Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by Jake@JHM View Post
    Why not both? ;)
    Are connections the same on the new cable? Just want to make sure I have everything I need.
    Might be a little bit of a struggle anyway, my laptop doesn't have Ethernet input but I have a ton of faith in my Wi-Fi.
    Sent from my SM-G990U using Audizine Forum mobile app
  2. #42
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by a4937 View Post
    Yes the new cable is similar to the old in terms of connection. USB to OBD2. Send an email to us with your original tuning order number so we can create you the power connect login and get you the download.
  3. #43
    Aug 14 2008
    Ohio%20
    I'm doing the TCU first. Do I still need to email my original order number? Plus I don't have the cable yet and sadly it won't arrive until next week.
  4. #44
    Aug 31 2011
    Lathrop
    You should get an email with your account info then. Though you will need to reach out before redoing the ECU side
  5. #45
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I just used Wi-Fi and was plenty fine. I'd have to run a 100' cable to use a hard line, lol.
    Sent from my CPH2611 using Audizine Forum mobile app
  6. #46
    Aug 31 2011
    Lathrop
    We often flash using just a hotspot on our phone when out testing. Not recommended obviously, since we have the tools to fix something should there be an issue. A strong wifi connection should work. Just make sure it doesn't drop out
  7. #47
    Aug 14 2008
    Ohio%20
    I was reading the email about controller not found issues, should I expect that delay in an 07? Cable is delivered today so I'm ready to rock and roll!
  8. #48
    Aug 31 2011
    Lathrop
    Its not a common occurrence. If you run into any snags, respond to the email you received from our tuning department (the one that has your login details) and the calibration team will be able to assist you along the way.
  9. #49
    Aug 14 2008
    Ohio%20
    Cool thank you sir!
  10. #50
    Aug 14 2008
    Ohio%20
    Nm
