Hey Guys,
I searched the treads and couldn't come up with a resolution. The instrument cluster lights up on auto but once you push the fog lights or rear fog lights the lights go out. I have replaced the battery did a reset via obd11 and coded the new battery. If i turn on the lights manually the cluster lights go out. I swapped the light switch with my SQ5 to see if it was faulty and same issue. I pulled all the fuses and checked and they are good. obd 11 Scan said instrument cluster fault. Hopefully someone can guide me to what to check next. TiA.
