Page 1 of 4 123 ... LastLast
Results 1 to 40 of 159
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Post DIY Fuel Filter B6 A4
    Alright so I looked everywhere on Audizine for a DIY for a fuel filter replacement for my b6 a4. No luck! Ended up going to Audi World, so I decided to make one for this website.
    It doesn’t make any difference because this is pretty much the same for all B6’s but mine is a 3.0 v6 with FWD.
    ** NOTE: Something VERY important is the fuel filter, don’t go to ECS tuning or any other website for your fuel filter, because there are THREE different types of them for this car… I bought my first filter at Kragen, and they sold me one with one in hole and one out. Went then to ECS, same deal, so I had enough and went to the dealer. The parts guy told me at the end of the part number (8EO-201-511____) there is a letter, it will either be G,L,J,D! The L is the new G, so if you have a G there going to give you an L. To find out which one you have the dealer will look it up with your VIN. The three types look the same, just the sizing of the inlet and outlets are bigger/smaller… pain in the rear! **
    Parts you will def need:
    1x OEM Fuel Filter
    Gloves, I had 2 kind; nitrate dipped for when the fuel was present, and some leather ones to grip the tools and keep clean.
    Goggles! Big time MUST HAVE!
    10mm socket
    Torx 25
    Small flathead
    6-8 Rags + bucket (opt)
    Install Time
    It took me about 45 minutes
    Process:
    1. Find a way to get your car’s rear end off the ground. You may consider using jack stands, or like I did use drive up ramps, and reverse onto them. Make sure that it doesn’t hit the mufflers or any pipes.
    2. To gain access to the entire wiring and fuel filter you have to remove the black housing around it, its simple just take the 10 mm socket and remove the nut that is located right on the end of the skirt molding, then right by the front of the rear wheel you will see two torx screws, remove them as well. To the left of the filter you will see a black “plug” looking screw made of plastic, take the flat head screw driver and pry it out.
    3. Now that the plastic covering is off you will see the entire filter and all the fuel lines. Take your TORX 25 and un screw the filter from the enclosure. Once you do that, you will need to dislodge the brake line running right to the side of it. That is done by pushing up on the line evenly on both sides so that we don’t bend it and then once out letting it hang down. Once that line is out of the way your going to need to “play” with the filter to get it out of that housing.
    4. Alright breath.. Your 50% there! Ok so while your up taking a breather from being stuck down underneath the car, unscrew the gas cap a little and leave it like that. (It will get rid of any pressure that has accumulated in the tank)
    5. Go underneath your car again, because now the fun begins! Now to remove the lines from the filter, its really simple take your flat head and push the clamps in on the hoses. Before you disconnect them, make sure you have plenty of rags, your goggles on, and the new filter in hand. Like you see in the photos, it is a good idea to keep one side of the filter plugged up with the yellow caps that came with your filter.. Trust me, it stopped the leaking and gave me time to unhook the other side of the old filter off.
    6. Once you have removed the old filter and have installed the new one you MUST check for leaks by pulling on the lines and seeing that they are truly connected.
    7. Your done! Now all you got to do is put everything back. Start off by mounting the fuel filter in the housing, then putting back that line on the clamps. Lastly put that plastic cover on (includes two torx 25 screws, a plastic cap, and the 10mm nut) Oh and don’t forget to tighten up the gas cap again or the MIL light will turn on!
    -- Start her up… might take 2-3 starts to get the fuel pumping in her veins again but she’ll start right up purring like new --
    Just thought you might want to see what was inside the filter; just look at that dirt! By the way, this car has only been filled with 91 octane and still Premium has all this! Yuck!
    Well that’s all, enjoy your ride for the next 30k until this has to be done again! Hope you are happy with the DIY!
    BTW the gloves and goggles were bought from www.Liftsafety.com I have to say they are the BEST gloves I have ever owned. Not only are they built really well they are well priced and they work great for car repairing and more!
    Registered Member Two Rings wunder wagon's Avatar
    Nov 04 2007
    03 A4 1.8T 5MT Avant quattro
    Arkansas
    Re: DIY Fuel Filter B6 A4
    great DIY and thanks for posting it.
    In regards to the Lift gloves you have. I have average to just a tad large hands (palm width is 4" and I usually wear Large gloves but will go down a size for a tighter fit). Since Lift doesn't have any sizing chart what would you recommend based on the pair you have?
    EDIT: ordered me up a pair of the Large size...at only $4.50 for a pair they're too cheap to pass up. They also have a pair of nitrile gloves with only the palms coated for better feel.
