Background - when I was out of town for over a month, my neighbor took my 2008 Cabrio without my permission or knowledge. I don't know how much she drove it or what may have happened during that time - all I know is that there was physical damage to the seats and interior, and, something was run over, causing the A/C line from the compressor to the drier to be shredded. I got estimates on repair, but thought I'd just do without the A/C.
Since then, I've started to have a lot of other problems and symptoms. When I turn the key to ACC, there is a loud clicking coming from the center dash. This has been consistent, and mechanics have just shrugged. Then I had a no crank/no start, replaced starter, but car was stalling immediately, replaced PVC and purge valve, after driving a few times kept stalling again just after start, the EPC light/codes, and the fan would start immediately, and very loud. After fiddling with it, checking relays/fuses/codes, it will often start and run fine, but only for a few drives. Then, the next day, it stalls right after starting.
I'm fed up with the numerous mechanics I've used, who just want to replace mechanical parts or the ECM.
Where would you start? Could the A/C system be at the root of most of this? Can I safely bypass the entire climate control system, or does it tie into engine cooling, etc? My battery is technically good, but is due for replacement - not sure if I should do that prior to more troubleshooting? I also realize that some of these codes may be due to having the battery and ECM disconnected, so I am thinking that the static codes are the ones to attack first?
Thank you in advance.
¯{"LB":"Audi Cabriolet USA/CAN 2003>->2008 (8)->Cabrio->BWT 2.0 L Turbo Motronic / 147 kW->Diagnosis->Quick Scan","Lang":"en","VehicleName":"AUDI","Version":" 1.0","JVer":"1.0"}
;{"DATA":{"UT":"AS","VID":"StartAutoScan>100","TT" :"Quick Scan","WU":false,"STAT":-1,"LB":"","IDX":0,"CNT":0,"CS":-1,"WR":[20,20,60],"IS":[{"ID":0,"LB":"01-Engine Control system","VA":"Fault | 2","STAT":1,"IES":[{"DID":"08753","STAT":"","DDE":"O2 Sensor Bank 1 Sensor 1,Signal Circuit Shorted to Heater Circuit - sporadic 004-No Signal/Communication"},{"DID":"05634","STAT":"","DDE":"Po wer supply terminal 30,Voltage too low - sporadic 002-Lower Limit Exceeded"}]},{"ID":1,"LB":"02-Auto Trans Control system","VA":"Fault | 1","STAT":1,"IES":[{"DID":"49408","STAT":"","DDE":"Lost Communication with ECM/PCM"}]},{"ID":2,"LB":"03-ABS Brakes Control system","VA":"Fault | 2","STAT":1,"IES":[{"DID":"01826","STAT":"","DDE":"Sensor for Steering Angle (G85): Supply Voltage Terminal 30"},{"DID":"01314","STAT":"","DDE":"Engine Control Module - sporadic 004-No Signal/Communication"}]},{"ID":3,"LB":"08-Auto HVAC Control system","VA":"Fault | 5","STAT":1,"IES":[{"DID":"01273","STAT":"","DDE":"Fresh Air Blower (V2) - sporadic - Open/short circuit to positive"},{"DID":"01172","STAT":"","DDE":"Tempera ture Sensor: Driver's Heated Seat (G59) - static - Open/short circuit to positive"},{"DID":"01172","STAT":"","DDE":"Tempera ture Sensor: Driver's Heated Seat (G59) - sporadic - Short circuit to earth"},{"DID":"00819","STAT":"","DDE":"High Pressure Sensor (G65) - static - Open/short circuit to positive"},{"DID":"00819","STAT":"","DDE":"High Pressure Sensor (G65) - sporadic - Signal too low"}]},{"ID":4,"LB":"09-Cent. Elect. Control system","VA":"Pass | No Fault","STAT":1,"IES":[]},{"ID":5,"LB":"15-Airbags Control system","VA":"Fault | 2","STAT":1,"IES":[{"DID":"00532","STAT":"","DDE":"Supply Voltage B+ - sporadic 002-Lower Limit Exceeded"},{"DID":"01316","STAT":"","DDE":"ABS Control Module - sporadic 004-No Signal/Communication"}]},{"ID":6,"LB":"16-Steering Wheel Control system","VA":"Pass | No Fault","STAT":1,"IES":[]},{"ID":7,"LB":"17-Instruments Control system","VA":"Fault | 3","STAT":1,"IES":[{"DID":"01314","STAT":"","DDE":"Engine Control Module - static - Interruption"},{"DID":"01316","STAT":"","DDE":"ABS Control Module - static - Interruption"},{"DID":"01320","STAT":"","DDE":"Con trol Module for Climatronic (J255) - static - Interruption"}]},{"ID":11,"LB":"25-Immobilizer Control system","VA":"Fault | 3","STAT":1,"IES":[{"DID":"01314","STAT":"","DDE":"Engine Control Module - static - Interruption"},{"DID":"01316","STAT":"","DDE":"ABS Control Module - static - Interruption"},{"DID":"01320","STAT":"","DDE":"Con trol Module for Climatronic (J255) - static - Interruption"}]},{"ID":15,"LB":"46-Central Conv. Control system","VA":"Fault | 4","STAT":1,"IES":[{"DID":"01320","STAT":"","DDE":"Control Module for Climatronic (J255) - sporadic - No conmmunication"},{"DID":"01371","STAT":"","DDE":"A larm triggered by Door Contact Switch: Driver's Side - static - No indication on display"},{"DID":"01572","STAT":"","DDE":"Alarm triggered by Door Contact Switch: Passenger Side - static - No indication on display"},{"DID":"00955","STAT":"","DDE":"Key 1 - Intermittent"}]},{"ID":16,"LB":"55-Xenon Range Control system","VA":"Fault | 1","STAT":1,"IES":[{"DID":"01314","STAT":"","DDE":"Engine Control Module - sporadic 004-No Signal/Communication"}]},{"ID":17,"LB":"56-Radio Control system","VA":"Fault | 1","STAT":1,"IES":[{"DID":"00857","STAT":"","DDE":"CD Changer Unit (R41)"}]}]}}
