Results 1 to 4 of 4
Thread: Door Plug?
    Junior Member Two Rings Mar'd's Avatar
    Aug 08 2019
    S4 B7 Avant (2007), S5 B8.5 (2014)
    Northern New Mexico
    Door Plug?
    I hate asking dumb questions, but I'm having trouble finding this part. Driver's side door closes a bit hard and I noticed this stopper bumper plug thing is missing. Anyone know what it's called?
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Just ran out to my car to check, there is no plug that goes where that bolt is. I checked all my doors. The door relies on the rubber stripping surrounding the interior of the door for a "softer" close. Is your rubber not soft anymore? Could be the problem. Easy as replacing with generic weatherstripping and some glue at an auto store if that's the case.
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Aug 08 2019
    Northern New Mexico
    Sounds like a worthwhile project since my weatherstripping has never been replaced. You are more than likely right about that being the cause. I had since pulled the screw from another door to get a better look at one. It looks like the driver side door screw broke off, and the base has moved a bit. I put a couple rubber stops over the hole to no benefit to the rough closing. Thanks for the reply!
    Oct 03 2017
    Any time, happy to help! I have yet to see this issue with this car but had a friend with a Scion a couple years back with a similar problem so that's where my mind went. Rubber weatherstripping was basically hard as a rock and the door was having a hard time closing/sealing shut. Very little humidity does not help here.
