INTRODUCING THE APR DTR8563 TURBOCHARGER SYSTEM FOR THE AUDI 2.5 TFSI!
Product Page
Unlock the full potential of your Audi RS3 or TTRS with the new APR DTR8563 Turbocharger System—a direct bolt-on upgrade designed for enthusiasts who want serious power without the hassle and expense of major engine modifications. With just an APR intake and intercooler, you’ll see up to 672 HP and 544 FT-LBS of torque without requiring modifications to the engine internals, exhaust, fueling, or sensors! This means you get brutal performance without compromising reliability or your budget. It’s power designed to dominate the streets, not your wallet.
At APR, we know the chase for horsepower can get expensive. We’ve engineered high-power setups that push the limits of what’s possible, but they’ve always required costly upgrades and ongoing tweaks to fuel systems, sensors, and even engine internals. The thrill was real, but so were the costs. And the results? Often fleeting—price and risk of engine failure for more power kept climbing.
This time, we’ve done things differently. The DTR8563 Turbocharger redefines the balance between performance and practicality, making it the perfect choice for enthusiasts who demand reliable, exhilarating power without turning their cars into high-maintenance race machines. This turbocharger delivers street-legal performance that’s easy to install—no need to open up your engine, overhaul the fuel system, or even modify the exhaust. Its exceptional transient turbo response ensures smooth driving around town, while stepping on the throttle unleashes brutal acceleration that pins you to your seat and climbs relentlessly to the 7,500 RPM redline. This setup delivers staggering results: 0-60 MPH in 2.x seconds, low 10.x-second quarter-mile passes at 13x MPH, and high 6.x-second 60-130 MPH runs—all achievable on the street without gutting your car or relying on specialized racing tires and surfaces like those typically found on record-setting passes. Designed for both practicality and performance, the DTR8563 brings more torque, more power, and more fun to your drive—all without compromises.
The APR DTR8563 system includes everything you need for a seamless upgrade: a complete drop-in turbocharger, the turbo inlet adapter ring for our intake inlet, all necessary gaskets and o-rings, plus a free upgrade to our Stage 3 engine and transmission tuning software from our lower stages. With just our intake and intercooler, you’ll hit impressive power figures, while still keeping compatibility with other APR modifications
This is truly performance without compromise—reliability, affordability, and incredible power in one street-legal package. Don’t settle for less. Go APR and dominate the road.
Features and Benefits
- Direct Bolt-On Turbocharger System: Complete upgrade kit with tuning software and mounting hardware for a seamless installation.
- Free Software Upgrades: Complimentary upgrade to APR Stage 3 ECU and TCU software from lower stages.
- Exceptional Power Gains: Achieve up to 672 HP / 544 FT-LBS (+289 AWHP / +203 AWFT-LBS) with APR intake and intercooler.
- German-Engineered Precision: Dual ceramic ball-bearing center section with VSR-balanced rotating assembly for optimal performance.
- Aircraft-Grade Durability: Billet 6061 aluminum compressor wheel with precision anti-surge cover for reliability and efficiency.
- High-Flow Capability: Nickel-based superalloy K418 turbine wheel designed for maximum power output with low back pressure.
- Heat-Resistant Design: 310 stainless steel turbine housing with internal wastegate for unmatched durability and longevity.
- Optimized for Multiple Fuels: Five fuel-grade tunes available: 91 AKI (95 RON), 93 AKI (98 RON), 100 AKI (104 RON), 104 AKI (108 RON), and E60-E85.
- No Engine Overhauls Required: No need for upgraded engine internals, exhaust, fueling systems, or sensors—reliable performance out of the box.
- Built-In Safety Protections: Advanced safety routines for enhanced reliability at high output levels.
- Enhanced Software Features: Optional exhaust crackle, raised standing rev limiter, speed limiter removal, and more.
- Comprehensive Installation Support: Full install guide included, with access to a vast global installer network.
- Lifetime Software Updates and Support: Enjoy ongoing enhancements and expert assistance.
- Street Legal Performance: Emissions-compliant design delivers exceptional power without altering emissions components.
Included Software Policy:
This kit includes an upgrade to the APR Stage 3 ECU/TCU for free from lower stages. If the vheicle is not already tuned with an APR ECU/TCU Upgrade you will need to purchase a lower stage ECU, and TCU. Specific software is required to use this system. Software compatibility must be checked before purchase & install. To get the advertised request, use a the APR Intake and APR Intercooler system. Factory 10,000 mile oil intervals are excessive. Cut oil intervals in half. To add an additional layer of protection, use a high performance oil matching the factory weight and minimum factory specs. Use APR Iridium Pro or equivalent heat range spark plugs.
Hardware Requirements
APR Intake System (inlet adapter included with turbo)
APR Intercooler System
APR Iridium Pro Spark Plugs
[b]Fitment Guide as of February 26th, 2025[b]
Software Ready
Audi RS3 (8V) 2.5T (DAZA) NAR
Audi TTRS (8S) 2.5T (DAZA) NAR
Software in final testing stages
Audi RS3 (8V) 2.5T (DAZA) ROW
Audi TTRS (8S) 2.5T (DAZA) ROW
Software in validation - future support
Audi RS3 (8V) 2.5T OPF (DWNA) ROW
Audi TTRS (8S) 2.5T OPF (DWNA) ROW
Audi RSQ3 (F3) 2.5T OPF (DWNA) ROW
Software in development - future support
Audi RS3 (8Y) 2.5T (DXHA) NAR
Audi RS3 (8Y) 2.5T (DXHB) NAR
Audi RS3 (8Y) 2.5T OPF (DWNC) ROW
Audi RS3 (8Y) 2.5T OPF (DWND) ROW
Cupra Formentor VZ5 (KM7) 2.5T OPF (DWNB) ROW
Product Page
