    Registered User Three Rings Jason@Addict's Avatar
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    CK04 (China K04) Testing: Boost Creep FTL
    How's 7psi boost creep by redline sound?
    http://forums.quattroworld.com/s4/msgs/10969.phtml
    Account Terminated Two Rings
    May 25 2007
    Stage 3 EPL 2001.5 B5S4
    Madison, WI
    Re: CK04 (China K04) Testing: Boost Creep FTL
    Man that looks like poop...
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    No surprises.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    From what I just read in that link, they said the turbo's themselves are solid... just the boost creap issue due to the wastegates not flowing enough. That could be solved mybe by some porting etc...
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    That's awesome, they even checked at what pressure the wastegate diaphrams break...very in-depth.
    So, too small of a wastegate opening causing boost creep (possibly needing a port and/or new flapper etc...custom work anyway), the possible need for a new tune (depending), not receiving them clocked correctly, and not even knowing if they're all manufactered the same...or whether they'll back you up in a warranty situation etc?
    Seems obvious to me, but I guess I could see why some of the adventurous might give it a go...not I.
    Brilliant Black 2001 S4 - 6MT <3
