Results 1 to 3 of 3
    Feb 25 2025
    Pottstown, PA
    Post I recently got an A4 3.2 from an no reputable seller and this is my first VCDS scan
    www.Ross-Tech.com
    VIN: WAUMK78K49N000400 License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
    42 46 47 52 53 55 56 62 65 67 6C 72 77
    VIN: WAUMK78K49N000400 Mileage: 189780km-117923miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Cannot be reached 1100
    0F-Digital Radio -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: Cannot be reached 1100
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    37-Navigation -- Status: Cannot be reached 1100
    3C-Lane Change -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Malfunction 0010
    65-Tire Pressure -- Status: Malfunction 0010
    67-Voice Control -- Status: Cannot be reached 1100
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CALA) Labels:| 06E-907-559-CAL.clb
    Part No SW: 8T0 907 559 G HW: 8T0 907 559 B
    Component: 3.2 SIMOS8.2 H08 0002
    Revision: -------- CVN: 40586940
    Coding: 01040009190F0121
    Shop #: WSC 23728 002 1048576
    ASAM Dataset: EV_ECM32FSI8T0907559G A01004
    ROD: EV_ECM32FSI8T0907559G.rod
    VCID: 4683E31FF9A7E4A3B9-8012
    VINID: 9D195D6C721B10978000010000A06D86CA
    2 Faults Found:
    6201 - Function Restriction due to Faults in Other Modules
    U1113 00 [108] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 8
    Mileage: 189782 km
    Date: 2008.02.08
    Time: 00:35:25
    Engine RPM: 706.00 /min
    Normed load value: 17.6 %
    Vehicle speed: 0 km/h
    Coolant temperature: 75 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 14.523 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 1312 /min
    MAF_ENVD: 212.43529 mg/stroke
    Coolant temperature (unfiltered): 60.8 °C
    Engine: operating status: IS
    Engine load: 39.453125 %
    Vehicle speed: actual: 0 km/h
    6134 - Function Restriction due to Faults in Other Modules
    U1113 00 [100] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 189782 km
    Date: 2008.02.08
    Time: 00:31:31
    Engine RPM: 1093.00 /min
    Normed load value: 56.5 %
    Vehicle speed: 1 km/h
    Coolant temperature: 18 °C
    Intake air temperature: 11 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.710 V
    Engine speed: actual: 1088 /min
    MAF_ENVD: 386.74117 mg/stroke
    Coolant temperature (unfiltered): 18.0 °C
    Engine load: 56.250000 %
    Vehicle speed: actual: 1 km/h
    Readiness: 1110 0101
    Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
    Part No SW: 8K0 927 158 D HW: 0B6 927 156
    Component: 0B6 32 FSIUSA H04 0010
    Revision: --H04---
    Coding: 001002
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_TCMAL651 A01004
    ROD: EV_TCMAL651.rod
    VCID: 377D9EDB8E4D8D2B32-8062
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 0F2500
    Shop #: WSC 02399 823 56573
    VCID: 7BF542EBFAE5694B96-802E
    2 Faults Found:
    03110 - Active Steering Control Module (J792)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 9
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:32
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4782
    Hex Value: 0x000D
    Hex Value: 0x33B8
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:32
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4782
    Hex Value: 0x0016
    Hex Value: 0x02B8
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
    Component: BCM2 1.1 H71 0134
    Revision: 00002001
    Coding: 0D0100
    VCID: 75E154D3DCC13F3BE0-8020
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H35 0039
    Serial number: 0208000015078009
    3 Faults Found:
    00192 - Rear Left Door Handle Touch Sensor (G417)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:13:15
    03286 - Sensor for Contact with Door Handle; Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:13:17
    00193 - Rear Right Door Handle Touch Sensor (G418)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:13:17
    Address 07: Control Head
    Cannot be reached
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
    Component: KLIMA 3 ZONEN H06 0140
    Revision: C1000000 Serial number: 0125.04.080896
    Coding: 46002000
    VCID: 72EB6FCFADAF2803C5-8026
    2 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:33
    Freeze Frame:
    Temperature: 10.0°C
    Temperature: 75.0°C
    Load: 0.0 %
    Absolute Pres.: 1.2 bar
    RPM: 680 /min
    Speed: 0.0 km/h
    Current: 0.000 A
    Temperature: 8.0°C
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 233
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:34
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H21 0253
    Revision: 05021001 Serial number: 00000000132823
    Coding: 26001091063CAF311F00080300003D0D0F9CD2480001016100 0000
    VCID: 306FA5C763235A1373-8064
    Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 060508 H06 0060
    Serial number: SWFBIE 0001228
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10116531
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    Serial number: 00000000000205080341
    3 Faults Found:
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 01:01:00
    03189 - Bulb for Side Marker Light; Front Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 01:01:00
    02258 - Door Opener Transmitter
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:15:00
    Address 0E: Media Player 1
    Cannot be reached
    Address 0F: Digital Radio
    Cannot be reached
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 B HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0010
    Revision: 11001001 Serial number: 75330811900427
    Coding: 200103
    VCID: 387F9DE78B5382533B-806C
    Address 14: Susp. Elect. (J250) Labels: None
    Part No SW: 8K0 907 364 HW: 8K0 907 364
    Component: DAEMPFUNGS-SG H08 0052
    Revision: 00000000 Serial number: 16040802450001
    Coding: 050181
    Shop #: WSC 02101 444 58852
    VCID: 70EF65C7A3A31A1333-8024
    1 Fault Found:
    03264 - Functionalty Shut Off
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:31
    Freeze Frame:
    Error Code: 9
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0039GD12216A Dataset Number: 8K0909602B0017
    Coding: 303836354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_A02.rod
    VCID: 3D718CF3AC71A77BE8-8068
