Results 1 to 10 of 10
    Jul 22 2019
    Houston
    Swapped Steering Wheel Help
    Hey guys I purchased a flat bottom steering wheel from a forum member for my 2013 S6. Originally my car had a round heated steering wheel. My mechanic swapped everything over this weekend and I'm trying to figure out if the * button will even work and if so can I program it to cycle through the drive modes, Comfort/Auto/Dynamic/etc... When the swap was completed there was no where for the heating element plug to go so it was tucked away but I don't know if the factory harness is pinned for this new "wild card" button.
    Any input is appreciated.
    Jul 22 2019
    Houston
    Anyone? I promise I've searched the forum to the best of my ability and haven't found this specific scenario covered already.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by cdbachm View Post
    I believe AZ member Audisthesia knows about these steering wheels. Maybe send a Private Message?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    The * button (aka joker button) cannot be programmed to do drive select modes, unless you have an ambrace module. The harness is indeed pinned for the * button, it should be functional.
    18 S6
    Mar 11 2007
    Colorado Springs
    IIRC, the drive select button will not work with MY 2013, I think it started with the FL 2016. OE/OEM flat-bottom steering wheels were never heated. I thought I could code the Drive-select buttons just as you would the paddle shifters, but no go.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Jul 22 2019
    Houston
    Thank you for all the information. If DS is out of the question what do you recommend the most useful function to program it through OBD11 to be?
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    I programmed it to be the >> or "Next" button. That way you rarely need to drop your hand from the wheel, since you have volume and next in the same area!
    My '13 A5 did this in the MMI from Audi, but my '14 S6 does not. Gotta love what Audi engineers think is important for different drivers!
    Cheers,
    KS
    Established Member Two Rings dspl1236's Avatar
    Dec 15 2007
    '90 90q 2.6, '90 GTI 3.6, '12 A6 3.2T
    Akron, Ohio
    I did a A8 wheel swap for the paddles with heat. My issue is heat is on all the time and the heat button is now a "M*" that switches the trans to manual mode... Thats kinda nice. I do want an "S" wheel tho.
    Looked up Ambrace as I didn't understand what it was https://www.ambrace.eu/products/.
    When I did the wife's Passat "LIN 1.3" to CC "LIN2" (single to dual air bag ignitor and horn pin changes) steering wheel swap in her Passat, all that was needed was the correct control module in the steering column that could talk both ways. I assume folks have already looked at that for our cars. Just spit balling as usual.
    '13 A6 3.0T + '90 Jetta 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 20v + '90 GTI Plum 3.6 VR6 + '89 200 10vt + '12 A6 3.2T + '01 A8
    Gone: '91 200TQA, '90 V8Qm, '97 A4 1.8T, 2x '98 A4 1.8T, '90 80Q, '90 CQ, '91 CQ, '91 CQ 1.8T, '91 200TQ, '95 90cs, '01 Jetta 1.8t, '08 Passat 2.0T, '13 GLI, '76 Audi Fox, '04 1.8T USP
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    Quote Originally Posted by Botbasher View Post
    Cheers,
    KS
    This is what I did as well. Sucks that the prefacelift can't have a cool function for it
    Sent from my CPH2611 using Audizine Forum mobile app
    Jul 22 2019
    Houston
    Do I need to enable any settings in OBD11 to take advantage of the star button? I had the factory heated steering wheel prior to this.
