Hi guys, do you know which version is compatible with mine? I'm so "lucky" that my S-tronic DL382 version is 80A 927 155 DF, I've checked on vag-flashinfo.de but other versions are available.
I can't figure out if I have an update available; could it be DE/DG ?
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 80A 927 155 DF HW: 0HK 927 156 B
Component: 0CJ 20TFSIRdW H01 0002
Revision: --H01--- Serial number: 0000002801 CVN: 70F47F2000000000
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
VCID: 70B9D0DD0A20ED5AFFB-8024
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190003000367
No fault code found.
Versions available: https://jmp.sh/fv1akjHW