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
    Component: BF-Gewichtss. H01 0030
    Serial number: 5810000R0800000XDW
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME3A243010$
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 6344MSME2724060FA
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 6352QSME63563537F
    Passenger side rear thorax airbag crash sensor:
    Serial number: 6362QSME6608400BD
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME4B331D1A2
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME4F445210Z
    1 Fault Found:
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
    B1016 14 [137] - Open or Short to Ground
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 189782 km
    Date: 2008.02.08
    Time: 00:38:48
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
    Component: Lenks.Modul H04 0005
    Revision: -------- Serial number: 90372MG9001SR
    Coding: 000016
    Shop #: WSC 45415 001 1048576
    VCID: 4487F917C79BD6B3A7-8010
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 A HW: 8K0 920 980 A
    Component: KOMBIINSTR. H15 0221
    Revision: 00000000 Serial number: 7BW230P48
    Coding: 8B1609003300D705020000
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0092
    Revision: FB402044 Serial number: 4400F0842181B7
    Coding: 000303
    VCID: 4A9BD72FE5BF00C35D-801E
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H03 0150
    Serial number: 1801451C060408
    1 Fault Found:
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:02:12
    Address 1B: Active Steering (J792) Labels: None
    Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
    Component: DYNAMIKLENK. H05 0570
    Revision: 50000003 Serial number: --------------
    Coding: 8C0000
    1 Fault Found:
    01087 - Basic Setting Not Performed
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:38:46
    Freeze Frame:
    Count: 56
    Count: 1
    Hex Value: 0x007D
    Hex Value: 0x7C1A
    Hex Value: 0x0C00
    Hex Value: 0x0400
    Address 1E: Media Player 2
    Cannot be reached
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Part No SW: 8K0 959 760 HW: 8K0 959 760
    Component: MEM-FS H05 0043
    Revision: AA000000 Serial number: 00001001077951
    Coding: 00581B00000044440000
    VCID: 77FD5EDBC6CD4D2BF2-8022
    5 Faults Found:
    03330 - Motor for Fore/Aft Adjustment
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:40
    03331 - Motor for Backrest Angle Adjustment
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:40
    03332 - Motor for Height Adjustment
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:41
    03333 - Motor for Cushion Angle Adjustment
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:41
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:44
    Address 37: Navigation
    Cannot be reached
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0040
    Revision: 00H01000 Serial number: 6PZ 009 014-13
    Coding: 0000001
    VCID: 366393DF4147742329-8062
    2 Faults Found:
    00447 - Function Limitation due to Over-Voltage
    001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:38:51
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:39:46
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000007998132
    Coding: 011C03204000410001
    Shop #: WSC 02391 823 56573
    VCID: 4189F003D889C39B8C-8014
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0109272733
    Coding: 0106023A007A440500B001
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0050
    Serial number: 00000000000000169826
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
    Component: J245 PS034 H06 0037
    Address 47: Sound System
    Cannot be reached
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 B HW: 8K0 959 792
    Component: TSG BF H10 0170
    Revision: Serial number: 0000007152994
    Coding: 011C13204E00410001
    VCID: 3E738BFFA977BC63F1-806A
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000365326
    Shop #: WSC 00000 000 00000
    VCID: 3467A9D7973B663317-8060
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:38:48
    Freeze Frame:
    Voltage: 12.80 V
    Count: 80
    Speed: 0.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000005
    VCID: 3467A9D7573B663317-8060
    1 Fault Found:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    010 - Open or Short to Plus - MIL ON
    Freeze Frame:
    Fault Status: 11101010
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:35:46
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8K0 959 795 HW: 8K0 959 795
    Component: TSG HL H06 0170
    Revision: Serial number: 0000007135870
    Coding: 010C13204000210001
    VCID: 7F0DB6FBEEFD756BBA-802A
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 17:58:17
    Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
    Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
    Component: J502-RDK H03 0250
    Revision: 00001001 Serial number: 12822707120231
    Coding: 0CD154
    1 Fault Found:
    01521 - Sensor for Tire Pressure
    002 - Lower Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 189782 km
    Time Indication: 0
    Date: 2008.02.08
    Time: 00:38:50
    Freeze Frame:
    0.00
    Bin. Bits: 00000000 00000001
    Voltage: 12.70 V
    Text: 09,0°C;n.erkannt; n.erkannt
    Address 67: Voice Control
    Cannot be reached
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
    Component: J772__Rearview 0070
    Revision: --H12--- Serial number: 525PA8-J8291NV
    Coding: 1001006
    VCID: 377D9EDB464D8D2B32-8062
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
    Part No SW: 8K0 959 794 HW: 8K0 959 795
    Component: TSG HR H06 0170
    Revision: Serial number: 0000007104995
    VCID: 7EF34BFFE9F77C63B1-802A
    Address 77: Telephone
    Cannot be reached
    End-------------------------(Elapsed Time: 04:40)--------------------------
    Feb 25 2025
    Pottstown, PA
    Looking for some help to identify the problem that I can fix myself and which one I will have to get the assistance of a repair shop. Any help to identify the issues found with VCDS that can guide me on the right direction will be highly appreciated, as the dashboard looks like a Christmas tree lights and it is such a nice car that I really would like to fix it. Thanks in advance
    Feb 25 2025
    Pottstown, PA
    See photos of the car
