Results 1 to 16 of 16
    Junior Member Two Rings
    Oct 25 2010
    08 A6 Quattro, 21 Atlas, 10 F-150, 12 318i
    Baton Rouge, LA
    1.8 Shudders Under Load Only
    With clutch in or not in gear I can redline it no problem with no missing. 0 to 60 in 30 seconds otherwise it shudders like I'm driving down train track. CEL will blink while shuddering then quit. Then CEL stay on and give me a random 1 of the 4 cylinder missfire.
    Guys any ideas. I'm lost.
    Sent from my SM-S926U1 using Audizine Forum mobile app
    Apr 13 2017
    2003 A4 6MTQ 3.0, 2005 A4 FWD 1.8T
    Dallas, Tx
    It could be a bad abs wheel speed sensor (or 2). One of mine is going out and it does that exact same thing when I turn around sharp corners. It could definitely also be your engine harness shorting out. I'd start with investigating the wiring to your ignition coils. I had to splice in 4 new ignition coil pigtails on mine for same issue.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Check your spark plugs first. If they're worn out or gapped incorrectly (too large vs to small) then that's a likely cause.
    Sent from my SM-S918U using Tapatalk
    Oct 25 2010
    Baton Rouge, LA
    Rebuilt top half 6 months ago with new plugs. Been running fine up until recently.
    Oct 25 2010
    Baton Rouge, LA
    Could wheel speed sensor impact how the motor runs?
    May 04 2020
    PA
    Quote Originally Posted by JasoninBRLA View Post
    General rule of thumb/process for misfires:
    1) Swap coils (either swap the cylinders that are missing with ones that aren’t or just throw a new set in)
    2) Inspect coil pack wire harness, these are known to crack and fray
    3) Inspect spark plugs for corrosion, hot spots, carbon build up, and check gap as well if tuned
    4) Inspect injectors if above mentioned failed to isolate issue, swap same as coil packs
    If all else check outs, you may have an issue elsewhere either being a vacuum leak or faulty MAF, MAP, TB, boost leak, etc.
    Apr 13 2017
    Dallas, Tx
    Absolutely. Bad wheel speed sensors can make the ECU think you have wheel spin and the ESP throttles the motor like you are describing. The misfires are either coincidental(trying to throttle the motor under load), or as I said electronic in nature. Being that you are having random misfires, I don't see it being coils or plugs, rather the OLD wiring we are all dealing with at this age. Try turning off ESP and see if it resolves the issue. If not, follow the troubleshooting we have described above.
    Sep 10 2021
    Pennsylvania
    It's pretty easy to check the ignition wiring. Maybe 10 minutes or so worth of work. Pull your engine cover off, pick a coil, and pull back the rubber boot thingy until you can see the wires under it. If you look in there and see four copper wires with no insulation getting real friendly with each other, you'll know your wiring is fried. You should check all four connections, but if you find a failed one, then you should just go replace the harness. It's not as big of a job as it sounds. The absolute worst part of the job was getting the dang windshield wiper off to get to that ONE screw holding the ECU cover on.
    If you're feeling brave, go ahead and check the wiring where it plugs into your fuel injectors (I've not been so brave yet). You might be in for a surprise there, too, but it doesn't sound like the cause of this particular issue for you right now.
    I'll echo what others have said about the plugs... double-check the gap. But do the easiest stuff first--it's really easy to look at the wires under the boots.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I know on my car when the traction control kicks in you will see a flashing light on the dash letting you know it activated.
    Jun 30 2008
    Erie, Pennsylvania
    This sounds like a textbook 1.8T weak ignition coil situation. The 1.8T ignition coils are very high failure rate. All of them get weaker over time as the secondary winding degrades. You will almost always notice the weak spark in boost/hard acceleration first (if you drive it hard, anyway). Extreme temperatures can also worsen the symptoms.
    You can try to figure out which one(s) are weak by lifting the coil off the plug gradually while the engine is idling (carefully, at your own risk). By doing this you can determine which coil causes a cylinder to drop-out with the least amount of lifting. You are forcing the coil to generate higher voltages to jump the additional gap between the coil and plug. If the coil is very weak, you will not be able to lift it very far or at all.
    The coil-lift test is pretty easy, but there exists a special (and cheap) tool to measure the attainable coil output voltage more "scientifically": https://www.lislecorp.com/specialty-...g-spark-tester
    Or you can just throw 4 new coils in it. ;) Good Luck.
    The wiring harness concerns are definitely valid, and you should inspect that - but I find harness issues to be much more rare than your standard weak ignition coil issue. Especially if its only cutting out under load.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Definitely sounds like wire issue
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Oct 25 2010
    Baton Rouge, LA
    Quote Originally Posted by Dfraney View Post
    Definitely not 1-3. I will check 4 this weekend.
    Oct 25 2010
    Baton Rouge, LA
    Quote Originally Posted by krazeedrivr View Post
    I will try this Saturday.
    Oct 25 2010
    Baton Rouge, LA
    I've had the car 17 years and changed out several bad coils. This is different. Also when I replaced the head gasket I replaced every hose and changed out all brittle and suspect electrical plugs. Especially the ignition wiring which was really really bad.
    Oct 25 2010
    Baton Rouge, LA
    Guys. I appreciate your efforts and will keep you updated on my progress. I love this car and plan on driving it till I die.
    Jun 30 2008
    Erie, Pennsylvania
    Have you checked your plugs and boots for carbon tracking? That can definitely cause a misfire that isn't quite the same as a weak coil or a worn plug. It sparks right down the side and skips the spark plug electrodes altogether.
