In the stock setup, the Boost gauge was displayed, but I installed the Rainbow Box to enable the engine data and G-force meter.
Since the Rainbow Box is also compatible with the A4, it seems to have some influence on the Boost gauge, and now it displays differently from the stock behavior.
In the stock configuration, the Boost gauge only started filling up when I pressed the accelerator quite deeply. However, now, with the same level of input, the gauge already shows more than half or even full boost.
Also, right after a cold start, before the RPM stabilizes, the Boost gauge slightly rises. (Added image)
I’m considering disconnecting the pin related to the Boost gauge from the module, but I don’t know which pin is responsible for what function.
Has anyone had a similar experience or knows how to resolve this issue?