    1.8T Avant quattro| Official AR Thread | Deviant:Speed
    Veteran Member Three Rings IOKEPA's Avatar
    Jun 03 2004
    2003 A4 1.8T Quattro
    CA
    BTDT... welcome to 2006! here's my original DIY posted on AudiWorld and AudiGeeks, and also linked here many times :)
    http://forums.audiworld.com/a4gen2/msgs/917681.phtml
    Feb 27 2008
    Btdt?
    Feb 27 2008
    Quote Originally Posted by wunder wagon View Post
    Glad you liked them! If you have any problems with them let me know! I work for there "brother" company EVS Sports, so anything on your mind or if you want a catalog, etc PM me!
    Jun 03 2004
    CA
    Quote Originally Posted by Frey7190 View Post
    Btdt?
    Been there, done that. Just saying a DIY already existed, but unfortunately you weren't aware of it
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    I just changed mine about 3 weeks ago.
    It's a pretty easy part change once you figure out those annoying clips.
    I got my filter from http://www.genuinevwaudiparts.com/
    You can enter your vin when ordering to make sure they send you the correct part.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Honestly I only payed 10 bucks more for the part at the dealer
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by Stockton View Post
    I still dont get why people think theyre annoying..
    You get a flat head and jam it in the colored part or the bump and yank off at the same time
    Mar 04 2008
    Palm Beach Co, FL
    Quote Originally Posted by audipotential View Post
    Well cause the first time I did it, it was getting dark and I was alone and couldn't see the clips very well and I didn't understand how they came off.
    Now that I know it's a very simple thing to do for next time. Just the first time without being sure of exactly how they work and being under the car with gas in my eye was frustrating.
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    I might have missed it but did you relieve the pressure in the fule line first????
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    Quote Originally Posted by IOKEPA View Post
    Yeah your DIY (sorry OP) was much more informational. I changed my fuel filter in about 30 mins thanks to that.
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    Feb 27 2008
    Quote Originally Posted by windyctyaudi View Post
    You know I just couldn't find the relief valve on my car... Its the 3.0 and I looked everywere on the fuel rail system. No luck, so I just decided to undo the fuel filler cap, and hope that would be enough..
    When I took the Fuel filter lines off there was NO pressure! I was bracing myself for streams of fuel to be gushing out and losing about a gallon of gas in the process, but i only lost about a half of a water bottle.
    The hoses when disconnected seemed to just drip slightly never did they stream gas.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    i have the purems one and its not audi brand it is an oem equivalent. it works fine. matter of fact i know its the same cause i get the same lean codes the same time of the year as the last "audi original" part.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    very very well written, i will have do this soon i started to hear a whine.
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpinewei 325iC
    Mount Rainier, MD
    I got my filter from ECS and I don't see how anyone could screw this up! They state pretty clearly that there are several different parts and even where the split is (in the 2005 year I recall). It was like $15 cheaper than the dealership and I didn't have to go there!
    I will agree that the clips that hold the lines on were confusing to me too...being upside down and never having encountered this type of retaining clip before! I may have messed oen of them up but a well placed hose clamp made all well (I'll probably replace the hose/clamp assembly next time I'm under there and feel like getting petrol all over the place.
    No more humming now...in fact I wouldn't wait for the humming to even start! This is going to be part of my normal maintenance plan from now on...at least every 40k.
    boy412
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    alright... so I am attempting this for the first time. I am having a lot of trouble with those clamps. I have broken one of the clamps (black) and it still will not slide off the old filter. Does anyone have some idiot-proof advise on how to remove this little piece of German engineering?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by csondaatje View Post
    Try pushing the fittings in toward the filter before depressing the tab on the side of the fitting. This takes some of the pressure off of the fitting and it will release easier. If you can't depress it with your finger try using the side of a straight blade screwdriver.
    Good luck
    Registered Member Two Rings LateApex's Avatar
    Apr 10 2008
    Blk/Blk B6A4 TQ 6M
    Alb, NY
    [QUOTE=Frey7190;2524640]I was bracing myself for streams of fuel to be gushing out and losing about a gallon of gas in the process, but i only lost about a half of a water bottle.
    QUOTE]
    So did you only have the water bottle to catch the fuel? Thats baller.
    ....nice write up btw
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    But your pics are gone.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    Thanks! finally got it off. I was putting the flat end of the screwdriver in the WRONG side of the clamp. I now see that all I needed to do squeeze the back side of the clamp in my fingers and it released. Anyone know if Audi sells those hoses separately? I broke one of the fittings and now it blows off when I try to start my car.
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    That's exactly what mine looked like last week when I did it. Those little clips that you press down were a pain in the ass for me, eventually the came loose though. Great DIY, could have used it last week though. haha
    WTB K04 turbo ASAP
    http://etektuning.com
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    I agree great Tut/write up! Thanks!
