    Junior Member One Ring
    Oct 27 2018
    Accessory belt squeal
    I'm having a hard time tracking down a squeal under load from my accessory belt.
    It started after I got the power steering pump replaced by a shop while traveling. I put on a slightly shorter belt and it went away for about 6 months, but then came back when on a long highway trip.
    Since then I've replaced the tensioner and idler pulley, the power steering pump (the one the shop installed was about 1/8" out of alignment with the idler and AC pulleys) and most recently the alternator when I realized the clutch had seized.
    I just swapped out a fresh belt since there was some wear on the backside and edges of the previous one, but same squeal is happening when I give it more than 20% throttle.
    What could be going on here?
    Junior Member Two Rings Duece McCracken's Avatar
    Jan 12 2025
    Croydon, PA
    Quote Originally Posted by bugleg View Post
    Any signs of contaminates? Oil, coolant, PS fluid. Did you brake clean the pullies just to be sure?
    Seems you have addressed most of the mechanical alignment and tension components. Not too much else to the acc drive belt system.
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    Back in the day when working at Chevron we used a Belt Dressing Stick. Not sure if that would be appropriate with the VAG style ribbed belts, but it worked great on v-belts. The AC compressor on my B5 squeals if AC is engaged on startup...after warmed up it is fine.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Small amount of soapy water may have the same effect as the belt dressing stick - that's what my mechanic Dad would use on vehicles back in the day
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Slightly late to the party but your serpentine belt isn't a DAYCO belt is it? Those things squeak. Every. Single. Time.
    Quote Originally Posted by a4audi4fun View Post
    Can confirm this is a little mechanic trick but I have also seen a tiny bit of die-electric grease on the ribbed-side of the belt can also get them to quiet down a bit.
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
