Results 1 to 3 of 3
    Dec 31 2024
    Nebraska
    Engine Ticking Noise - what is this?
    Greetings folks,
    2019 A7 with 44k miles. Just bought late December. Presenting a metallic ticking or tapping noise on driver’s side of the engine.
    Vid: https://youtube.com/shorts/TpQ0LbK1owk?si=1ieEoI8K6rXKyynl
    The noise is most pronounced when cold, at idle, and under light acceleration. Oddly, it doesn’t start until the idle drops off a cold start, and disappears at cruising speeds or when letting off the accelerator. Once warm, it’s only noticeable if you’re told to listen for it.
    Audi master tech at first inspection said it was normal engine noise or injectors/valves and normal. Second inspection said it could be faulty rocker arm. Other Audi techs have said it’s normal and all the 3.0T engines tick.
    It’s much louder and sharp in the video than in person. Guessing due to iPhone mic quality. I’m going to send an oil sample into Blackstone later this month.
    Thoughts on what it could be?
    Sep 15 2020
    vancouver
    I have a 2019 Audi A7 with 46k miles on it, and it made the same noise, more pronounced right when i cold start and start driving. low RPM when i press on gas it made the noise. no check engine light or anything. when i took it to audi dealership they found metal shavings in the engine pay and got quoted 60.5k for an engine replacement.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    What oil have you been running?
    0w20?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
