Results 1 to 7 of 7
    Junior Member Two Rings
    Aug 31 2021
    Arlington VA
    B7 S4 Tune Jackal or JHMotorsports?
    I have been trying to solve my P0491 & P0492 SAI issue and it just seems easier to get the SAI system tuned out. I would like any additional power that a tune would provide as well. It looks like JHmotorsports and Jackal both offer tunes for the cars and they both seem to be great shops. Does anyone recommend one over the other? My car is a 08 S4 Cabriolet. I have had the motor pulled and rebuilt by AMTuned so all the timing chain and valve issues are resolved. The motor runs great and no longer burns any oil. I did all repairs that I could while the engine was out replacing the clutch with RS4 and replacing AC compressor ect. The only real modification I have is gutted the precats. Any advice on which tune and any other required mods to do at the same time would be appreciated. Also if anyone has any discount codes for either vendor that would be great.
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    I personally recommend Jackal.
    I can't speak for JHM.
    AKA: FlyingNipples
    Aug 31 2021
    Arlington VA
    Thanks for the quick reply. Just waiting to hear back from them both to make sure they can code out the SAI.
    Quote Originally Posted by anthonyh75 View Post
    AFAIK they both can. For the rs4 they can so for the s4 would say so too
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    Is this possible with vcds? Or possible to see if sai is coded out?
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Oct 31 2022
    Prescott AZ
    Jackal,
    high flow drop in air filter
    Catback exhaust 2.5” (magnaflow)
    Catless
    Downpipes
    Rear sway bar
    Oct 31 2022
    Prescott AZ
    Both offer that delete
    Along with some other things not needed.
    Motor mount plug delete, if your aftermarket motor mounts installed.
    And one other not needed item
    Rear o2
