Results 1 to 4 of 4
    Junior Member One Ring
    Feb 18 2025
    Stellenbosch, South Africa
    Headlight adjustment
    Hi all. I知 having a little bit of trouble adjusting the headlights on my b6 a4. They seem to be pointed too far outwards. Well at least the brights are noticeably too far outwards. I have tried to manually adjust them but it seems that the two hex adjusters adjust the height of the brights and low beams separately and there is no horizontal adjustment. Can anyone inform me on if I知 doing something wrong or if that is just how they are supposed to be.
    Thanks
    Established Member Two Rings kevin1980's Avatar
    May 20 2013
    Hardenberg ( NL)
    Quote Originally Posted by Matt_Stander View Post
    Thanks
    is this of any use to you?
    2 is horizontal
    Verstuurd vanaf mijn SM-S911B met Tapatalk
    Feb 18 2025
    That is so weird. I tried again to adjust and none of the adjusters move horizontally at all.
    May 20 2013
    Hardenberg ( NL)
    Maybe they turned too far and came out of their mounting
    Take out the headlight and look at the back to see if you can see anything
