Results 1 to 9 of 9
    Apr 28 2024
    ‘14 RS7 Prestige and ‘23 F150 Platinum Black Pack
    Carbondale, Colorado
    B5 S4 Rattling brakes + noise when braking
    Hi Team,
    Hope everyone is having a nice Friday. Pardon me if this is a dumb question but I’m struggling a bit with some brake noise. It’s a rattling noise coming from my driver front caliper and only occurs when I’m going over bumps or on washboard-like snow AND when I first press the brake there is a bit of a clunk. I am not a mechanic or brake specialist(obviously).
    I’m mostly looking for direction on if there’s bolts I should tighten(I have a torque wrench and read that caliper bolts should NOT be over tightened), or if I should suck it up and take it to my local shop. The caliper feels a teeny bit loose if I try to move it with the wheel off, but not crazy. I’d like to mention that the brakes feel 100% fine as well when operating them.
    Attached is the photo of the bottom of the caliper, please ignore the fluid as I had loosened what I think is part of the ABS to get to the triple square bolt up top and realized it wasn’t right maneuver.
    Thanks AZ
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Is it me or are those pads way past the edge of the rotor? I’d check to see if the pad has separated from the backing plate or if the pad isn’t seated correctly on the caliper. When I was rebuilding mine when I first picked up my S4, two of the pads had separated from the backing plate and were just floating when I separated the calliper from carrier. If you are handy, I’d remove the calliper and remove the pads to inspect them. Otherwise you are just guessing.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Jan 01 2018
    utah
    Any fluid out of the caliper is going to be brake fluid. I would tighten that back up asap. That could cause spongy brakes.
    Rattle when your going over bumps could be a lot things. Does the noise go away when you apply the brakes. A clunk up front could also be your control arms.
    Is your clip in on the back of the pads and do you have pad life left?
    Don't take off the triple square bolts
    Sent from my SM-S928U using Audizine Forum mobile app
    Apr 28 2024
    Quote Originally Posted by Cybersombosis View Post
    I will remove the caliper and check this out today. Thanks for the reply. The rotor sort of “floats” a very tiny bit while I feel like the others are tight and more seated. I just don’t like messing with brakes without direction as they are the most important piece of safety equipment on a car. Appreciate the reply
    Apr 28 2024
    Quote Originally Posted by travis_w View Post
    As soon as a teeny bit of fluid came out of the top nipple I tightened it back up right away. Noise does in fact go away when I apply the brakes. It’s as if there is a slight gap between the pad and rotor. The clunk happens only happens precisely the moment when I first press the brakes. I will check the clip on the back of the pads. Yes, they appear to have a nice amount of life left. I’ll be sure to not touch the triple squares. Thanks for the reply
    Senior Member Three Rings 2006b7a4's Avatar
    May 13 2018
    2003 Acura TL Type S
    When i had stock brakes the pad separated from the backing plate and it caused a rattle.
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Quote Originally Posted by Ryes7 View Post
    If you work on the brakes or have them worked on, then it would be good to check the caliper slide pins (that are on the right side of your above image) to make sure that they are properly lubed and that the rubber bushing they fit into isn't too worn, plus there should be a cap covering the inside of the rubber boot. The slide pins and boots aren't expensive if you need to replace them.
    On my car (2001 A6 2.7T 6-speed with the HP-2 front brakes), I had to remove the front rotors to remove the slide pins, and I used some 3M silicone paste to lube the slide pins.
    - Jim
    Apr 28 2024
    Quote Originally Posted by 2006b7a4 View Post
    This feels a lot like what is happening. I made a video of what the brake looks like, pads and such. It just all looks normal-ish to me. Ran outta time so I threw the wheel back on.
    https://youtube.com/shorts/11jhlzKpJ...gWa9gUc_3Xm7RA
    Apr 28 2024
    Quote Originally Posted by Calif_Kid View Post
    - Jim
    I haven’t really worked on them beyond tightening the a couple bolts. I will check this out. I made a video of the brake and it looks normal, it’s just ever so slightly loose. I’m a little hesitant to pull them apart too much because it feels as if they are functioning well, it’s more of a nuisance noise kinda thing at this point.
