Results 1 to 6 of 6
    Junior Member Two Rings
    Feb 27 2024
    2003 A4 Avant (Built 2.7t Tial605 Swap)
    Basics
    Love this car, but I'm looking to move on to something smaller and lighter.
    Very well maintained, and has been a reliable daily driver for me over the past year.
    All the big 2.7t stuff has been taken care of by previous owners, me, or Joe @ Northeast Euro.
    Has some minor cosmetic flaws: small dents & chips on the front.
    ~450whp, looks & sounds amazing, and gets tons of attention.
    Built engine, so its ready for E85/meth, or bigger turbos if you want to go that route.
    ~140k miles on chassis, ~30k on built engine & turbos.
    No rust, car came from NC/CO.
    Vin: WAUVC68E23A167777
    EDIT: PRICE DROP: Opportunity to buy a TTRS has come up, would like to get this car sold beforehand for storage/financial logistics
    Asking $18k
    Located in Connecticut, 06478
    Links
    Here is a document with full service history, complete mod list, underside pictures, extra parts list, VIN, etc...
    Original owner’s build thread (This is Aaron's old car)
    Mod List
    ## Engine
    - 2.7t swap, rebuilt w forged rods, 30k miles on rebuild
    - Forged rods, ARP rod/head bolts, pistons rings, bearings, honed cylinders, timing belt, oil pump tensioner/chain, gaskets, seals, etc
    - Tuned by Blake/ETSpec
    - 25psi, LC, NLS
    - BEL Block
    - APB Heads for SAI delete
    - DM Forged Rods
    - ARP Head & rod bolts
    - Tial 605.2 Turbos
    - Inspected at 25k, no shaft play or leaks
    - Fluidampr Crank Pulley
    - 034 Spider PCV hoses
    - NGK PFR7Q plugs
    - OEM red-top push down coil packs
    ## Intake
    - B7 RS4 Airbox
    - CTS 85mm MAF housing
    - 034 Bipipes, DVs, TBB
    - Tial 2.25” inlets
    - ER Side mount intercoolers
    - TFSI N75 valve
    - 3 bar MAP sensor
    - N249 Delete
    ## Fueling
    - Walboro 450 fuel pump + 034 Fuel pump bracket
    - All new fuel lines
    - Bosch EV14 750cc injectors
    ## Cooling/Fluids
    - CSF Radiator
    - Upgraded/insulated turbo coolant drain lines.
    - Aux water pump relocation kit
    - Aluminum thermostat housing
    - 034 silicone PS pump hose
    ## Transmission
    - Allroad late 01E
    - JHM Short Shifter
    - TTV Billet SMF, Stage 4 clutch
    ## Suspension/Mounts
    - H&R Street Coilovers
    - ECS Poly engine mounts
    - 034 density line trans mounts
    - 034 density line control arm set
    - B6 S4 front sway bar
    - 034 Rear sway bar
    - Apikol rear diff mount
    - B7 RS4 steering rack
    - With servotronic retrofit
    ## Brakes
    - 18z BBK, braided lines
    - B6 S4 rear brakes
    - EBC Red pads
    ## Exhaust
    - Custom downpipes
    - GESI High flow cats
    - Passes emissions
    - x-pipe
    - B7 RS4 Magnaflow catback
    - EGT Delete resistors
    ## Interior
    - B6 S4 front/rear seats
    - B7 center console
    - BFI Shift knob
    - 8P S-line Flat bottom steering wheel
    - JCM Industries Duel Gauge Pod defrost vent
    - AEM X-gauge AFR & Boost gauges
    - Newly redone headliner
    - Rennline pedals
    - Xtrons Carplay/AA Headunit
    - Dashcam & Reverse cam
    ## Exterior
    - B6 S4 side blades, spoiler, rear bumper
    - Ultrasport front bumper
    - B6 S4 Xenon headlights
    - 20% Tints on side & rear
    ## Wheels
    - B8 S5 Rotors
    - 19x9 ET33
    - Michelin PS4AS 235/35/19
    - ~1.5y old
    # Extra Parts
    - 2 Keys
    - Roof rack
    - Complete B6 rear differential
    - ECS lightweight crank pulley
    - Piano black trim pieces, extra brushed alu interior trim pieces
    Junior Member Two Rings mightar's Avatar
    Jan 20 2020
    Silicon Valley
    Damn that's badass!
    2017 Rebel Blue V60 Polestar | 2021 Performance Blue Veloster N 6MT
    Previous: 2017 Elantra Sport | 2008 E63 AMG wagon | 2002 S6 Avant | 2001.5 S4 | 1994 Integra RS
    Veteran Member Four Rings ENVČ's Avatar
    Nov 04 2010
    I wish. That’s too much for my wallet. Someone will be very happy owning this thing.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Feb 27 2024
    Bump. Price drop. Looking to sell this car soon to potentially make room for a TTRS :)
    Aug 02 2012
    chicago, IL
    Full photos or just whats in the build thread ?
    Feb 27 2024
    Sold
