Results 1 to 40 of 70
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    Roundabout And Back Again, A B5 S4 Story
    Well folks It’s been a Journey for sure. I’ve been maintaining and modifying these cars for 20+ years at this point. It is what I do for a living, and I’ve personally been through more Audi chassis then I would care to admit. However, It always has, looks like it always will be, the good old B5 S4 for me. So here I am back again, let’s do another build thread.
    These cars are getting harder to find. With the whole part out trend starting years back. Good ones are fewer, and further between. I have said this before, It’s just at this point, I think this truly might be my last one. The forever car, the keeper, the old man garage queen.
    I introduce you to my hi mileage, and relatively unmolested, 2000 Laser manual B5 S4.
    First photos from the day I picked it up!
    Jul 19 2014
    Tulsa
    First things first, replace the damn wheels. A friend of mine had some RSe52’s in 18x8.5, with a ET of 45. The car came with some BC racing coilovers already installed, so I dropped it down about another 20 mm. I’m now happy with the way it’s sitting.
    Honestly, I was always a BC hater. Never even would’ve considered them, had they not come on the car. I’m surprisingly impressed so far. At least enough to put money elsewhere first.
    Jul 19 2014
    Tulsa
    Also, I hate wood trim. With sport trim so much harder to come by these days. I called oCarbon, had Matt make me some belt line trim. Decided to go with the Audi atlas, same stuff that’s in all of the new chassis. I only did the beltline trim, this is my personal opinion, I think carbon on the console is a bit much. So I stayed with the sport trim style.
    The steering wheel had also seen better days. So I had an eBay manufacturer from overseas send me out a recovered stock wheel. Finished it all of with some RS4 style door pulls from project B5.
    After these pictures were taken, I removed the gauges from the vents. It was just too much going on. I think I might install them in the glove box, if I can’t find a better solution. Also, I plan to install the factory head unit. I feel anything aftermarket in that position just looks tacky.
    I think the interior came together nicely .
    Jul 19 2014
    Tulsa
    I got a box today! Radiator support from VanBuren!
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    NICE- thanks for sharing!
    The ride height looks perfect!!
    Agree with your decision on the head unit--the "old" analog stuff better suits the Audi.
    PS-
    I tried that glove box trick with my gauges and quickly moved back to a single pod gauge setup(on steering wheel)-Innovate PSB-1 gauge (boost with AFR)
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I don’t understand the glovebox thing and I know it’s been popular across platforms forever. You drive around with it open? Or hope it’s open when something goes wrong and you need to see the gauges? Or only open it if you think something is wrong?
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Nice man looks like a good base.
    For a clean gauge setup, you really can’t beat a FIS-Control
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    I’ve always been a big fan of the P3 gauge. I have one in both my 2.7’s. It’s clean and matches the lighting. Analog boost sensor and you’re good to go. It’s also a code reader!
    I’m with CELison, being in the glove box is cool and discrete, but not helpful.
    Jul 19 2014
    Tulsa
    Quote Originally Posted by LJS View Post
    PS-
    Thanks man, the interior of these cars is just so classy and perfect. Anything other than the factory head unit, just doesn’t suit it.
    I’ll definitely look into that gauge idea.
    Jul 19 2014
    Tulsa
    Quote Originally Posted by CELison View Post
    My thoughts on it, with the gauges in the glove box, I’ll have access if required. Boost and lambda, both with peak hold ability. I’m not going crazy with this car, K04 and some E. So in my humble opinion, I think I would get a cell before a lean condition could cause any damage.
    Quote Originally Posted by Silverex View Post
    Definitely a good option. I’ve been looking into it.
    Quote Originally Posted by ShelbyM3 View Post
    I’m still undecided, I had a VADpro in a different chassis. They seem to have a good option for the B5. I think that’s kind of the way. I’m leaning at this point.
    Jul 19 2014
    Tulsa
    Parts ordered from SEP, K04’s, charge pipes, inlets, Y-pipe, Bi-pipe, catch can. I have the Bi-pipe, and catch can in my possession. I’m impressed with the quality so far. I have a set of SRM, and a set of AWE intercoolers left over from other builds. Still undecided what set will go in this car.
    Feb 23 2010
    Emmaus Pa
    The car has narrowband O2s, so it has no idea what AFR is at WOT. It can only throw a lean code from LTFTs at cruise and idle, which can be perfectly fine while stilling having a major issue in boost. Be careful with SEP, I’ve know him for a very long time. He’s a nice guy, and means well, but I wouldn’t trust anything coming out of there.
