Results 1 to 37 of 37
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Painting USP Wheels *DIY Content*
    I made this for those that want to do this but are afraid it will turn out bad. Enjoy.
    I am showing you how to do this on one wheel, obviously it applies to the other 3.
    Stock wheels with a little curb rash.
    This is what you will need to do the job right. 1 roll of painters tape, 1 pack of 80 grit sandpaper, 1 pack of 400 grit sandpaper and 1 pack of 2000 grit sandpaper, 1 can of Duplicolor Filler Primer, 1 can of Duplicolor wheel paint (I used black caliper paint, it's the same exact thing as wheel paint), 1 can of Duplicolor clear wheel paint, 1 bottle of degreaser and 1 roll of paper towels.
    1. Use the 80 grit sandpaper to sand out all the curb rash on the wheels. Once you get that out use the 400 to sand it smooth to the touch and the 2000 to make it glass like. It should look something like this.
    The curb rash is gone.
    2. Take your degreaser and clean the wheels very well. Anything you leave on there will be trapped under the paint.
    3. Use the painters tape and tape off anything you don't want painted. I took the center caps off prior to this so I only taped off the valve stems and tires.
    4. Apply light even coats of the filler primer waiting approximately 5 minutes in between coats. Continue coating until the whole wheel is covered. Make sure you don't try to cover the wheel in 1 coat. This will cause runs and the paint will take forever to dry. It should look like this.
    5. Allow the primer to dry by waiting approximately 1 hour and then spray on the color you want. Use the same painting method of spraying light even coats until the whole wheel is covered. Now they should look like this.
    Allow the wheels to dry overnight to let the paint cure and your ready to put them on. They should look something like this. I took these photos with the flash on to show you the glass finish and the lack of curb rash. The wheels are actually black.
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    Re: Painting USP Wheels *DIY Content*
    Looks good. Still don't know how I haven't seen your car around yet.
    Stretched, poked, and slammed.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Nice job, but that Duplicolor paint sucks if you want to refinish them in silver, it's way too sparkly. I used it and had to redo my wheels with Wurth laquer paint, much better color.
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Very nice
    Im doing mine this weekend. Did you use just regular sand paper for wood or something different?
    Approx. cost to do ALL 4 weels?
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Aug 24 2005
    Cali
    a couple questions:
    Did you sand down only the curb rash?
    Did you spray the center caps? If you did, did you spray the entire thing?
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Very nice, is that semi-gloss?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    looks nice i wanna paint my stockies white. u didnt use any fill for the curbrash?
    Joooe Mamma!
    Jul 04 2008
    York, PA
    Quote Originally Posted by Trev View Post
    Very nice
    I just used regular sand paper. I spend about $25 bucks total on the supplies.
    Quote Originally Posted by dunggah View Post
    a couple questions:
    Yes, I sanded down only the curb rash. No, I didn't spray the center caps yet but I want to paint them all black and leave the rings chrome. When I do that I'll post pics.
    Quote Originally Posted by Charlescrs6 View Post
    It's gloss black and clear coat on top of that.
    Quote Originally Posted by pa4ul View Post
    No, I didn't need to. It came out with just sanding.
    Nov 25 2007
    So $25 will do all 4 wheels?
    Some Go, No show
    Wish List
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    congrats now it looks like every other black wheel out there. Personally i woulda repainted it silver but thats just me
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    i dunno if that is the problem with spray paint, but the interior of the rims are not yet covered i duuno if u are goiing to cover it later on...anyway good job, but i sure will let a professioanl to do my rims if i want another color
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
    Jul 04 2008
    York, PA
    Yes
    Quote Originally Posted by eurogruppe View Post
    And have it look like every other silver wheel out there? No thanks.
    Quote Originally Posted by 18tboost View Post
    I'm not worried about the interior of the rims since these are stock wheels and you won't see the inside of the wheels when they are on the car.
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    looks good one day i will man up and do mine
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    one of these days i will do mine lol... i just keep changing my mind about selling the car or not...
    My Cars...
    1998 Honda Civic Ex... *sold*
    2004 Audi A4 1.8T Giac Stage 1+ *current*
    *Honda Cbr 600rr* Springtime
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    If you didn't spray the clear coat on, would it have looked matte black?
    I'm trying to re-do my rims -- the job that's on them right now isn't that great.
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Looks good....you should have painted the barrels though
    -Sami-
    Jul 04 2008
    York, PA
    Quote Originally Posted by Shak View Post
    No, I used a gloss black paint to begin with so even if I didn't use clear it would have been glossy.
    What are barrels?
