So no communication at all then. Is your car parked inside or outside more often before this happened? It could simply be the relays under ECM behind the false firewall. If the drains under the cowl back up, water can rise and work its way into the ECM box. The seal on those boxes aren't the greatest when it comes to standing water and being a number of years old. Unfortunately to get into it to check you have to pull the wiper arms, then separate the cowl from the bottom of the windshield and then you can use a Torx-30 to remove the screws holding the ECM box closed.
Pulling the wiper arms can be a bitch if they've never been off though; I would recommend a puller. If it's not that case, send me you vin and if I have some free time I can try to pull up the wiring diagrams and find which wires through supply power and the wake up signal for ecm
Sent from my Pixel 6 Pro using
Audizine Forum mobile app