    Jul 19 2014
    Tulsa
    You are right, I guess I just don’t worry about it as much with this car. The plan is to run my old Daz file for now, same box code. If I remember that file only made 18 psi on 550’s, and E. It may end up getting a VADpro either way.
    With SEP, I guess I’ll need to learn my own lesson. I’ve heard stories, It’s just as you stated, I’ve had multiple conversations, and I like the guy. The examples that I have in my possession I’m impressed with so far. I always worked with Daz, then Blake, and Blake sells his stuff. So that was my reasoning.
    I appreciate you lookin out!
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    I actually kind of liked the gold Avus' lol
    Regardless, nice pickup.
    Heres to never selling cause we like the punishment.
    Sent from my SM-G973U using Audizine Forum mobile app
    Jul 19 2014
    Tulsa
    Quote Originally Posted by TwoSnelz View Post
    Honestly when I initially swapped them out. I felt like the car looked better with the Avus’s also. The RSe52’s are growing on me, and I definitely need the room for bigger brakes here shortly.
    Also I think with the bigger brakes, and red calipers behind the black wheels, it will help with the contras. Make them stand out more. Right now they get lost in the black abyss of the wheel wells.
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Welcome back!
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Jul 19 2014
    Tulsa
    Quote Originally Posted by zatch_303 View Post
    Welcome back!
    Thank you, kind of feels like home again haha!
    Jul 19 2014
    Tulsa
    Well, a friend of mine back home was having trouble getting back into a B5 S4. Could not find the right car. An offer was made on my laser, I took the offer. So this thread is going to change up a bit. We are going to move forward with another car that I picked up. All of the available funds from the laser sale will go into one of two cars. I can either build my silver S4 manual, or sacrifice that car, and use all of its components for my cactus 1.8 auto Avant. I honestly need help with this decision.
    Starting from scratch, I’m going back to my roots. Chassis, brakes, and suspension components will be first. This is the list already ordered and hopefully in the mail soon.
    Torque factory spec, FEAL coilovers.
    034 fully spherical front upper control arms.
    034 fully spherical rear upper control arms.
    034 spherical rear tire rod set.
    034 rear sway bar, and subframe reinforcement kit.
    034 billet subframe mounts, front and rear.
    034 spherical swaybar links, front and rear.
    034 billet engine mounts.
    034 billet transmission mounts.
    034 snub mount.
    In the next day or so, I will order Wavetrac differentials, and JHM 4.1 center, with JHM trans components.
    The 2000 silver car, interior is decent, would require paint. The 2001 cactus A4, its also in decent condition, would require paint. My dream car is a cactus Avant. My only issue is it’s not technically an S4. When I was done with it however. I don’t think anyone but me would ever know the difference.
    Apr 08 2013
    Connecticut
    FWIW-
    Be sure to get the protective boots for your spherical rods ends--will extend the service life of those ends...I had these items on an earlier project car(LONG time ago) and found this out the hard way....
    Good luck with the new project!
    Jul 19 2014
    Tulsa
    FWIW-
    That’s great advice, not my first rodeo with these components. Previously in California, so honestly, I didn’t have much trouble. Now I’m in Oklahoma, they will definitely get installed.
    Feb 05 2007
    Portland, OR
    I say build the cactus. While’s it’s not an S4 technically, it’s your dream and it’s going to get harder and harder to make that happen the longer you wait. Life is cruel, parts are NLA, and Cactus. Everybody needs more Cactus in their life! Go all out and like you said, nobody will even have to care that the VIN is an A4. I think at some point the overall quality of a really nicely built car from a shell will far outweigh the originality factor of an S4. So much is changed on both after a build that neither are really anything like their original forms.
    Jul 19 2014
    Tulsa
    I’m still leaning heavily towards the cactus. However, I am still completely undecided. I think it’ll end up being a spur of the moment decision haha.
    Well, I spent another round ordering parts. Entirely too much money. However, I’m looking at this as my last real project. I’ve decided to do some things differently.
    Torque factory complete Y-pipe with upper, lower inlets.
    JHM trans overhaul kit, with the 1-2 collar.
    JHM drive shaft support insert.
    JHM 4.1 center.
    Wavetrac front and rear LSD’s.
    This is gonna be a ride!
    Jul 19 2014
    Tulsa
    Picked this up used. Ordered the maf housing and lower inlets from torque factory to round out the monster kit. This thing is huge!
    Junior Member Two Rings
    Dec 01 2021
    Plymouth
    Looks lovely, very envious! What turbos are you going for?
