Results 1 to 3 of 3
    Junior Member Two Rings
    Aug 31 2021
    Arlington VA
    Code P0491 & P0492 from Piggies?
    I gutted my pre cats and now have code 0491 and 0492. Is this from gutting the pre cats or something else?
    Nov 12 2015
    Oregon
    Nope. Its SAi code. Sounds like you have a vacuum leak going to your Combi valves or something like a bad SAi pump or broken flexible SAi line
    Sent from my SM-N975U using Tapatalk
    My build log
    Aug 31 2021
    Arlington VA
    Thanks Vinny. I am trying to diagnose the problem now. It does not feel like I am getting any air through the vacuum lines. They broke when I tried to take them off to check so I need to get some replacements. I am not sure if it is suppose to have positive air blowing out of the line or pull a vacuum through them but either case it is not doing much. I checked the SAI motor and it didnt seem like it was coming on. I ran power directly to the SAI motor and it will run then. I am going to double check it at start up when I know the motor is good and cold. I did check the 40 amp fuse for the SAI motor and it is good. Any hints of where to look would be appreciated.
