Results 1 to 2 of 2
    Feb 09 2022
    Colorado
    SQ7 OBDEleven Block?
    Has anyone had any luck long-coding things on the 4M.5 SQ7 using OBDELEVEN? I recently purchased a 2021 SQ7 and trying I am trying to long code “Central Locking System lock unlock at engine running” and keep running into the warnings below. Depending on what security access I have chosen or diagnostics view, I get one of the 3 responses below. I have the Pro VAG account and have initiated all dual factor authentication procedures for SFD and SFD2 unlocks, even though I do not believe this car has SFD. I have the coded dozens of VW’s and Audis with this device and never had an issue, including our 2018 Q7, 2019 S5, 2018 Golf R, and 2017 Golf R.
    Prior to coding, I have opened the hood, tried engine running and not running, battery is brand new and voltage is perfect. Also, I have parked on a flat surface with drive mode in “Auto”.
    I havee googled and googled with no luck. Appreciate any help!
    1. “Writing” and then it get stuck on this screen indefinitely. The only way out is by force closing the app
    2. “Procedure cannot be performed, incorrect sequence”
    3. “Function not available”
    Lastly, at the recommendation of someone in the MQB space, I was able to turn on and off Terminal 15 in Module 46, with no further success..
    Feb 09 2022
    Colorado
    Anyone? I stuck my OBDELEVEN in my other 2018 Q7 for fun this weekend and was able to code anything with no issues.. Weird.
