2007
    NC
    Ok i got everything back together with pics from along the way for got to snap a few but no big deal... But to my question...
    I have the STASIS QT Exhaust and when i installed it i first put the entire exhaust on with the bolts and all very losely and the tightened it from the front to the rear and i noticed the the exhaust rest very firmly on the rear crossmember bar ( That bar may not be there on a Qt if anyone wants to check for me) and the exhaust also rides against the rear CV joint gaurds. Is this common on the after market exhausts because the pipe diameter is larger than the stock one.
    Where the 7" crossmember bar attaches to the body don't know it the QT has it or not but need to know.. Pic shows where it hits and there is a lot of preassure on that bar frpm the exhaust....
    Here is the Exhaust hitting the CV Heat shield/Protector.....
    vizi
    Jan 27 2007
    NC
    Here are some pics.. More to come..
    My Sending unit. Can anyone tell me which connector pin is the POSITIVE side and which is the NEGATIVE side?? Or have a wiring diagram?? i gotta figure out with this harness thing for a temp gas guage until i can get the correct harness..
    Pass Side Electrical Connections.
    Driver Side Electrical Connections.
    Electrical Connections pass through inside of car.
    vizi
    Apr 18 2008
    Jacksonville, FL
    Quote Originally Posted by viziers View Post
    vizi
    thought it was mounted transverse in FWDs. my bad.
    SOLD 10/2011
