Results 1 to 7 of 7
    Oct 14 2022
    US
    CODE: P1B1C (coolant pump mechanical malfunction)
    Yesterday, received a fault on the dash: "Turn off engine and check coolant level".
    Pulled over and checked under the hood:
    • Coolant in the reservoir was between the min and max lines.
    • Engine didn't appear overly hot (operating temp normal).
    • No Smoke.
    My coolant gauge on the dash was perfectly in the middle where it always is (no drifting).
    I drove the car home 2-3 miles, plugged it in and found the code: P1B1C (coolant pump mechanical malfunction); I clear the code.
    Today, received the same fault, at the same location (about 2 minutes into my morning drive), which makes me think its an issue with the thermostat (opening/closing the t-stat at that point when the car is up to operating temp and needs to cool) versus a faulty sensor. But both seems to be a fairly common failure point reading the forums, as well as a nearby vacuum solenoid?
    Is there anyway to test this more thoroughly to confirm the failure point? I have VCDS and can log, but what should I log to verify?
    Thanks.
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    More than likely the sensor is going bad in the coolant tank.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Junior Member One Ring
    Dec 23 2017
    Greencaslte, PA
    I wouldn’t go buy parts based on my experience alone… but I had the same code on my 21’ SQ5 at 48kmiles and the dealer replaced the coolant tank under warranty and the issue was fixed. I presume the sensor was part of the tank.
    21' SQ5 (Quantum)
    19' S5 (wife's daily driver)
    15' SQ5 (sold - drove it like I stole it)
    13' Q7 (Puppy Hauler)
    09' A4 (daughters first car)
    92' S4 (in storage)
    Established Member Two Rings B8A4Kevin14's Avatar
    Jun 20 2017
    RIP:2014 A4 2.0T/RS Grille/APR Stage 2/19" Black Alzor 349/Custom S4 custom Exhaust
    White Plains NY
    There is a TSB on the water pumps:
    https://static.nhtsa.gov/odi/tsbs/20...07223-0001.pdf
    You can find a lot of info here:
    https://www.audizine.com/forum/showt...0#post15127720
    Oct 14 2022
    US
    Took the car out again this evening and no fault/codes… same route plus another 5 miles…. maybe it is a sensor… but incredibly coincidental the alert popped off two days in a row at the same location
    May 03 2010
    2012 TT Sold
    Maine
    Sometimes they do get a little build up and may have come off.
    Nothing was changed with coolant? Also how long since its been flushed?
    2002 A4 1.8T - sold
    Oct 14 2022
    US
    The fault popped off again today (same spot) on the morning commute. Logged the coolant temp—it never went above 98c.
    It seems to only happen after a (overnight) cold start.
    I ordered a new Coolant Reservoir, but it won’t be delivered for another week.
    Going to keep monitoring.
    To answer your question, it’s never been flushed on my watch (owner from 30k to 42k miles). The coolant still tests well, so this wasn’t on my to do list.
