Results 1 to 16 of 16
    Junior Member One Ring
    Nov 07 2015
    So Cal
    Still clunking after replacing all suspension
    I replaced my upper control arms, lower control arms and struts, because I had clunking. Well I still have the clunking when going over bumps in the road. It's a little quieter, but not as quiet as it should be. Argh!
    I read something here about loosening and re-torqueing the strut tower. I tried, but it's a 9M triple square. I have 8 and 10M Lol. I ordered a 9M. It should be here Tuesday. I'm hoping that will work. It seems weird that that would fix it.
    Anyone have any other ideas?
    May 20 2010
    Did you replace the strut mount bushing?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Established Member Two Rings petarat's Avatar
    Nov 06 2018
    Bellevue, WA
    I had the same problem, mine was my sway bar bushings. They get dirt and water in them over time and eventually start to wear out.
    2016 C7.5 A6 TDI clean diesel GTD2872 turbo, bitdi injectors, matrix lights, tow hitch
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    I've had swaybar bushings make noise. And the front subframe bolts loosening (C6 A6). The front subframe bolts baffled my indie as I kept complaining about the noise. Eventually he found the loose bolts, removed and wire wheeled them, cleaned the threads and applied Loctite and the car stopped making noise. The car also handled way better.
    Before I had my thrust arms changed (034 Density line kit on my C7.5 A6) installed, we checked all the suspension/subframe bolts and it seemed to make the car more responsive. I would urge anybody to make sure things are tightened to spec on subframe bolts and the like if you are under the car.
    Nov 07 2015
    So Cal
    Yes
    Nov 07 2015
    So Cal
    Quote Originally Posted by petarat View Post
    I did not replace sway bar bushings. I assumed since it didnt make noise when turning side to side. I'll have to check those.
    Nov 07 2015
    So Cal
    Quote Originally Posted by WatchMeSpend View Post
    Hmm, I'll have to check the sub frame as well. Guess I'll check sway bar bushings, strut tower torque,
    Established Member Two Rings TD_05's Avatar
    Dec 19 2013
    2016 Audi S6 2005 BMW M3 1994 Nissan King Cab
    Midwest
    This solved some clunk type noises for me in the past.
    Established Member Three Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    Transmission mount and or drive carrier …. Not sure if you skipped tie rods and sway bar endings when doing rest of suspension
    I am a 034 nutswinger
    Disclaimer: I am not sponsored or affiliated with 034 motorsport, just one of many happy customers.
    Nov 07 2015
    So Cal
    You know, I thought I did but, I found a set here in my garage. How would I check those on the car? I would hate to take it all apart again and,
    have the bushings be fine, lol.
    May 20 2010
    Quote Originally Posted by 82Gman View Post
    Yeah they're on top of the strut under the nut. So all apart again. Worth checking the other things like sway bar bushings. Did you make sure to re-tighten the suspension at ride height too?
    FWIW, I doubt it's transmission mount--I replaced mine and had zero difference in driving. And driver carrier if it's only over bumps.
    Dec 24 2023
    Canastota/NY/USA
    check your lower ball joints, sway bar end links, and motor mounts.
    Sep 30 2020
    Boston, MA
    Quote Originally Posted by 518Audi View Post
    Big this. I've replaced both lower ball joints on my A7, although it's not so much a clunking noise as it is a screeching sound. My previous S4 i had to replace the sway bar end links (easy to do yourself), this had a very clunking sound.
    May 24 2024
    South Texas
    Quote Originally Posted by omgContra View Post
    The only time I’ve heard ‘screeching’ was when I first bought the car at 60k miles the bearings were shot driver front passenger rear. I think that the sway bar end links and rear strut mounts get overlooked when refreshing suspensions because they’re not part of the commonly offered control arm kits. 034 has a front mount rubber bushing too. Bump stops are another cheap thing that if ignored will leave you annoyed
    Nov 07 2015
    So Cal
    OMG! It was the friggin sway bar links. I didn't notice them until I started taking it apart to redo the strut mounts!! I pried on them with a pry bar but saw and heard nothing. Thanks everyone for the advice. Ahhh peace and quiet!
    Sep 30 2020
    Boston, MA
    When they're loaded I couldn't tell anything. But once I had them off in my hands, one of the bushings in the left sway end link was very loose compared to the one on the right.
