This kinda surprised me. Was checking for a PS leak, my rack sprung a leak again, and found this.
These arms are only maybe 6 months old, maybe 5k miles, and the 1 bushing completely failed. Everything was torqued at ride height like it should be, so wasn't that. The bushing totally separated from the sleeve. All the others are fine, but 1 completely failed.
Has anyone ever seen this or had it happen?
Had cheap eBay ones hold up much better, let alone a $700+ set, lol. Good thing I got them super cheap. Gonna install some poly bushings now.
Only issue is the sizing is different on the adj arms. Bushing is ~1-1.5mm smaller, and arm is wider. Caused the bushing to kinda push out, so I had to trim it a bit.
We'll see how these ECS bushings do, had good luck with them before.
Sent from my CPH2611 using Audizine Forum mobile app
