Hello,
A few weeks ago I noticed I was getting no heat and car had a coolant smell. Nothing was leaking on the floor but can see the trans was wet with coolant. I found the coolant flange was leaking and also the bottom heater core hose looked like it was starting to tear. I replaced the hoses, coolant flange and temp sensor. Bled all the air out of the system with radiator bleeder funnel and upper rad air release in hose. The car seemed good for about 3 days then noticed no heat again.
This went on for about 2 weeks then the issue kept repeating but never overheated until recently. I overheated 2 times and the thermostat gauge went to 3/4s for about 5 seconds then back to normal once it spit out coolant from the overflow cap. This was done on tests just around the block and I stopped driving it after the second time it did a 5 second overheat. I thought maybe it was a bad cap which did the same thing after replacing with OEM. I did a head gasket test and showed positive blue to yellow so thought it was the headgasket went bad. So i was going to attempt it myself, upon taking the head off i noticed cracks in the intakes immediately then see cracks between the intakes and exhaust on 2-3.
Would overheating twice to 3/4ths on the temp gauge for 5 seconds cause the head to crack like that?
Intake 1
https://drive.google.com/file/d/1Sn3...ew?usp=sharing
Intake 2
https://drive.google.com/file/d/1Rs7...ew?usp=sharing
Intake 3
https://drive.google.com/file/d/1Ak7...ew?usp=sharing
Intake 4
https://drive.google.com/file/d/1mmD...ew?usp=sharing
Vid
https://drive.google.com/file/d/1AJy...ew?usp=sharing
Around 6 years at 130k I had a ton of work done to the car from Audi of Mt Vernon NY which royally ripped me off and never was right since -5k. (very bad experience if anyone is interested) Had timing belt, water pump, coolant flange, MAF, themostat, got the car back and over heated within 10min to full hot and brought the car immediately back to them. They kept the car for about 3 weeks and told me i needed a headgasket which i agreed to. After getting the car back for the second time after the head gasket was done the car seems to lack any power and Audi said they refuse to work on the car anymore and recommended me to rid of it. They offered me $500 trade in value after charging me 5k in repairs which made me furious. The car now has 160k seems like the repairs didnt last so they were right I guess. But whats wierd is i remember the head saying AEB but noticed it doesnt have any markings so Im wondering if they replaced the head back then when they did the head gasket and why it took them 3 weeks. Anyways was going to try and get a used head, attempt the job myself to make the car work again but not sure its worth it.
