Results 1 to 21 of 21
    Junior Member One Ring
    Jan 13 2025
    Singapore
    ///HELP NEEDED/// Chirping Noise from Supercharger Upon Cold Start
    Hi all, I am facing an issue with my B8 S4.
    1 month ago, I replaced both the SC & Crank pulley to IE's 57.5 & 188mm pulley & recently I encounter a chirping noise upon cold start
    Got it sent in to the workshop later & was informed coolant pump is gone (Pump was replaced together with both pulleys & heat exchanger)
    And now, I have replaced a 2nd coolant pump, 2 x tensioners & 2 x pulleys at the bottom of the engine & got the supercharger oil replaced.
    Sound persisted, was recommended to change to a new belt by the workshop & was informed by IE belt number should be 7PK1320.
    Despite changing to a new belt, the sound persisted and I am at my wits end thus seeking for help in the forum.
    Link to the video and photos of the pulleys and tensioners changed as below
    https://youtu.be/UtIoK9eJreg?si=72xLxrXbmtcpLzPq
    https://ibb.co/8qDBnBc
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    Any chance your tensioner pulley is a bit loose?
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Jan 13 2025
    Singapore
    Hi! Thanks for the input. Now my mechanic is suggesting to replace a new supercharger. Lets hope it works.
    Veteran Member Three Rings PassionForAudi's Avatar
    Aug 10 2016
    4M.5 SQ7, B8.5 A4 (hey, I keep it clean, though!) and 5th gen’ Ram 3500 Limited Mega Cab (DRW).
    Orange County/Inland Empire, C
    Quote Originally Posted by sky0925 View Post
    At that point you’d been better off purchasing an entire new car. Guess it’s the love that counts!
    Jan 13 2025
    Singapore
    Haha, unfortunately cars are not cheap at where I am residing thus thats the only option!
    Aug 10 2016
    Yes, I know, man. Things will definitely ease up in the near future and I’m sure that you’ll get into something… Either that or as soon as I hit the lotto I get you covered for the car of your choice! 🫡
    Jan 13 2025
    Singapore
    Thank you 😄 Wishing you abundance luck in the lotto. 🍀
    Aug 10 2016
    Thank you Wishing you abundance luck in the lotto.
    Mar 31 2008
    eS-4
    CAL*SO
    i was chasing this noise for a couple months last year...
    currently using a 6 rib belt that has always worked.
    tried a 7 rib belt
    went down a size in belts to try and make it 'tighter'
    replaced both tensioners
    water pump/pulley
    idler rollers
    in the end, it was the alternator pulley causing the noise
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
    Senior Member Four Rings
    Jun 08 2021
    PA
    Check the actual crank pulley bolts while you're in there. Pull the supercharger belt off completely and start it. If it stops at least you narrowed it down to that belt or pulleys
    Jan 13 2025
    Singapore
    I replaced a SC and the noise still persisted. In the end we replaced back to a stock crank pulley and the noise stopped.
    I revert back to stock crank pulley, SC pulley and belt now the car runs fine.
    All that for nothing!
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    i have 187.x and 57.x pulleys. I use:
    https://www.ecstuning.com/b-ecs-part...lt/7pk1300ecs/
    paid $39.56 BTW
    Initially there was a chirp which soon went away.
    2011 S4 prestige. Imola 6mt.
    Jan 13 2025
    Singapore
    So a 7PK1300 belt can fit the 57.5 and 188m pulley as well?
    Am out of alternatives now. Sigh.
    Mar 31 2008
    eS-4
    CAL*SO
    alternator has a pulley...
    Jan 13 2025
    Singapore
    Alternator pulley is fine. Noise is gone after I got rid of the IE crank pulley and revert back to stock crank pulley.
    Mar 31 2008
    eS-4
    CAL*SO
    my bad, was going off your previous previous post.
    Jan 13 2025
    Singapore
    Thank you all for your assistance. It appears that the mechanics did not follow IE's installation guidelines, which resulted in an improper setup & causing the chirping noise.
    I am now seeking support from another workshop that is capable of properly calibrating the IE throttle body with their tuning expertise.
    Unfortunately, I have wasted a significant amount of time & money at the previous workshop, as they had assured me they could perform custom tuning for the IE throttle body and dual pulley setup.
    I would also like to check if anyone is running an IE 188mm crank pulley with a 57.5mm supercharger pulley and has experience with or without the IE enlarged throttle body. Does it truly make a noticeable difference?
    Mar 31 2008
    eS-4
    CAL*SO
    If you have ie and a cable (or vcds) you should be able to Calibrate the tb yourself. Their is no "custom tuning" if you have ie.
    A larger tb is ok, but without a ported blower to match, is kinda useless
    Jan 13 2025
    Singapore
    I had the car tuned to a stage 3 map as per the workshop's tuner with my dual pulleys (IE 57.5mm sc & 188mm crank) & heat exchanger upgrade.
    However he mentioned he was unable to calibrate the IE throttle body to my car thus the car was left running on IE dual pulleys, merc racing heat exchanger & stock throttle body.
    When the chirping noise surfaced 1 month later after the above works, I had the crank pulley reverted back to stock since it was causing the chirping noise & am running on a 57.5mm pulley now with a stage 1 map.
    Right now, I am thinking of going to another workshop to have the IE's 188mm crank pulley & IE's enlarged throttle body installed and have the car flashed with IE's map.
    However, my concern is the previous tuner did the tuning by benching my ECU & am worried that if I flash the IE's map, my ECU might get bricked.
    My options are really limited now with the previous workshop bringing me on a wild goose chase & apparently they did not follow IE's installation guide during the installation work.
    Mar 31 2008
    eS-4
    CAL*SO
    did you make sure you had the correct belt when running both pullies?
    Jan 13 2025
    Singapore
    Yeah I did. I bought a new belt with the same specs provided by IE.
