Results 1 to 9 of 9
    Junior Member Two Rings
    May 06 2020
    Wisconsin
    2011 B8 2.0 dreaded reduced oil pressure at idle. Help! P164d00
    I know this has been covered a million times and I've read A LOT of those forums, but I'm still having an issue. 2011 2.0 after idling for about a half hour I get the low oil pressure light. I use mobil one 0w40 and the oil has about 1 hour run time. I pulled brown pressure switch and installed gauge. Cold start at idle, the oil pump pressure ramps up to 40 psi, then after a few minutes it comes down to 25 psi. As the engine is idling the pressure does come down slowly as the engine warms up. By the time engine is at 212°f the oil pressure gauge shows 11 psi. I thought the cooling fan would have come on but it never did. Now sure what temperature it's supposed to turn on. It takes almost a half hour to get to the 11 psi, it's not right away. I've ruled out both switches (via gauge readings)and control valve n428 because at 3500 rpm the two stage oil pump jumps up to high flow, 58 psi. So oil pump is working and switches are reading correct. My oil cap is hard to pull off when engine is running, so I checked the vacuum at the dipstick and had 1.5-2.0 in hg. I took pcv diagram out and it wasn't cracked or torn. I also did timing chain, pistons, rod and main bearings recently and at that time removed the cam bridge screen. Engine runs perfect, idles smooth, no noise and the only code is p164d00. Anyone have ideas, I'd appreciate it.
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Quote Originally Posted by 09A6 View Post
    Did you replace balance shafts with genuine oem?
    Sent from my SM-S921U using Audizine Forum mobile app
    May 06 2020
    Wisconsin
    Quote Originally Posted by Shane Horning View Post
    No I haven't. Some posts say balance shafts are not the problem. Some post say cam bridge or intake cam. I even watched a hour long YouTube video and the guy replaced all of those parts and it fixed the problem, but he couldn't say what part was the actual failed part. So he wasted a bunch of money on parts it didn't need.
    Nov 16 2018
    Upstate. New York.
    Id say if you swapped the bearings with the correct ones, so clearance is correct then change balance shafts next
    Feb 15 2016
    Cambridge,Ontario
    1. Did this car have low oil pressure before you did the engine work ???
    2. Back yard mechanics should never mess with Crank and main bearings as the risk/ reward is just too great on an otherwise good engines. Rod bearings fine, they are all yellow on this engine and are just a swappable part.
    Normally the vast majority of the time it is the BS causing low oil pressure , but since you have had the engine apart, all bets are off..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 06 2020
    Wisconsin
    I bought the car not running due to a timing chain tensioner failure. The owner did say it had a oil consumption problem. They never mentioned a low oil pressure issue. I only did the bearings because I was already in there doing the piston update. I didn't remove the balance shafts because they turned freely. If I pull them how can you tell if they are bad? I can look to see if the screens are there but you can't see the actual bearings.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Low oil pressure is always a nightmare with these engines because there are so many places they can loose pressure. We don't even bother tearing into them anymore if they have low oil pressure. It's cheaper just replace the engine, and the engines are not cheap.
    B6 S4, B8 A4, 8P A3, and something, something.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by RPMtech147 View Post
    yup 100%
    the things that can cause it are all high labour things . that's why i suggest people just don't Fuck with bearings .
    we had a guy last moth rebuild it all with brand new bearings, used plastigauge etc. all that to find out the manufacturer of bearings he used were not exactly the same and caused low oil pressure at idle . had to tear whole engine down again
    We had the guy where he had low oil pressure at idle and had a leaking piston squitter, had to tear the entire engine down...
    Then there was the guy with cam advance issues caused by low oil pressure, jammed oil return valve in the underside of the head.. engine had to come apart and head off.
    And lastly of course the balance shafts and the Chinese balance shafts headaches...
    If you have good oil pressure before you start a rebuild, do NOT touch the cranks and mains. They are solid on this car and ive never heard of any go bad..
    1976 Yamaha XS 360
    Apr 14 2019
    Northeast, NJ
    At idle your supposed to have -3 in hg (maybe only for "white top")
    timing chain tensioners, must be OE (ECS Bremman chain tensioner = low oil pressure)
