Hi all, I am facing an issue with my B8 S4.
1 month ago, I replaced both the SC & Crank pulley to IE's 57.5 & 188mm pulley & recently I encounter a chirping noise upon cold start
Got it sent in to the workshop later & was informed coolant pump is gone (Pump was replaced together with both pulleys & heat exchanger)
And now, I have replaced a 2nd coolant pump, 2 x tensioners & 2 x pulleys at the bottom of the engine & got the supercharger oil replaced.
Sound persisted, was recommended to change to a new belt by the workshop & was informed by IE belt number should be 7PK1320.
Despite changing to a new belt, the sound persisted and I am at my wits end thus seeking for help in the forum.
Link to the video and photos of the pulleys and tensioners changed as below
https://youtu.be/UtIoK9eJreg?si=72xLxrXbmtcpLzPq
https://ibb.co/8qDBnBc