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: Used diy thread and now car won't start help!
    Make sure you didn't get the breather line mixed up with the fuel line. (the line with the Blue connects to the centre "inlet").
    I hate to admit it, but when i changed my filter, i thought i payed attention to which lines went where...but for some reason i still reversed them and it didn't start first shot.
    Quote Originally Posted by avantdaddy View Post
    I have an 03 A4 1.8T Q Tip, it has a GIAC chip installed I checked the correct part number for the new fuel filter, using this link http://www.audizine.com/forum/showthread.php?t=224783
    Now the car won't start, my car is on it's 3rd fuel pump from the recent recall on it. The original one died, was replaced under warranty, then I had it changed again under the recall.
    From the instructions it does not sound too difficult, the filter only goes in 1 way and I only transferred fuel line connections one at a time, and made sure they were on securely 3x. Also tried reinstalling the old fuel filter and it still would not start.
    When disconnecting the lines the main line marked RL at the rear of the filter has pressure and fuel spilling out of it, and the VL line next to it has a little fuel coming out of it, but the 2 other lines on the filter facing the motor are dry when I disconnected the new filter?
    I do not here any humming from my fuel pump when the key is on the on position? Checked the fuse for the fuel pump and it is fine. Could it have died again?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Jan 28 2008
    03 A4 Avant 1.8TQ Tip,98M3/4/5
    Chicago
    Quote Originally Posted by mattman View Post
    Thanks, I did make the same mistake!
    Jan 28 2008
    Chicago
    THANKS FREY7190 for this helpful DIY!
    Feb 27 2008
    avantdaddy, your welcome! I will be making new ones on other things... If you have ideas on a DIY you would like... Chances is I've already attempted it ( i have taken the whole engine apart) so just name it and ill DIY it for you guys just let me know..
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Oct 13 2006
    04 A4 USP
    Naperville, IL
    I didn't read the whole thread, but wanted to point 2 things out. The first picture you posted with the arrow pointing to the filter is misleading, it makes it look like the filter is in the back of the car when it's actually under the passenger rear door. You might want to edit your DIY to clarify that, it took me about 5 minutes of searching before I had to pull up this DIY on my laptop and figure it out.
    Sencond, capping the end of the new filter is a good idea, but also keep the caps that were removed handy to cap the existing fule line once you pull the 1st set of lines off. While trying to remove the 2nd set of lines the fule will drip from the filter and the caps that were removed from the new filter will stop the dripping while you remove the last 2 lines. I had to do this once I realized the existing filter wouldn't stop dripping, and had soaked my rag that I had placed under the car.
    Just thought that would help. Thanks for the instructions otherwise.
    USP CLUB MEMBER #33
    Established Member Two Rings VisionPaintball's Avatar
    Jun 26 2007
    Keyport,NJ
    Thanks for this.
    I just did my wifes car in about 20 min. My torx size was t-20 not t-25. I didn't have to move the brake line and it was really simple.
    My car is next.
    Thanks again!
    '02 B5 S4 Avant
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    why is your fuel filter different than mine? we have the exact same car.
    i just had my filter changed
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 27 2008
    Quote Originally Posted by Maverick View Post
    What do you mean... How exactly are our filter different??
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Nice DIY
    Veteran Member Three Rings AvantinUSP's Avatar
    Jul 28 2008
    Can I get a clarification of how to get the hoses off for both sides? In the "in" hoses there are those little blue and black clips which I had a hard time with and ended up braking the plastic. In the "out" side there is nothing. How do you get these off?
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by AvantinUSP View Post
    there are little "buttons" i guess you can call them on each line. you can push them in with your fingers but not very far.... so use a flathead screwdriver to push those 'buttons' in, then pull the line off the filter.
    Meet Shanice...
    For Sale:
    Jul 28 2008
    Ok. But on the other side there are no "buttons" What about them? (on the right side of the filter on the pictures above or front side of car)
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Nice DIY! Isn't there a bleeder on the back of the fuel rail on the 1.8t? Like a Schaeder valve or something that I vaguely rememeber seeing.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Oct 23 2007
    Ontario, Canada
    i believe you just squeeze the collar of the connector and pull.
    Meet Shanice...
    For Sale:
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    So you just squeeze the blue "button"?
    [IMG][/IMG]
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Quote Originally Posted by 80CID View Post
    [IMG][/IMG]
    Yes, squeeze and hold so you can get the hose over the "lip" of the fuel filter nipple.
    GO KNIGHTS!
    Jan 25 2009
    Long Island,NY
    [IMG][/IMG]
    Whatever you doo. DONT PRESS DA BLU BUTTON.
