    Junior Member One Ring Alan_11gl's Avatar
    Jul 19 2015
    Meoqui, Chihuahua
    Audi S4 B5 close/open door sensor
    Hello Guys
    I was wondering if someone have information (Diagram, pictures, etc) about of close/open door sensor, my vehicle showing a door open but i couldn't see any sensor around of door.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    If it’s anything like my C5’s there’s a little micro switch in the locking mechanism. It’s got two wires, one red and one blue. Over time it either wears out and no long actuates enough because the surface has worn down, or it gets corroded and fails internally. At this age, a lot of these have solidified grease inside and are rusty, too. You can try to take it apart, it’s not too difficult, once you finagle it out of the door.
    You have two kind of lame options in my opinion:
    - Roll the dice on a used unit which can probably be found on Marketplace, a junkyard, or eBay.
    -Get an aftermarket one that can be really cheaply made and fail in a few years, itself.
    A few years ago I found the micro switches themselves online, but my order was canceled a few months later so I just started looking in junkyards for replacements. OE is usually best with this kind of stuff.
    https://www.ebay.com/itm/32606694134...60PEY5M7HP1ZWN
    May 10 2018
    MA
    The sensor is in the latch on front doors. Rear is a switch on the quarter label side
    Depending on the door, I can still possibly get it. New and genuine. Have supplied a bunch to others.
    Oct 14 2006
    by the lakeshore, mi
    Do these sensors in the door latch also cause your interior motion sensor system to act wonky? Reason why I ask is because (this past late summer/early fall) when I had my avant locked, the alarm went off as the interior motion sensor was tripped even though I had all windows and sunroof closed. I turned on the interior motion sensor switch and the system still goes off. Now during the winter months, everything works as normal when I lock my avant.
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    May 10 2018
    MA
    Quote Originally Posted by speedydtp247 View Post
    I’m not sure on that. I know the interior motion sensor button does go bad. I have those in stock for that reason.
    The other thing that gradually goes bad, is the central locking pump. All of the above (and more) runs through it.
