I have my 2003 A4 3.0L torn down to replace a leaking water pump. The timing belt and water pump were both replaced in 2014 by the PO. I called a local shop and they essentially wanted the value of the car to do the job so I chose the DIY path with specialty tools and youtube videos. The issue I'm having now is 4 stripped and stuck crankshaft pulley bolts. I do have the cams and crank locked with the special tools. I've tried heat, vice grips, even notching with a dremel tool to try and get a flathead to bite. Any other thoughts here short of just grinding them down one at a time? Constructive comments and suggestions are appreciated!