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    barrels= inside of wheel
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Jan 06 2009
    For the spraying process, I found it easier to deflate the tires and insert cardboard cards in between the tire and wheel. You can buy them or just cut up some cerial boxes.
    In the past I have had good results with the painting process with that duplicolor paint/clear however it does not last. That paint chips away very easily. I also had one can of bad clear coat which ruined the finish (dulled the gloss black paint).
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Nice job I'll be sure to refer to this when I refinish mine.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Jul 04 2008
    York, PA
    I think I am going to go back and paint the inside of the wheels as well.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    shameless plug of my rattle can rim thread...
    http://www.audizine.com/forum/showthread.php?t=199801
    DO paint inner part of wheels, makes a world of difference. I filled instead of sanding down through chips, but i didn't have major rash on mine. probably a combo of both to get the best result.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Can anyone recommend an almost exact color match to that of the OEM Silver. Mines were pretty eff when i bought them, Thanks.
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Three Rings Ultra B6's Avatar
    Sep 05 2007
    New Jersey
    just a hint to do the barrels, go around the them with 100-150 grit to get everything clean, wipe clean with spray cleaner and paper towel
    and as much of a pain as its goin to be, you should tape off the spokes so you dont get over spray on the face that you just painted
    -James-
    04 Dolphin A4 USP CLUB MEMBER #84 3.0 QUATTRO TIP
    MODS:
    Pics:http://s231.photobucket.com/albums/ee167/ultrab6/
    Deactivated Four Rings
    Sep 30 2008
    n/a
    should have painted the inside of the wheel first matte black or whatever black you used then did the outside
    Dec 08 2006
    Jersey
    Quote Originally Posted by 4Rings3Liters View Post
    Yes
    You can definitely see the inside of wheels with open spokes and the spokes on USP wheels are open enough that they need paint. I left mine because they are only winter wheels but I will probably do it next year
    Quote Originally Posted by El_Chapusca View Post
    Wurth Wheel Paint, it's expensive but trust me on this. Do it right or do it twice. I had to do mine twice . As I mentioned befor ethe Duplicolor has sparkly crap in the paint, it's close match from far away but as you get closer it's not as close. Wurth is almost spot on, I think after I buff them it will look even closer. Don't cheap out, get the Wurth clear coat too, helps bring the color out more.
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    I think the USP looks best like this. Sort of stealth. However, if those Sumitomo's are HTR+'s, I'd get rid of them. Theyre either good on tread or blown up. no in between :/ went through 3 in 9 days
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Mar 20 2008
    south
    i painted the barrells sliver to match my rims and it enhances the wheel so much more i get a pic up when i off work
    Joooe Mamma!
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    YOU FORGOT THE BACK HALF OF THE RIM!
    HA im just kidding
    there already caked with brake dust that will probably outlast the time the paint sticks onto the wheel. and its black already!
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    My non-usp came with the 16" wheels when I first bought it. We don't have "winters" around here or anything but I'm thinking about getting the wheels I have now worked on a little bit but before I do that, I want to paint my stock 16's something a little crazy, like lime green or gold or something.
    This is a great write-up!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    So when you used black for the finish you waited an hour for it to dry then put clear coat on and thats it?
    2018 Mercedes GLC 300
    Mar 20 2008
    south
    Joooe Mamma!
    Jul 04 2008
    York, PA
    Quote Originally Posted by NorCal1.8T View Post
    I waited a few hours to put clear coat on and then I let them sit overnight.
    Jul 04 2008
    York, PA
    I finally got around to painting my center caps too. I was hesitant about doing it because I wanted to leave the Audi rings chrome but I didn't feel like taping them off. It turns out that the rings come off so it made the job super easy.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Looks great Want to see pics on the car!
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    ...anyway good job, but i sure will let a professional to do my rims if i want another color
    Dude...if you take your time and are meticulous with your prep then you can do just as good a job yourself. I painted my MTM Bimotos flat black and NOBODY can tell its a DIY job. In fact it looks better than other wheels I've seen that were done professionally. If I had to pay someone to do it I'd probably elect to have them powdercoated instead. Of course that would involve unmounting the tires, re-mounting and re-balancing.
    The Duplicolor product is nice and goes on easily. I haven't tried the Wurth paint, but maybe I will if it comes in flat black!
    Nice job on the wheels and caps. Lets see them on the car please! Its hard to get a sense of them because of the flash.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Aug 25 2007
    B6 S4
    Can we see some pics on the car plz?
    Also for reference, the duplicolor code to match the stock usp silver is T191 Truck/Van/Car Ultra Silver. The Wurth is probably better I just hate waiting for shipping.
    -Nick
