Results 1 to 2 of 2
    Senior Member Two Rings REDa3STALLION's Avatar
    Jul 22 2021
    Orange County California
    URGENT HELP !!!!
    So lastnight I flashed my car back to ie's stage 2 non crackle cause I was tired of the pop sound from the stage 2 crackle 91 octane option well somewhere I went wrong apparently cause when I went to change the launch rpms it wouldn't flash and would say FLASH ERROR NEGATIVE ECU RESPONSE - SEND - 7F-22-31 and then this morning I went to start my car and it wouldn't start nor crank and I put my battery charger on the battery to see if it was a battery issue but even on the charger would start or crank so I dont know what to do or what's going on can anyone help me understand or point me in the direction to figure this problem out. I tried scanning for fault codes with the obd eleven and it didn't scan the transmission and wouldn't let me look at anything involving the transmission like live data etc etc.
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    You answer your own question. Something when wrong with the flash tune. Open a ticket support with IE with the information you provided that's your only option.
    Sent from my IN2017 using Audizine Forum mobile app
