Hi All,
The Problem:
This Clicking Noise started yesterday on my drive home from work - https://youtube.com/shorts/d2J-FZHaA...JgodFwoRHiXs7h
It only clicks when I'm going straight or turning slightly. The clicks coincide with my speed. Go Faster, clicking speeds up, go slower, clicks slow down.
The Clicking goes away on sharper turns or corners, as well as when I apply medium to heavy breaking.
Any clues as to what could be causing this?
Last Service:
I had my car in the shop on Feb. 7th. They did an oil change, new NGK Spark Plugs, as well as the 034 Stage 1 ECU/TCU Tune.
Their report showed that everything was fine except for some small amount of dried coolant around the water pump. I will be replacing the Water Pump, PCV and Thermostat this month yet.