    Jul 19 2014
    Tulsa
    I was always happy with K04 power levels. So I went with SEP billet K04’s. The car will go together initially with an unopened long block. I have a spare engine sitting on my stand, so that may change in the future.
    Jul 19 2014
    Tulsa
    Parts either in the mail, or boxes in my living room haha!
    Cooling system
    CSF aluminum large capacity radiator
    Induction.
    SEP billet K04’s
    SEP charge pipes
    SEP V-band bi-pipe
    SEP catch can
    AWE intercoolers, carbon shrouds
    Torque factory monster Y-pipe
    Torque factory maf housing
    Torque factory upper, lower inlets
    034 diverter valves
    Fueling.
    Walbro 450
    Bosh 4bar regulator
    Bosh 550 EV14 injectors
    Drivetrain, chassis.
    JHM full transmission kit
    JHM 4.1 center diff
    JHM trio package
    JHM center support inserts
    Wavetrac front LSD
    Wavetrac rear LSD
    AWE drivetrain stabilizer
    034 billet B7 RS4 conversion flywheel
    034 billet trans mounts
    034 stub and cage
    ECS diff mount.
    VanBuran aluminum core support
    Ringer racing Stage 4 clutch kit
    Suspension
    Torque factory FEAL coilovers, 12-15k springs.
    034 fully spherical front upper arms
    034 fully spherical rear upper arms
    034 spherical rear tie rods
    034 rear sway bar
    034 subframe reinforcement kit
    034 billet subframe bushings, front and rear
    034 spherical sway bar links, front and rear
    Exhaust
    XS 3in V-band down pipes
    SEP 3.5 in single exhaust.
    Wheels
    034 forged ZTF01, 18x8.5, ET45
    Brakes
    18Z front
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I’m biased but the cactus wins for me too, but I’ll just be happy to get mine up and running in stock s4 form
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jul 19 2014
    Tulsa
    Quote Originally Posted by bakedziti View Post
    Haha, great minds!
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by Tjtalan View Post
    Cooling system
    Induction.
    SEP billet K04’s
    SEP charge pipes
    SEP V-band bi-pipe
    SEP catch can
    034 diverter valves
    Fueling.
    Walbro 450
    Bosh 4bar regulator
    JHM 4.1 center diff
    JHM trio package
    Wavetrac front LSD
    Wavetrac rear LSD
    034 stub and cage
    ECS diff mount.
    Suspension
    034 rear sway bar
    Exhaust
    Wheels
    Brakes
    18Z front
    Jul 19 2014
    Tulsa
    Yeah, lots, with more to come. I’m old now, it’s time to do it right. The AWE intercoolers are getting sold, the tuner wants SRM’s, also getting bigger injectors.
    Jul 19 2014
    Tulsa
    Parts started rolling in. It’s getting real!
    Sway bar
    Chassis reinforcement kit
    Snub,and cage
    Engine mounts
    Billet Front subframe bushing
    Front sway bar end links
    May 10 2018
    MA
    There’s a very good chance those wheels aren’t going to come close to fitting those brakes. Something to be aware of.
    Jul 19 2014
    Tulsa
    Quote Originally Posted by RMode View Post
    I printed the template, looks close. I’m hoping it just clears. If not, at an ET of 45, I have room for spacers. I like the wheel size, because I should be able to fit a 245. So fingers crossed.
    May 10 2018
    MA
    Caliper template doesn’t really tell you wheel clearance without the corresponding rotor template. Rotors have offsets to them just like wheels do, and there are multiple rotors for those calipers.
    Don’t get hung up on the number on the sidewall, it’s not an actual measurement at the end of the day. There are 225s as big as some 245s.
    Jul 19 2014
    Tulsa
    I used a full-size wheel template that 034 provides. You’re definitely right about the tires, even between brands with the same sizing, you’ll find drastic differences.
    I do a lot of autocross, so I’ve learned a bit about tires. Definitely not an expert though. I’m trying to fit the RE71RS, in a 245/40, it’s a big tire.
    Thanks for making me more nervous than I already was haha!
    Jul 19 2014
    Tulsa
    Radiator just showed up!
    Jul 19 2014
    Tulsa
    Received a few pictures from Andrew over at SEP. He started on my exhaust!
    Jul 19 2014
    Tulsa
    Traction, all the traction please!
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Looks like you're sourcing all the good parts, one of the mods I want to do to my car is a lsd rear diff at some point. Looking forward to the build
    Jul 19 2014
    Tulsa
    Quote Originally Posted by Tec_Nine View Post
    Thanks, just trying to take what I’ve learned previously with this chassis, and some good information from others. Hoping to put it together into a fun little car.
