Results 1 to 8 of 8
Thread: Android HU
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Android HU
    Anyone give one of these units a try? I like that it has a factory look…
    https://www.ebay.com/itm/184388692721?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bc7N2zURTe6&sssrc=4429486&ssuid=jkxn2hDyT3 y&var=&widget_ver=artemis&media=COPY
    Jul 07 2024
    Elk Valley, BC, Canada
    At that price I'd say give it a shot. But my experience with android head units both cheap and expensive has been bad. Especially bad with the cheap ones. It's always clunky, and one of the ones I got (different car) stopped doing CarPlay after a week.
    I now use an mk1 RNSE from Gunnarrrrr, it has been great. It's not fancy but it always plays music, the reverse camera works, and it is OEM.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    I've been thru a few different Android hu's. That one's going to be slow and annoying with only 2GB RAM and 32GB RAM. You're just throwing money away.
    This one is better:
    Xtrons HU
    But honestly, I would recommend getting one that is 8GB RAM and 128GB RAM if you want to be able to do anything with it. Worth the extra money IMHO.
    And, I would contact Matt Devo. He sells hus and makes true Plug and Play Harnesses for these.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Apr 16 2015
    CNY Syracuse
    Thanks for putting me straight. Every once in a while I go down this road and need to be reminded they're all junk at this price point. I've heard good things about the extrons units as well.
    They're not scared of you. They're scared of what you represent to 'em.
    May 22 2007
    Santa Monica CA
    This is the unit I finally settled on. Went thru about 6 or 7 other units.
    Liked the fact it was a full touch screen WITH a volume knob.
    I bought the BT6. The supplied harness is total garbage and their tech support sucks, so bought a plug and play harness from Matt Devo for about $80.
    Had it now for 2 years and love it. Couldn't be happier. Sounds great with the Factory BOSE
    Android Head Unit
    Jul 10 2015
    Colorado
    I also recommend the Xtrons units. I have this one and if I had to do it over, I'd buy one with a volume knob. https://www.amazon.com/dp/B09R9DFKKK I didn't have any issues with the supplied harness and the unit works great. I don't have Bose though.
    Veteran Member Three Rings codemode's Avatar
    Sep 01 2019
    EU
    You will have a much bigger choice over on AliExpress. Cheaper prices and more add-ons.
    The prices are RAM dependent. Aim for newer Androids, 13 and 14. I’d personally choose one that has all the buttons. Having a full touchscreen and no steering wheel controls sucks.
    A4 B6 1.8T Manual FWD 2002
    Painted lowers, USP front
    18'' RS4 ET 35 Replicas
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Mine came with what I assume was a B7 antenna adaptor. I reworked that to fit my B6's coax cable, only to have no radio reception. Figured later that the coax's shield is not to be grounded but serves as the 5V source for the antenna amplifier at the rear window. In fact there was one wire in the new harness adaptor labeled in Chinese on one side, and "antenna" on the other, for powering the antenna cable. The instructions were pretty minimal, but I've happy with it since.
